Page 1 of 1
Bit confused by the Ubuntu stable PPA situation and 1.32.x
Posted: Sun Sep 16, 2018 4:14 pm
by c128
Noticed that the new installation instructions reference the stable PPA to install 1.32.x, from where I currently have 1.30.4 installed i.e.
https://launchpad.net/~iconnor/+archive ... zoneminder . However, 1.32.x packages don't seem to be published there, although there are specific builds that have been made but that aren't picked up by through a normal upgrade e.g.
https://launchpad.net/~iconnor/+archive ... d/15453489 .
Are we "safe" to use those builds, or is it just a matter of being patient for a "formal" 1.32.x build to be published within the stable PPA?
Thanks.
Re: Bit confused by the Ubuntu stable PPA situation and 1.32.x
Posted: Sun Sep 16, 2018 5:17 pm
by sagitt
for me 1.32 upgrade (and fresh install too) won't work.
Posted: Sun Sep 16, 2018 7:20 pm
by bbunge
I've upgraded my test machine a couple of times from Ubuntu 16.04 ZM 1.30.4 to ZM 1.32.0 successfully. Did it the other day when 1.32.0 hit the PPA and again just a couple of minutes ago using the ppa zoneminder-master. Had about 50 GIG of events from running mocord overnight and preliminary testing shows the box to be working OK for the features I've tested.
I've seen something about needing additional grants for the zm user on the database server. Doing a "grant all" should catch it on a new install but the grants should be OK on an upgrade. The 1.30.4 install has an entry in the my.cnf (sql_mode = NO_ENGINE_SUBSTITUTION) which may not be needed for 1.32.0 as the database was supposed to be fixed. Leaving it in the file for now on my test machine.
If you have a system that does not work you may be able to get it going by switching to the zoneminder-master PPA and forcing a reinstall.
Oh, reboot the server after an upgrade.
Posted: Sun Sep 16, 2018 9:28 pm
by c128
bbunge wrote: ↑Sun Sep 16, 2018 7:20 pm
Not totally clear on what you're saying there - when you initial say "did it the other day when 1.32.0 hit the PPA" do you mean the
stable PPA, or both times from
zoneminder-master?
I know it's available from the master PPA, but I've personally only ever used the stable PPA for the official releases, and like to stick to it, so was just wondering whether there was a reason it wasn't installable from there at the moment.
Posted: Sun Sep 16, 2018 10:30 pm
by bbunge
c128 wrote: ↑Sun Sep 16, 2018 9:28 pm
zoneminder-master?
First time when 1.32.0 was on the zoneminder ppa and today from the zoneminder-master ppa. It is not on the zoneminder ppa because of some reported issues (and I'm not sure just what they were). I did the upgrade from the zoneminder-master ppa to see what would happen with a machine with a couple of GIG of events. Most of the time I do a test upgrade there are not many events as I have images of systems that I clone so I do not have to run full installs (with a USB3 external drive with Clonezilla I can image Ubuntu with Zoneminder installed in about 4 minutes). I do not advocate using an install from a development PPA for a production system but you may be able to recover a failed system, just maybe...
Posted: Mon Sep 17, 2018 8:05 am
by c128
bbunge wrote: ↑Sun Sep 16, 2018 10:30 pm
Ah, I understand - wasn't aware there were some known issues at the moment.
Thanks!
Posted: Thu Sep 20, 2018 5:10 pm
by sagitt
where is the old zoneminder ppa version?
No version for xenial in the stable ppa
i've a lot of problems with 1.32, please upload again the old version.
- Schermata 2018-09-20 alle 19.09.19.png (47.11 KiB) Viewed 339579 times
Posted: Thu Sep 20, 2018 5:15 pm
by rockedge
Posted: Thu Sep 20, 2018 5:30 pm
by wh33lz
sagitt wrote: ↑Thu Sep 20, 2018 5:10 pm
I managed to reinstall 1.30.4, after purging 1.32,
I removed 1.32 (for the time being...) using these commands
WARNING ! these commands will remove almost all Zoneminder files, dependencies, configurations, past events and the Zoneminder database. You will be starting from scratch. So backup what ever you want to keep. You have been WARNED!.
sudo apt-get purge --auto-remove zoneminder
sudo mysqladmin --defaults-file=/etc/mysql/debian.cnf -f drop zm
Use the following instructions to re-install 1.30
Posted: Thu Sep 20, 2018 5:34 pm
by iconnor
People get surprised when they have the stable ppa and suddenly get upgraded. So in future I will create a new ppa for each version. Unfortunately it's a lot of work, so it's not done yet.
The new ppa will likely be called ppa:iconnor/zoneminder-1.32
At the moment the master ppa is as stable as it gets.
Posted: Thu Sep 20, 2018 6:41 pm
by wh33lz
iconnor wrote: ↑Thu Sep 20, 2018 5:34 pm
Really do appreciate all your work.
Proprietary software is such crap when compared to Zoneminder.
Is is possible to get a list of the different PPA's ?
I am confused since
https://wiki.zoneminder.com/Common_Issu ... PA_version states "Master" is Beta software.
Posted: Thu Sep 20, 2018 7:41 pm
by bbunge
Well, things change and the zoneminder-master and zoneminder-storageareas ppa's were and still are development areas. It is not wrong to call development software BETA! If and when this changes I'll do my best to get the WIKI area's updated. Yes, things are a bit confused right now and it will take time to get it sorted out. There are still 1.30.4 installs for Xenial (64 bit only) and Bionic (32 and 64 bit). Best if you need help with 1.30.4 to use the 1.30.x forum area.
Posted: Tue Sep 25, 2018 6:21 pm
by sagitt
so what is the right command to install zoneminder 1.30.4 with the standard ppa?
Posted: Wed Sep 26, 2018 6:22 pm
by Pedulla
sagitt wrote: ↑Tue Sep 25, 2018 6:21 pm
This is the 1.32 forum... Check out the 1.30 forum.
viewforum.php?f=36
