API changed in .23 or broken?
geraldbrandt
Post by geraldbrandt »
I use the API to change a couple of cameras from Modect to Monitor and back at specific times during the day. It was working in .20, but doesn't work anymore.
Has there been a change, or is there something I can trace to help?
/usr/bin/curl  -XPOST http://localhost/zm/api/monitors/3.json -d "Monitor[Function]=Modect&Monitor[Enabled]=1"
{"message":"Error"}
Gerald
geraldbrandt
Re: API changed in .23 or broken?
Still bad in .24
Any help I can give in tracking this down?
weird... I use this heavily. you can look in /var/log/zm/cake*.log
geraldbrandt
Here it is:
2018-01-19 08:15:02 Notice: Notice (8): Use of undefined constant ZM_SERVER_ID - assumed 'ZM_SERVER_ID' in [/usr
Trace:
MonitorsController::edit() - APP/Controller/MonitorsController.php, line 172
ReflectionMethod::invokeArgs() - [internal], line ??
Controller::invokeAction() - CORE/Cake/Controller/Controller.php, line 491
AppController::invokeAction() - APP/Plugin/Crud/Lib/CrudControllerTrait.php, line 31
Dispatcher::_invoke() - CORE/Cake/Routing/Dispatcher.php, line 193
Dispatcher::dispatch() - CORE/Cake/Routing/Dispatcher.php, line 167
[main] - APP/webroot/index.php, line 107
Ah.. I understand the problem. I'll push a fixed version tonight.
geraldbrandt
Awesome, thank you!
geraldbrandt
Still no go, but this may be due to a failed(ish) upgrade (in another post)
2018-01-20 12:06:52 Error: [ParseError] syntax error, unexpected ']', expecting ',' or ')'
Request URL: /zm/api/monitors/3.json
Stack Trace:
#0 [internal function]: App::load('MonitorsControl...')
#1 [internal function]: spl_autoload_call('MonitorsControl...')
#2 /usr/share/zoneminder/www/api/lib/Cake/Routing/Dispatcher.php(266): class_exists('MonitorsControl...')
#3 /usr/share/zoneminder/www/api/lib/Cake/Routing/Dispatcher.php(235): Dispatcher->_loadController(Object(CakeRequest))
#4 /usr/share/zoneminder/www/api/lib/Cake/Routing/Dispatcher.php(158): Dispatcher->_getController(Object(CakeRequest), Object(CakeResponse))
#5 /usr/share/zoneminder/www/api/app/webroot/index.php(107): Dispatcher->dispatch(Object(CakeRequest), Object(CakeResponse))
#6 {main}
Latest packages should fix this.
geraldbrandt
Re: API changed in .23 or broken? Still .28
I'm still having issues in .28:
/usr/bin/curl  -XPOST http://localhost/zm/api/monitors/4.json -d "Monitor[Function]=Modect&Monitor[Enabled]=1"
{"message":"Error"}
There was nothing written to any of the cake logs.
Gerald
geraldbrandt
Okay, .29 changed it up again!
root@zoneminder2:~# /usr/bin/curl  -XPOST http://localhost/zm/api/monitors/3.json -d "Monitor[Function]=Monitor&Monitor[Enabled]=1"
{"message":"Error Array\n(\n    [Function] => Array\n        (\n            [0] => Please choose one of the following values : None, Monitor, Modect, Record, Mocord, Nodect\n            [1] => Please choose one of the following values : None, Monitor, Modect, Record, Mocord, Nodect\n        )\n\n)\n"}
The cake logfile is empty (has been since the 20th), so maybe logging got turned off somehow?
Gerald
Uh... .29 was supposed to fix it... where are you getting your packages from?
Sigh.. I hate git submodules. New packages building.
geraldbrandt
iconnor wrote: Tue Jan 30, 2018 2:19 am Uh... .29 was supposed to fix it... where are you getting your packages from?
From your repo.deb http://ppa.launchpad.net/iconnor/zonemi ... eas/ubuntu xenial main
Gerald
geraldbrandt
iconnor wrote: Tue Jan 30, 2018 2:26 am Sigh.. I hate git submodules. New packages building.
No worries. I know this is alpha/beta code. I'm using it hoping my testing and feedback will help.
Gerald
I feel like I'm quashing some of the really hard long-standing wierd bugs. I'm going to lay off any new features for a while and just put polish on it.
Thanks for your patience.
