Issue with Target Color after update 1.31.15
MrRose
Post by MrRose »
I´m sorry me again.
After doing a fresh and clean installation to version 1.31.15 and add a monitor as ffmpeg I get after pressing save the Popup
"Target colour must be set to a valid value"
Inside the monitor settings Source/Target colorspace i´m only able to set 1,3,4 as drop down list.
What i´m doing wrong?
Thanks for the help.
digital-gnome
Re: Issue with Target Color after update 1.31.15
Post by digital-gnome »
This was fixed on the 26th. Just did a fresh install in a vm and it works as it should. Not sure why yours isn't working. Maybe try
sudo apt update && sudo apt install zoneminder --reinstall
It's just a php change so you could also manually add the changes. https://github.com/connortechnology/Zon ... 362cef831b
