Zoneminder installation problem on Pi2 Deb
tracks
Post by tracks »
Hi
Need some help anyone that installed Zoneminder on Pi2 , php7 Debian
Is there a version 1.31 for Raspberry Debian?
I see its looking for php5 below
regards
root@raspberrypi:/home/pi# apt install zoneminder vlc-plugin-base php7.0-gd
Reading package lists... Done
Building dependency tree
Reading state information... Done
php7.0-gd is already the newest version (7.0.27-0+deb9u1).
php7.0-gd set to manually installed.
Some packages could not be installed. This may mean that you have
requested an impossible situation or if you are using the unstable
distribution that some required packages have not yet been created
or been moved out of Incoming.
The following information may help to resolve the situation:
The following packages have unmet dependencies:
vlc-plugin-base : Depends: libavcodec57 (>= 10:3.3.7) but it is not going to be installed
Depends: libavformat57 (>= 10:3.3.7) but it is not going to be installed
Depends: libavutil55 (>= 10:3.3.7) but 7:3.2.10-1~deb9u1~bpo8+1 is to be installed
Depends: libchromaprint1 but it is not going to be installed
Depends: libpostproc54 (>= 10:3.3.7) but 7:3.2.10-1~deb9u1~bpo8+1 is to be installed
Depends: libpulse0 (>= 0.99.4) but it is not going to be installed
Depends: libswscale4 (>= 10:3.3.7) but 7:3.2.10-1~deb9u1~bpo8+1 is to be installed
Recommends: xdg-utils but it is not going to be installed
zoneminder : Depends: libavcodec56 (>= 6:11~beta1) but it is not installable or
libavcodec-extra-56 (>= 6:11.4) but it is not installable
Depends: libavformat56 (>= 6:11~beta1) but it is not installable
Depends: libavutil54 (>= 6:11~beta1) but it is not installable
Depends: libmysqlclient18 (>= 5.5.24+dfsg-1) but it is not installable
Depends: libswscale3 (>= 6:11~beta1) but it is not installable
Depends: php5-mysql but it is not installable
Recommends: libapache2-mod-php5 but it is not installable or
php5-fpm but it is not installable
Recommends: zoneminder-doc (>= 1.29.0+dfsg-1~bpo8+1) but it is not going to be installed
Recommends: ffmpeg but it is not going to be installed or
libav-tools but it is not going to be installed
E: Unable to correct problems, you have held broken packages.
