Upload won't work
sagitt
Upload won't work
Post by sagitt » Wed Sep 19, 2018 4:54 pm
I'm not able to upload on my sftp server
works very well with olter version
i found this error in logs: Unknown function call Filter->AutoUpload from /usr/share/zoneminder/www/index.php:254
finter are correctly setted and server works.
Re: Upload won't work
Post by iconnor » Thu Sep 20, 2018 5:38 pm
Just pushed the fix to master. Packages will build in a bit.
sagitt
Post by sagitt » Fri Sep 21, 2018 5:25 pm
upgraded but still not working (upload)
anyway
i've some other problems
you can see the post "more problems"
viewtopic.php?f=38&t=27535
and zmtrigger works very bad.... sometimes works fine, others stop my record after 6-10 seconds...
my trigger interface works very well with older version.
the way to restore it to working after the problem is terminate zmtrigger.pl and restart system or reinstall zoneminder.
sagitt
Post by sagitt » Fri Sep 28, 2018 4:31 pm
Still not working...........
