Question re copying config files from 1 machine to another
hokedigital
Post by hokedigital » Tue Jul 18, 2017 12:56 am
I'm running an i5 with 8 5mp cameras H265
Can I copy the config files from one machine to another?
ex: camera settings , etc
Thank you
Tom
PacoLM
Re: Question re copying config files from 1 machine to another
Post by PacoLM » Tue Jul 18, 2017 12:23 pm
Use phpmyadmin to backup the database, where the config and rest of options are included. Then you need to install zoneminder in the other computer and restore there the database making the opposite process.
Hope it helps,
PacoLM
mini-ITX system (6 IPCams - Ubuntu14.04 - ZM1.31.1)
hokedigital
Post by hokedigital » Tue Jul 18, 2017 11:48 pm
Thanks for that
will this work if your using MariaDB
