Ffmep video stream stop and start
Posted: Fri Oct 26, 2018 7:03 am
Dear ZoneMinder community,
I’m creating this post to get your feedback and point of view about error messages retrieved into zoneminder logs.
I have installed ZoneMinder 1.32.2 into a fresh CentOS 7.5.1804 and have followed the installation guide from RHEL ZoneMinder documentation by using RPM fusion without facing any problem.
The only thing I have done is to use dedicated drive for /images and /events folder but I have also strictly followed ZoneMinder documentation to do that.
Actually, I have only 1 RTSP camera configured as Ffmeg source and acting as monitor only, method TCP actually used.
When camera start or zoneminder restart, first direct video stream appears to be start and stop every 30sec approximatively. This start/stop phases have been going on in the first 10min when camera or zoneminder started. Then, direct video stream goes into normal way and no more error message into zoneminder logs.
I would like to avoid some misconfiguration and would like to have your feedback.
I have also tried to use “Extract” command from ZoneMinder webpage but I always encounter error message like this one appears just after having clicked on “Extract” button :
I have made an extract of logs just right after camera or zoneminder start.
Thanks for your support,
Cheers
Cyril
ERR Uncaught TypeError: $(...).overlayShow is not a function https://192.168.1.56/zm/cache/skins_classic_views_js_log-base-1539455775.js
Cheers
Cyril
25/10/2018 15:22 zmc_m5 14834 INF Cuisine: images:1 - Capturing at 14.29 fps, capturing bandwidth 22212bytes/sec zm_monitor.cpp 2473
25/10/2018 15:22 zmwatch 13735 ERR Memory map file '/dev/shm/zm.mmap.5' does not exist. zmc might not be running. zmwatch.pl
25/10/2018 15:22 zmdc 14834 INF 'zmc -m 5' started at 18/10/25 15:22:06 zmdc.pl
25/10/2018 15:22 zmdc 13659 WAR Can't find process with command of 'zmc -m 5' zmdc.pl
25/10/2018 15:22 zmc_m5 14834 INF Starting Capture version 1.32.2 zmc.cpp 223
25/10/2018 15:22 zmdc 13659 INF 'zmc -m 5' starting at 18/10/25 15:22:06, pid = 14834 zmdc.pl
25/10/2018 15:22 zmc_m5 14834 INF Priming capture from rtsp://admin:@192.168.1.54:554 zm_ffmpeg_camera.cpp 163
25/10/2018 15:22 zmc_m5 14834 INF Stream open rtsp://admin:@192.168.1.54:554, parsing streams... zm_ffmpeg_camera.cpp 378
25/10/2018 15:22 zmwatch 13735 INF Restarting capture daemon for Cuisine, shared data not valid zmwatch.pl
25/10/2018 15:21 zmdc 13659 INF 'zmc -m 5' exited normally zmdc.pl
25/10/2018 15:21 zmdc 13659 INF Command 'zmc -m 5' removed from pending list at 18/10/25 15:21:56 zmdc.pl
25/10/2018 15:21 zmwatch 13735 INF Restarting capture daemon for Cuisine, no image since startup. Startup time was 1540473706 - now 1540473716 > 5 zmwatch.pl
25/10/2018 15:21 zmdc 13659 INF 'zmc -m 5' starting at 18/10/25 15:21:46, pid = 14810 zmdc.pl
25/10/2018 15:21 zmwatch 13735 INF Restarting capture daemon for Cuisine, shared data not valid zmwatch.pl
25/10/2018 15:21 zmc_m5 14810 INF Got signal 15 (Terminated), exiting zm_signal.cpp 40
25/10/2018 15:21 zmc_m5 14810 INF Priming capture from rtsp://admin:@192.168.1.54:554 zm_ffmpeg_camera.cpp 163
25/10/2018 15:21 zmdc 13659 INF 'zmc -m 5' sending stop to pid 14810 at 18/10/25 15:21:46 zmdc.pl
25/10/2018 15:21 zmc_m5 14810 ERR Unable to open input rtsp://admin:@192.168.1.54:554 due to: Interrupted system call zm_ffmpeg_camera.cpp 357
25/10/2018 15:21 zmc_m5 14810 ERR Failed to prime capture of initial monitor zmc.cpp 253
25/10/2018 15:21 zmwatch 13735 ERR Memory map file '/dev/shm/zm.mmap.5' should have been 1168 but was instead 0 zmwatch.pl
25/10/2018 15:21 zmdc 14810 INF 'zmc -m 5' started at 18/10/25 15:21:46 zmdc.pl
25/10/2018 15:21 zmdc 13659 INF Starting pending process, zmc -m 5 zmdc.pl
25/10/2018 15:21 zmc_m5 14810 INF Starting Capture version 1.32.2 zmc.cpp 223
25/10/2018 15:21 zmfilter_2 13710 INF Checking filter Update DiskSpace update disk space returned 0 events zmfilter.pl
25/10/2018 15:21 zmfilter_1 13699 INF Checking filter PurgeWhenFull delete returned 0 events zmfilter.pl
25/10/2018 15:21 zms_m5 14798 ERR Unable to connect to zmc process for monitor 5 zms.cpp 254
25/10/2018 15:21 zms_m5 14798 ERR Unable to connect to monitor id 5 for streaming zm_stream.cpp 48
25/10/2018 15:21 zms_m5 14798 ERR Got empty memory map file size 0, is the zmc process for this monitor running? zm_monitor.cpp 538
25/10/2018 15:21 web_js 20990 ERR getStreamCmdResponse stream error: Socket /var/lib/zoneminder/sock/zms-247272s.sock does not exist. This file is created by zms, and since it does not exist, either zms did not run, or zms exited early. Please check your zms logs and ensure that CGI is enabled in apache and check that the PATH_ZMS is set correctly. Make sure that ZM is actually recording. If you are trying to view a live stream and the capture process (zmc) is not running then zms will exit. Please go to http://zoneminder.readthedocs.io/en/latest/faq.html#why-can-t-i-see-streamed-images-when-i-can-see-stills-in-the-zone-window-etc for more information. - checkStreamForErrors() ?view=watch
25/10/2018 15:21 web_php 20990 ERR Socket /var/lib/zoneminder/sock/zms-247272s.sock does not exist. This file is created by zms, and since it does not exist, either zms did not run, or zms exited early. Please check your zms logs and ensure that CGI is enabled in apache and check that the PATH_ZMS is set correctly. Make sure that ZM is actually recording. If you are trying to view a live stream and the capture process (zmc) is not running then zms will exit. Please go to http://zoneminder.readthedocs.io/en/latest/faq.html#why-can-t-i-see-streamed-images-when-i-can-see-stills-in-the-zone-window-etc for more information. /usr/share/zoneminder/www/includes/functions.php 2043
25/10/2018 15:21 zms_m5 14786 ERR Unable to connect to monitor id 5 for streaming zm_stream.cpp 48
25/10/2018 15:21 zms_m5 14786 ERR Got empty memory map file size 0, is the zmc process for this monitor running? zm_monitor.cpp 538
25/10/2018 15:21 web_php 7961 ERR Socket /var/lib/zoneminder/sock/zms-382537s.sock does not exist. This file is created by zms, and since it does not exist, either zms did not run, or zms exited early. Please check your zms logs and ensure that CGI is enabled in apache and check that the PATH_ZMS is set correctly. Make sure that ZM is actually recording. If you are trying to view a live stream and the capture process (zmc) is not running then zms will exit. Please go to http://zoneminder.readthedocs.io/en/latest/faq.html#why-can-t-i-see-streamed-images-when-i-can-see-stills-in-the-zone-window-etc for more information. /usr/share/zoneminder/www/includes/functions.php 2043
25/10/2018 15:21 zms_m5 14786 ERR Unable to connect to zmc process for monitor 5 zms.cpp 254
25/10/2018 15:21 web_js 7961 ERR getStreamCmdResponse stream error: Socket /var/lib/zoneminder/sock/zms-382537s.sock does not exist. This file is created by zms, and since it does not exist, either zms did not run, or zms exited early. Please check your zms logs and ensure that CGI is enabled in apache and check that the PATH_ZMS is set correctly. Make sure that ZM is actually recording. If you are trying to view a live stream and the capture process (zmc) is not running then zms will exit. Please go to http://zoneminder.readthedocs.io/en/latest/faq.html#why-can-t-i-see-streamed-images-when-i-can-see-stills-in-the-zone-window-etc for more information. - checkStreamForErrors() ?view=watch
25/10/2018 15:21 zms_m5 14756 ERR Unable to connect to monitor id 5 for streaming zm_stream.cpp 48
25/10/2018 15:21 zms_m5 14756 ERR Got empty memory map file size 0, is the zmc process for this monitor running? zm_monitor.cpp 538
25/10/2018 15:21 zms_m5 14775 ERR Unable to connect to monitor id 5 for streaming zm_stream.cpp 48
25/10/2018 15:21 zms_m5 14756 ERR Unable to connect to zmc process for monitor 5 zms.cpp 254
25/10/2018 15:21 zms_m5 14775 ERR Got empty memory map file size 0, is the zmc process for this monitor running? zm_monitor.cpp 538
25/10/2018 15:21 web_php 21156 ERR Socket /var/lib/zoneminder/sock/zms-285895s.sock does not exist. This file is created by zms, and since it does not exist, either zms did not run, or zms exited early. Please check your zms logs and ensure that CGI is enabled in apache and check that the PATH_ZMS is set correctly. Make sure that ZM is actually recording. If you are trying to view a live stream and the capture process (zmc) is not running then zms will exit. Please go to http://zoneminder.readthedocs.io/en/latest/faq.html#why-can-t-i-see-streamed-images-when-i-can-see-stills-in-the-zone-window-etc for more information. /usr/share/zoneminder/www/includes/functions.php 2043
25/10/2018 15:21 web_js 21156 ERR getStreamCmdResponse stream error: Socket /var/lib/zoneminder/sock/zms-285895s.sock does not exist. This file is created by zms, and since it does not exist, either zms did not run, or zms exited early. Please check your zms logs and ensure that CGI is enabled in apache and check that the PATH_ZMS is set correctly. Make sure that ZM is actually recording. If you are trying to view a live stream and the capture process (zmc) is not running then zms will exit. Please go to http://zoneminder.readthedocs.io/en/latest/faq.html#why-can-t-i-see-streamed-images-when-i-can-see-stills-in-the-zone-window-etc for more information. - checkStreamForErrors() ?view=watch
25/10/2018 15:21 zms_m5 14775 ERR Unable to connect to zmc process for monitor 5 zms.cpp 254
25/10/2018 15:21 web_php 6845 ERR Socket /var/lib/zoneminder/sock/zms-258431s.sock does not exist. This file is created by zms, and since it does not exist, either zms did not run, or zms exited early. Please check your zms logs and ensure that CGI is enabled in apache and check that the PATH_ZMS is set correctly. Make sure that ZM is actually recording. If you are trying to view a live stream and the capture process (zmc) is not running then zms will exit. Please go to http://zoneminder.readthedocs.io/en/latest/faq.html#why-can-t-i-see-streamed-images-when-i-can-see-stills-in-the-zone-window-etc for more information. /usr/share/zoneminder/www/includes/functions.php 2043
25/10/2018 15:21 zmc_m5 14700 INF Got signal 15 (Terminated), exiting zm_signal.cpp 40
25/10/2018 15:21 zmdc 13659 INF 'zmc -m 5' sending stop to pid 14700 at 18/10/25 15:21:36 zmdc.pl
25/10/2018 15:21 zmwatch 13735 INF Restarting capture daemon for Cuisine, no image since startup. Startup time was 1540473682 - now 1540473696 > 5 zmwatch.pl
25/10/2018 15:21 web_js 6845 ERR getStreamCmdResponse stream error: Socket /var/lib/zoneminder/sock/zms-258431s.sock does not exist. This file is created by zms, and since it does not exist, either zms did not run, or zms exited early. Please check your zms logs and ensure that CGI is enabled in apache and check that the PATH_ZMS is set correctly. Make sure that ZM is actually recording. If you are trying to view a live stream and the capture process (zmc) is not running then zms will exit. Please go to http://zoneminder.readthedocs.io/en/latest/faq.html#why-can-t-i-see-streamed-images-when-i-can-see-stills-in-the-zone-window-etc for more information. - checkStreamForErrors() ?view=watch
25/10/2018 15:21 zms_m5 14734 WAR no last_frame_sent. Shouldn't happen. frame_mod was (1) frame_count (0) zm_monitorstream.cpp 711
25/10/2018 15:21 web_php 7961 ERR Socket /var/lib/zoneminder/sock/zms-025527s.sock does not exist. This file is created by zms, and since it does not exist, either zms did not run, or zms exited early. Please check your zms logs and ensure that CGI is enabled in apache and check that the PATH_ZMS is set correctly. Make sure that ZM is actually recording. If you are trying to view a live stream and the capture process (zmc) is not running then zms will exit. Please go to http://zoneminder.readthedocs.io/en/latest/faq.html#why-can-t-i-see-streamed-images-when-i-can-see-stills-in-the-zone-window-etc for more information. /usr/share/zoneminder/www/includes/functions.php 2043
25/10/2018 15:21 web_js 7961 ERR getStreamCmdResponse stream error: Socket /var/lib/zoneminder/sock/zms-025527s.sock does not exist. This file is created by zms, and since it does not exist, either zms did not run, or zms exited early. Please check your zms logs and ensure that CGI is enabled in apache and check that the PATH_ZMS is set correctly. Make sure that ZM is actually recording. If you are trying to view a live stream and the capture process (zmc) is not running then zms will exit. Please go to http://zoneminder.readthedocs.io/en/latest/faq.html#why-can-t-i-see-streamed-images-when-i-can-see-stills-in-the-zone-window-etc for more information. - checkStreamForErrors() ?view=watch
25/10/2018 15:21 zms_m5 14711 ERR Terminating, last frame sent time 10.483479 secs more than maximum of 10.000000 zm_monitorstream.cpp 713
25/10/2018 15:21 zmc_m5 14700 INF Priming capture from rtsp://admin:@192.168.1.54:554 zm_ffmpeg_camera.cpp 163
25/10/2018 15:21 zmc_m5 14700 INF Starting Capture version 1.32.2 zmc.cpp 223
