Layout messed up after 1.31.44 update
I just updated to 1.31.44 from .42 and the skin is doing weird things and when I click on montage it goes to a white screen and buttons missing. Running Ubuntu 16.04.3. Zmninja still works fine though right now.
- 1.jpg (324.61 KiB) Viewed 21833 times
- 2.jpg (445.53 KiB) Viewed 21833 times
Re: Layout messed up after 1.31.44 update
There are additional apache config updates required.
Please see the following gist for an example
https://gist.github.com/connortechnolog ... 54ee45067e
ok, I did that and it fixed all that but I can't see anything when I open a cam to watch or open montage, its just blank and I right click and view image and it gives this "requested URL /zm/cgi-bin/nph-zms was not found on this server." and log says cannot find sock file.
double check the configuration of the PATH for the /cgi-bin/....
Is this for 1.34.44 master since 1.34.44 storageareas is in a file
Is Master include storageareas ?
Sometimes it gets confusing what release when there is the same 1.34.xx they are talking about
Jimmy
Linux Mint 21 Cinnamon Mariadb 10.6.x using Master 1.37.x latest always
1.30.4 Stable
1.31.1 Master (there is also 1.31.43 in the Master directory but not sure if any merge from storageareas branch occurred)
1.31.44 Storageareas
all those from the iconner PPA https://launchpad.net/~iconnor
all the versions after 1.30.4 have the Options->Paths now in a config file in /etc/zm
and custom changes that will not be over-written during update is under /etc/zm/conf.d ( i.e. /etc/zm/conf.d/zmcustom.conf )
After that update the layout actually got weird. I followed the guideline of opening the zoneminder.conf into conf-available and erasing all the contents and inserting the content of the gist Iconnor passed on correcting line 58 (indentation error). After changing the zoneminder.conf the layout was OK, but the images do not appear and the error log appears in PATH_ZMS. If I open restore the zoneminder.conf backup the layout gets strange again, but the cameras reappeared without the PATH_ZMS error. I believe there is some error in the gist script that is messing with PATH_ZMS.
Mine does the exact same as this. ^
Same issue ^
perhaps this may help : viewtopic.php?p=105647#p105647
Okay, figured it out..
Needed to reorder the code as shown below:
Alias /zm /usr/share/zoneminder/www needs to be defined later..
/etc/apache2/conf-available/zoneminder.conf:
<Directory "/var/cache/zoneminder/cache">
AllowOverride None
<IfModule mod_authz_core.c>
# Apache 2.4
Require all granted
</IfModule>
<IfModule !mod_authz_core.c>
# Apache 2.2
Order deny,allow
Allow from all
</IfModule>
</Directory>
ScriptAlias /zm/cgi-bin/ /usr/lib/zoneminder/cgi-bin/
ScriptAlias /cgi-bin "/usr/lib/zoneminder/cgi-bin"
AllowOverride All
# Apache 2.4
Require all granted
</IfModule>
# Apache 2.2
Order deny,allow
Allow from all
</IfModule>
</Directory>
Alias /zm "/usr/share/zoneminder/www"
<Directory "/usr/share/zoneminder/www">
AllowOverride All
# Apache 2.4
Require all granted
</IfModule>
# Apache 2.2
Order deny,allow
Allow from all
</IfModule>
</Directory>
AllowOverride None
# Apache 2.4
Require all granted
</IfModule>
# Apache 2.2
Order deny,allow
Allow from all
</IfModule>
</Directory>
AllowOverride All
# Apache 2.4
Require all granted
</IfModule>
# Apache 2.2
Order deny,allow
Allow from all
</IfModule>
</Directory>
AllowOverride All
# Apache 2.4
Require all granted
</IfModule>
# Apache 2.2
Order deny,allow
Allow from all
</IfModule>
</Directory>
then just reload the conf and restart apache:
Here's what i did (maybe overkill, but works):
a2dismod cgi; a2enmod cgi; a2disconf zoneminder; a2enconf zoneminder; service apache2 reload; service apache2 restart
Perfect, after changing the reversing zoneminder.conf as per above orientation the system ran perfectly with the correct layout and all the functions working.
One note, if we do a clean installation direct to StorageAreas I no longer need to mess with PATH_ZMS. There is no longer any need to change the directory.
At that point my instance is running smoothly, recording with h264 passthroug.
But in the logs I found something I did not understand either.
It appears that I need to restart, I restart zoneminder or even Ubuntu Server and the message continues.
juanmoura wrote: ↑Thu May 03, 2018 12:46 pm Perfect, after changing the reversing zoneminder.conf as per above orientation the system ran perfectly with the correct layout and all the functions working.
I am having the same in my logs. Does your monitor restart every 10 minutes aswell?
