Can't delete filter
sil3ntcor3
Can't delete filter
Post by sil3ntcor3 »
I'm trying to delete several filters I created. When I select the filter and click the delete button, nothing happens and the filter is still present.
Thanks for any help in advance.
Re: Can't delete filter
what are the zoneminder and operating system versions ?
sil3ntcor3
Zoneminder v1.31.1 and Ubuntu 16.04.3 LTS
I had this happen with version 1.30.1 but I can not find the notes as to what it was and how to fix it. I will try to duplicate it as I am about to do a new install with the same version of ZM and Ubuntu. See if I can get ZM to fail in the same manner.
sil3ntcor3
Thanks.
are you using mariadb or mysql for the database?
sil3ntcor3
MySQL
I have not been able to duplicate the error but I used mariadb.....I will change db to MySQL and try it again!
did you add this line to the my.conf?
sil3ntcor3
That line is there but I don't recall adding it or if it was there by default.
it should be there for the newer versions of mysql. can you drop the ZM database and create a new one and import the sql file?
sil3ntcor3
So I ended up building a new VM and using mariadb and everything is working great now.
:D
