How can i update from 1.31.1 (master) to 1.31.18 (storageareas)
juanmoura
Post by juanmoura » Wed Jan 03, 2018 5:06 pm
Hello guys, i need a little help.
Initially I installed 1.30.1, then I removed the stable repository and inserted the master repository, ran apt-get update and then upgrade. The system upgraded to 1.31.1 perfectly. Then I tried to upgrade to 1.31.18 (storageareas) the same way I did before, but it did not update. When I rang update and upgrade it just updated the zoneminder-doc. My question, how to upgrade it now?
Re: How can i update from 1.31.1 (master) to 1.31.18 (storageareas)
Post by bbunge » Wed Jan 03, 2018 9:29 pm
Dowmload the .deb and install it manually.
Post by iconnor » Sat Jan 06, 2018 9:28 pm
Ubuntu package builders seem to be really backed up. I have actually released 1.31.19 several days ago, but the packages are not being built.
It may just be a problem with the PPA.
In the meantime I am working to update our own repo. Which version of ubuntu are you on?
juanmoura
Post by juanmoura » Thu Jan 11, 2018 11:32 am
I found the solution. In case I was with version 1.31.1 of the PPA Master repository, I removed the MASTER repository and inserted the StorageAreas repository and gave an apt-get update && upgrade. It only updated the zoneminder-doc. I searched a lot on the internet and saw the solution. I installed aptitude and ran sudo aptitude safe-upgrade, so yes it updated everything correctly and now I'm using version 1.31.18 perfectly.
I created a script to make it easier for me, where it installs the stable version and then upgrades to the master or storageareas version, so I do not need to change the PATH of the CGI via the terminal, just via the browser when the stable is installed, making it much more easy to install system. I have installed several instances of Zoneminder, because here in the company we use it to monitor and record 8 restaurants with an average of 45 cameras per unit.
We finally managed to eliminate the paid system we had.
juanmoura
Post by juanmoura » Fri Jan 19, 2018 9:13 pm
I`m tring to install a new instance of Zoneminder. First i install from the stable repo, after i updated with the storageareas repo and i have this problem. Still here and don`t finish.
https://imgur.com/a/hM8O8
Any helps ?
geraldbrandt
Post by geraldbrandt » Sat Jan 20, 2018 1:26 am
That happened to me. I let it sit for awhile (5 + minutes) and then manually killed the two upgrade scripts running in the background. The upgrade then proceeded nicely.
juanmoura
Post by juanmoura » Sat Jan 20, 2018 9:29 am
So you kill the two process update script and run again the updater zmupdate.pl ??
Post by iconnor » Sat Jan 20, 2018 3:10 pm
Latest version shouldn't have this problem. However, if you have a lot of Events, some of the updates will take a long time.
juanmoura
Post by juanmoura » Sat Jan 20, 2018 8:16 pm
Iconnor thank you again. Upgrade sucess with the new version.
