PTZ control for FLOUREON IPCAM SD17W
zorzini
Post by zorzini » Fri Oct 12, 2018 4:38 pm
Hey,
I i'm running ZoneMinder with Floureon SD17W and the monitor works correctly.
Now i will use the PTZ feature via ZoneMinder but I'm a little bit confused about the items in Control tab.
Anyone used this PTZ IPCAM or knows an equivalent other brand and use the PTZ control in ZM ?
Thanks for your suggestions.
security_dude
Re: PTZ control for FLOUREON IPCAM SD17W
Post by security_dude » Sun Oct 14, 2018 7:41 am
Try reading this https://zoneminder.readthedocs.io/en/st ... ntrol.html
Also you maybe able to control it using onvif ptz commands. I read that the existing onvif script in zoneminder maybe broken so maybe check the forums for a working copy. Here is a place to start with viewtopic.php?t=25138
Good luck.
Users browsing this forum: No registered users and 5 guests
