I have a Dahua camera with the main stream (high res) at 5FPS and substream at 10FPS like so
Modect is enabled on the Substream like so,
and the MainStream is setup as NoDect and linked to the Substream,
With the above setup I am getting more events in the Substream and less events in the MainStream. Is it because the FPS is different between the two streams or is there some other issue?
