job for zoneminder.service failed...
fontes31
Post by fontes31 » Sun Sep 16, 2018 1:55 pm
I tried to install zoneminder 1.32 on my ubuntu 16.04 server, but i have this error.
i try to open it on http://myip/zm and i have could not open config file.
I run service zoneminder start and i have the error - "Job for zoneminder.service failed because the control process exited with error code. See "systemctl status zoneminder.service" and "journalctl -xe" for details"
I run journalctl -xe and i have this (i followed the wiki 1.32 easy install"
-- Unit zoneminder.service has begun starting up.
Sep 16 14:47:55 Media zmpkg.pl[13881]: DBI connect('database=zm;host=localhost','fontes31',...) failed: Access den
Sep 16 14:47:55 Media zmpkg.pl[13881]: Can't connect to db at /usr/share/perl5/ZoneMinder/Config.pm line 119.
Sep 16 14:47:55 Media zmpkg.pl[13881]: BEGIN failed--compilation aborted at /usr/share/perl5/ZoneMinder/Config.pm
Sep 16 14:47:55 Media zmpkg.pl[13881]: Compilation failed in require at /usr/share/perl5/ZoneMinder.pm line 33.
Sep 16 14:47:55 Media zmpkg.pl[13881]: BEGIN failed--compilation aborted at /usr/share/perl5/ZoneMinder.pm line 33
Sep 16 14:47:55 Media zmpkg.pl[13881]: Compilation failed in require at /usr/bin/zmpkg.pl line 48.
Sep 16 14:47:55 Media zmpkg.pl[13881]: BEGIN failed--compilation aborted at /usr/bin/zmpkg.pl line 48.
Sep 16 14:47:55 Media systemd[1]: zoneminder.service: Control process exited, code=exited status=255
Sep 16 14:47:55 Media systemd[1]: Failed to start ZoneMinder CCTV recording and surveillance system.
-- Subject: Unit zoneminder.service has failed
-- Defined-By: systemd
-- Support: http://lists.freedesktop.org/mailman/li ... temd-devel
-- Unit zoneminder.service has failed.
-- The result is failed.
Sep 16 14:47:55 Media systemd[1]: zoneminder.service: Unit entered failed state.
Sep 16 14:47:55 Media systemd[1]: zoneminder.service: Failed with result 'exit-code'.
sagitt
Re: job for zoneminder.service failed...
Post by sagitt » Sun Sep 16, 2018 5:18 pm
same
with fresh install or upgrade.
fontes31
Post by fontes31 » Sun Sep 16, 2018 6:09 pm
how can i upgrade?
sagitt
Post by sagitt » Sun Sep 16, 2018 6:21 pm
see my post "upgrade error"
i'm waiting iconnor solution
fontes31
Post by fontes31 » Sun Sep 16, 2018 7:06 pm
I tried to do - sudo zmupdate.pl
but i have this error:
Warning, overriding installed ./zm.conf file with local copy
DBI connect('database=zm;host=localhost','',...) failed: Unknown database 'zm' at /usr/share/perl5/ZoneMinder/Config.pm line 96.
BEGIN failed--compilation aborted at /usr/share/perl5/ZoneMinder/Config.pm line 119.
Compilation failed in require at /usr/bin/zmupdate.pl line 71.
BEGIN failed--compilation aborted at /usr/bin/zmupdate.pl line 71.
sagitt
Post by sagitt » Sun Sep 16, 2018 9:18 pm
my surveillance is offline from 2 days for this version!
i hope a fix soon.
fontes31
Post by fontes31 » Mon Sep 17, 2018 7:58 pm
tried 1.29, 1.30 versions and allways the same error
Users browsing this forum: mikb and 4 guests
