Running Zoneminder inside Mininet
limciana
Post by limciana » Mon Nov 05, 2018 7:13 am
I'm trying to run Zoneminder inside a Mininet host, without any luck.
I can only open Zoneminder when I use my native machine's IP address, and not the mininet host's IP address. If I type in the mininet host's IP address on the address bar, it says it's unable to connect to the server. However, when I type in my native machine's IP address, I see Apache2's Default Page, which means that Apache2 is running, but not inside the mininet host. What I want is that I can run Zoneminder (which means that I should run Apache2 and see its default page as well) using Mininet's IP address.
What I did is to open Firefox through root inside Mininet host (such that when I type localhost, it actually means the IP address of the Mininet host), and then tried typing the IP addresses.
I tried changing the IP address that Apache2 is to host, but it always gives me a DNS error whenever I use the mininet host's IP address, saying that it does not exist.
I did a native installation of mininet in my machine. My machine is a Linux Mint 18 Sarah, which runs on Ubuntu 16.04. My Zoneminder is version 1.32. I followed the Easy Way Installation from the official documentation.
I am not sure if I should configure zoneminder's connection to Apache, or Apache's connection to the network, for this to work.
Any help will be appreciated. Thank you!
