Upgrade from 1.31
Upgrade from 1.31
I've been running ZM 1.31.? for a few months. It is installed on Centos 7 VM on an Esxi server and I used the ZM redhat install instructions. I worked fine until I updated Centos 7 and it updated ZM to 1.32.2. First had an error to update zm???.pl (I don't remember) I did and now seems to work but when in montage view I click past hour or 8 hours the data is marked red on all three cameras and I get no frame found for event and the path to the image.php. After messing with it I messed it it up more and I also get Diskspace event does not exist. I could post the log file but its not in the /var/log/zoneminder folder where the config says it should be..Any help appreciated.
Re: Upgrade from 1.31
See log pics.
- Capture2.JPG (71.2 KiB) Viewed 1882 times
- Capture.JPG (124.61 KiB) Viewed 1882 times
This sounds very similar to my issue posted here: viewtopic.php?f=38&t=27709
I am testing a few things now to see what works and what does not.
Question, where do you see that log view? In my older version of zoneminder I had a log link in the upper right hand corner, now that gone. How do I get that back?
Nevermind I got the log back, you have to turn it on in Options > Logging > LOG_LEVEL_DATABASE > set to a desired level.
Thanks. I'll check out the link.
