Need Help with Command Line Script
jsylvia007
Post by jsylvia007 »
I have a script (below) that I use to get the status of all the cameras and grep values to insert into Zabbix.
The script has stopped working in 1.32.1, and I believe it has to do with this line:
my $monitorState = zmGetMonitorState($monitor);
I did a print to see what was contained in $monitor, and the value at that point in the script is:
HASH(0x56072d4282f0)HASH(0x56072d428bc0)HASH(0x56072d42a8f8)HASH(0x56072d42d9d0)HASH(0x56072d42e2a0)HASH(0x56072d4319d8)HASH(0x56072d4322a8)HASH(0x56072d4352f0)HASH(0x56072d435bc0)HASH(0x56072d438128)HASH(0x56072d4389f8)HASH(0x56072d43bc70)HASH(0x56072d43f178)HASH(0x56072d43fa48)
I'm not sure what that all means... I'm hoping that someone who understands the codebase can tell me what's changed.
Executing the script results in these outputs:
2018-10-07 14:55:32	getstate	10085	ERR	Can't read from mapped memory for monitor '1', gone away?	getstate.pl
2018-10-07 14:55:32	getstate	10085	ERR	Unable to read 'shared_data:state' from memory for monitor 1	getstate.pl
2018-10-07 14:55:31	getstate	10069	ERR	Can't read from mapped memory for monitor '1', gone away?	getstate.pl
2018-10-07 14:55:31	getstate	10069	ERR	Unable to read 'shared_data:state' from memory for monitor 1	getstate.pl
2018-10-07 14:55:30	getstate	10053	ERR	Can't read from mapped memory for monitor '1', gone away?	getstate.pl
2018-10-07 14:55:30	getstate	10053	ERR	Unable to read 'shared_data:state' from memory for monitor 1	getstate.pl
#!/usr/bin/env perl
use strict;
use warnings;
use ZoneMinder;
use Switch;
$| = 1;
my @monitors;
my $dbh = zmDbConnect();
my $sql = "SELECT * FROM Monitors";
while ( my $monitor = $sth->fetchrow_hashref() ) {
    push( @monitors, $monitor );
while (1) {
        foreach my $monitor (@monitors) {
                printStateSimple($monitor->{Id}, $monitor->{Name}, $monitorState);
#        sleep 1;
         exit
sub printState {
        my ($monitor_id, $monitor_name, $state) = @_;
        my $time = localtime();
        switch ($state) {
                case 0 { print "$time - $monitor_name:\t Idle!\n" }
                case 1 { print "$time - $monitor_name:\t Prealarm!\n" }
                case 2 { print "$time - $monitor_name:\t Alarm!\n" }
                case 3 { print "$time - $monitor_name:\t Alert!\n" }
sub printStateSimple {
        switch ($state) {
                case 0 { print "$monitor_name ($monitor_id):\t Idle\n" }
                case 1 { print "$monitor_name ($monitor_id):\t Prealarm\n" }
                case 2 { print "$monitor_name ($monitor_id):\t Alarm\n" }
                case 3 { print "$monitor_name ($monitor_id):\t Alert\n" }
