Page 1 of 1
Onvifprobe.php error 500
Posted: Mon Feb 25, 2019 10:03 pm
by shardick
i'm using 1.30.4 on Raspbian 9 (Raspberry Pi 3B+) and i'm getting error 500 when accessing onvifprobe.php page from monitor
Below the apache error.log:
[Mon Feb 25 22:45:10.617780 2019] [:error] [pid 25646] [client 10.0.0.24:54148] PHP Parse error: syntax error, unexpected end of file in /usr/share/zoneminder/www/skins/classic/views/onvifprobe.php on line 285, referer: http://10.0.0.35/zm/index.php?view=monitor&mid=2
Hope this helps.
Re: Onvifprobe.php error 500
Posted: Tue Feb 26, 2019 2:35 am
by bbunge
ONVIF monitor does not always work on this version of Zoneminder. Likely not just an issue with the Pi. You are better off using VLC or an Android ONVIF app.
I will fire up my Pi tomorrow to see if I get the same error.
Posted: Tue Feb 26, 2019 1:28 pm
by bbunge
Did not get an ONVIF error on my fresh Pi install.
Use a modified install procedure:
apt install php mariadb-server php-mysql libapache2-mod-php7.0 apache2
mysql_secure_installation
Edit sources.list
nano /etc/apt/sources.list
For Pi uncomment:
deb-src http://raspbian.raspberrypi.org/raspbian/ stretch main contrib non-free$
Ctrl+o Enter to save
Ctrl+x to exit
apt update
Install Zoneminder
apt install zoneminder
chmod 740 /etc/zm/zm.conf
adduser www-data video
For Pi, Create Zoneminder database in Mariadb (Note: this also creates the default Zoneminder user and permissions in MySQL)
mysqladmin -uroot -p reload
Start Zoneminder
a2enmod cgi
a2enmod rewrite
a2enconf zoneminder
Add timezone to PHP
sed -i "s/;date.timezone =/date.timezone = $(sed 's/\//\\\//' /etc/timezone)/g" /etc/php/7.0/apache2/php.ini
Restart Apache
service apache2 restart
Posted: Tue Feb 26, 2019 8:46 pm
by shardick
did the same procedure (as found on zoneminder wiki)
it seems a phone syntax error, read the phone source code but without finding the error.
Posted: Tue Feb 26, 2019 9:23 pm
by bbunge
The procedure was changed on the wiki this morning. There are differences from the STDs Debian install. Suggest you start with a fresh Raspbian and try again.
Posted: Sat Mar 02, 2019 7:41 pm
by shardick
ok, thanks (I've to enable the mail notifications :D)
how to uninstall it?
Posted: Thu Jun 06, 2019 4:23 pm
by lselinger
Has anyone else seen this? I've done a fresh install from scratch 2 times and still get this 500 error. I' following the install on the wiki from the Raspberry Pi 3B Zoneminder 1.30.4 section of This page: https://wiki.zoneminder.com/Debian_9_64 ... der_1.30.4
The error is the same as previous:
the weird thing is that file doesn't even have a line 285:
# wc -l /usr/share/zoneminder/www/skins/classic/views/onvifprobe.php
284 /usr/share/zoneminder/www/skins/classic/views/onvifprobe.php
I'm at a loss right now lol ... redoing gthe steps a few times to make sure they were done to a 'T' has not improved the situation. Is it possible there is a better guide or possibly something else I'm missing? For posterity I'm using the raspian lite image
Posted: Thu Jun 06, 2019 5:04 pm
by lselinger
Never mind now all of a sudden it's all good :shock:
Posted: Sun Jun 16, 2019 11:16 am
by mitchell_cj
People getting this message...
There are 2 stray curly braces in this file for some reason.
Edit the file and remove/comment out lines 103 & 107.
If your editor doesn't have line numbers...
find "function probeProfiles"
remove the line after "preg_match"...there are 2 of these in this function, remove both. there are a single line containing {
Posted: Tue Jun 25, 2019 6:54 am
by zm_user
Good morning,
I also have problem with
I comment lines 103 & 107 as mitchell_cj suggested but now in error.log I see
 PHP Fatal error:  Uncaught Error: Call to undefined method Logger::Debug() in /usr/share/zoneminder/www/skins/classic/views/onvifprobe.php:44\nStack trace:\n#0 /usr/share/zoneminder/www/skins/classic/views/onvifprobe.php(54): execONVIF('probe')\n#1 /usr/share/zoneminder/www/skins/classic/views/onvifprobe.php(148): probeCameras('')\n#2 /usr/share/zoneminder/www/index.php(213): require_once('/usr/share/zone...')\n#3 {main}\n  thrown in /usr/share/zoneminder/www/skins/classic/views/onvifprobe.php on line 44
Does anybody meet this error and know how to resolve it?
