Page 1 of 4
(Solved)API not working with PHP 7.2 and Bionic 18.04
Posted: Wed Mar 14, 2018 5:19 pm
by rockedge
Installed ZM 1.31.39 on a Puppy Linux Bionic (Ubuntu 18.04 binaries and is compatible)
Hiawatha 10.7
PHP 7.2
mariadb
and ZM is working mostly. The API is failing due to Cakewalk having a name defintion of objects problem due to changes in definitions with PHP 7.2
an example of the errors. Using /zm-server/zm/api/host/getVersion.json returns nothing but a blank page.
192.168.0.6|Tue 13 Mar 2018 18:09:01 -0400|/usr/share/zoneminder/www/api/app/webroot/index.php|PHP Fatal error: Cannot use 'Object' as class name as it is reserved in /usr/share/zoneminder/www/api/lib/Cake/Core/Object.php on line 30
192.168.0.6|Tue 13 Mar 2018 18:09:01 -0400|/usr/share/zoneminder/www/api/app/webroot/index.php|PHP Fatal error: Class 'Object' not found in /usr/share/zoneminder/www/api/lib/Cake/Controller/Controller.php on line 58
192.168.0.6|Tue 13 Mar 2018 18:09:01 -0400|/usr/share/zoneminder/www/api/app/webroot/index.php|CGI returned 500 Internal Error
So the changes in PHP 7.2 cause the API not to work.
Re: API not working with PHP 7.2
Posted: Wed Mar 14, 2018 9:06 pm
by bbunge
Same problem with Ubuntu-Server 18.04 installing the .deb per the WIKI install for 17.10. Have successfully upgraded Ubuntu 16.04 with ZM 1.30.4 to Ubuntu-Server development version 18.04 and everything, including API, worked. Am in process of doing it again to get the steps I did written down. Stay tuned...
BTW - Zoneminder has been removed from Ubuntu 18.04.
Posted: Wed Mar 14, 2018 10:09 pm
by knight-of-ni
Ah, yep. This appears to be affecting multiple projects:
https://www.google.com/search?q=PHP+Fat ... e&ie=UTF-8
The knee-jerk fix would be to simply change the name of the object to something else, but perhaps we ought to look into what it would take to upgrade the version of cakephp instead. That of course, could be more work that it's worth, but It is worth looking into.
Posted: Wed Mar 14, 2018 11:17 pm
by knight-of-ni
So this turns out to be a known issue with cakephp 2.x versions which was fixed in 2.10.7:
https://github.com/cakephp/cakephp/releases/tag/2.10.7
Posted: Thu Mar 15, 2018 2:06 pm
by rockedge
I replaced the cakephp version to 2.10.7. Then taking some of the controllers code and moving some stuff back and forth to the point of who knows what I did....I have reached a point where only 1 error is appearing and at least something is showing after entering /zm-server/zm/api/host/getVersion.json....
Fatal error: Class 'CakeObject' not found in /usr/share/zoneminder/www/api/lib/Cake/Controller/Controller.php on line 58
Posted: Thu Mar 15, 2018 8:09 pm
by bbunge
Have upgraded to Cakephp 2.10.7 and can get 1.30.4 and 1.31.1 to work on Ubuntu server 18.04 (dtd 15MAR18) but no luck with the API.
Must be the doom of The Ides of March...
Posted: Fri Mar 16, 2018 3:29 pm
by rockedge
I have the same....both 1.30.4 and 1.31.39 working.....mostly working on Puppy Linux Bionic (18.04) PHP 7.2....but the API refuses to be fixed... I have it to the point where cakephp was displaying a page but still named some (warnings) errors...I felt really close to getting it going then one more small modification and back to square 1..... but I am still going at it ... the page displaying was a start and looked good...I will see if I can get back there again.
Posted: Fri Mar 16, 2018 5:18 pm
by bbunge
After a morning of retail therapy am updating my Ubuntu 18.04 images. Noticed PHP7.2 got some upgrades today.
Found a copy of zoneminder_1.30.4+dfsg-2_amd64.deb which may be the version that was on the earlier 18.04. Plan to try to install that. Have had problems getting the 1.31.1 from the PPA master to finish installing and will not create database.
Posted: Sat Mar 17, 2018 12:14 am
by bbunge
With CakePHP 2.10.7 installed in /var/www/html/cake and no errors showing on the cake test screen I've repackaged zoneminder_1.30.4+dfsg-2_amd64.deb and removed the requirement for cakephp and zoneminder-docs.
Installed php-gd and ffmpeg with apt before installing repackaged zoneminder with apt.
Followed my interim procedure on the WIKI except used php7.2:
Zoneminder runs and captures events. Still no api when tested. Did notice a file generated called '/etc/zm/core.php' Checked through it to see if there was a setting to point to my cake install. Np luck....yet
Suggestions?
Posted: Sat Mar 17, 2018 1:29 pm
by knight-of-ni
hmmmm..... /etc/zm/core.php - that doesn't look like its in the right place. Unless someone has made a change I am not aware of, there should only be *.conf files there.
In order for ZoneMinder to work with the version of cakephp we have currently, certain files had to be modified by us. If I recall, all these files live here:
https://github.com/ZoneMinder/zoneminde ... app/Config
So for anyone who is attempting to upgrade the version of cakephp on their system, the first thing that comes to mind is whether you took the zoneminder specific information out of those files and properly blended them into the new files. It is entirely possible that certain variable names have changed too.
Our cakephp folder also has several .htaccess files hidden in several places. You need to make sure those are still there, and in the right spot. On a side note, I have gotten rid of these sneaky files for redhat builds and have chosen to centralize this into the master apache config file. Look here:
https://github.com/ZoneMinder/zoneminde ... onf.in#L47
The folder names in each apache directive tell you where to look for the .htaccess files. If this turns out to be the issue, perhaps this would be a good time to centralize these for debian builds too.
If you have already done these steps, then the next thing we need is data. I don't know what you mean when you say "no api". What do you see when you manually type in an api url into your browser? Blank screen? http 404? Also, there is a cake error log. Have you looked at that? The location of the errorlog is one of the things we modified. Depending on the state of you system at the moment, the cake errorlog might be under /var/log/zoneminder. in zoneminder's temp folder, or the cakephp tmp folder. If the commands are indeed getting to cakephp, then it is most certainly writing error messages to that file.
Posted: Sat Mar 17, 2018 2:35 pm
by rockedge
I started fresh with Bionic 18.04 and installed Hiawatha 10.7 PHP 7.2 mariadb zoneminder 1.31.39 (storageareas).
ZM runs and streams also will detect motion and create events which can be viewed. Some other small things I noticed with video and export are so-so but that comes another time.
I am using now cakephp 2.10.7 with crud-c3976f1478c681b0bbc132ec3a3e82c3984eeed5. and I did also get a cakephp page but some warnings.Now after some more modification this is what I am running into
Fatal error: Uncaught Error: Class 'RelatedModelsListener' not found in /usr/share/zoneminder/www/api/app/Plugin/Crud/Controller/Component/CrudComponent.php:752
Stack trace:
#0 /usr/share/zoneminder/www/api/app/Plugin/Crud/Controller/Component/CrudComponent.php(728): CrudComponent->_loadListener('RelatedModels')
#1 /usr/share/zoneminder/www/api/app/Plugin/Crud/Controller/Component/CrudComponent.php(169):
CrudComponent->_loadListeners()
#2 /usr/share/zoneminder/www/api/lib/Cake/Utility/ObjectCollection.php(128):
CrudComponent->initialize(Object(CakeErrorController))
#3 /usr/share/zoneminder/www/api/lib/Cake/Event/CakeEventManager.php(243):
ObjectCollection->trigger('initialize')
#4 /usr/share/zoneminder/www/api/lib/Cake/Controller/Controller.php(677):
CakeEventManager->dispatch(Object(CakeEvent))
#5 /usr/share/zoneminder/www/api/lib/Cake/Error/ExceptionRenderer.php(158):
Controller->startupProcess()
#6 /usr/share/zoneminder/www/api/lib/Cake/Error/ExceptionRenderer.php(95):
ExceptionRenderer->_getController(Object(FatalErro in /usr/share/zoneminder/www/api/app/Plugin/Crud/Controller/Component/CrudComponent.php on line 752
I also tried cakephp 3.5.13 and crud-master to see what happened... same errors. I am adding the /api/apps/Controllers content from a working API from Artful 17.10 ZM install which I got the API to work.
Also adding the /api/apps/Models content from the same source.
Posted: Sat Mar 17, 2018 3:27 pm
by bbunge
Posted: Sat Mar 17, 2018 4:25 pm
by rockedge
are you seeing in the error.log this? ->
the Class 'RelatedModelsListener' not found error above I fixed sometime yesterday but for the life of me I can not remember what I did but I got past this and received a cakePHP error page with some warnings of undefined zoneminder config variables
Posted: Sat Mar 17, 2018 6:16 pm
by rockedge
this is the stage before adding the controllers and models
- api_error1.png (101.58 KiB) Viewed 50826 times
and this error after copying the /app/Controllers and /app/Models from a working API in a ZM 1.31.39 Artful 17.10
Fatal error: Class 'Cake\Controller\Component' not found in /usr/share/zoneminder/www/api/app/Plugin/Crud/Controller/Component/CrudComponent.php on line 25
Posted: Sat Mar 17, 2018 6:30 pm
by rockedge
and now :
127.0.0.1|Sat 17 Mar 2018 14:28:11 -0400|/usr/share/zoneminder/www/api/app/webroot/index.php|PHP Fatal error: Trait 'CrudControllerTrait' not found in /usr/share/zoneminder/www/api/app/Controller/AppController.php on line 34
127.0.0.1|Sat 17 Mar 2018 14:28:11 -0400|/usr/share/zoneminder/www/api/app/webroot/index.php|PHP Fatal error: Class 'Cake\Controller\Component' not found in /usr/share/zoneminder/www/api/app/Plugin/Crud/Controller/Component/CrudComponent.php on line 25
127.0.0.1|Sat 17 Mar 2018 14:28:11 -0400|/usr/share/zoneminder/www/api/app/webroot/index.php|CGI returned 500 Internal Error
