Delay issue in live stream
francis3
Post by francis3 » Wed Jan 16, 2019 10:38 am
Hi all,
first post here!
Wanna say a HUGE "thank you" for the great work in this project.
I've just set up a ZoneMinder server grabbing two remote IP camera,
and I'm pretty happy with it.
The big annoyance in the current setup is a delay of about 10 seconds in the live stream view.
The setup:
** ZM cloud server:
KVM cloud server
cpu 2.0 Ghz
ram 2 GB
hdd 20 GB
Running Debian 9 stable with ZoneMinder 1.30.4
** 2 ip camera located behind a DSL line
IP cameras
2 Foscam C1 V3, with the last firmware
Video settings:
720p
512k bitrate
10 FPS
variable NO
The DSL line is managed by an OpenWrt router, and the connection to the ZM server is over an OpenVPN link.
The results of some network test:
**ZM stopped
*Ping test to one remote camera (wireless link) from the ZM server
root@zm:~# ping 192.168.1.251 -c5
PING 192.168.1.251 (192.168.1.251) 56(84) bytes of data.
64 bytes from 192.168.1.251: icmp_seq=1 ttl=63 time=31.6 ms
64 bytes from 192.168.1.251: icmp_seq=2 ttl=63 time=33.2 ms
64 bytes from 192.168.1.251: icmp_seq=3 ttl=63 time=32.8 ms
64 bytes from 192.168.1.251: icmp_seq=4 ttl=63 time=32.3 ms
64 bytes from 192.168.1.251: icmp_seq=5 ttl=63 time=31.3 ms
--- 192.168.1.251 ping statistics ---
5 packets transmitted, 5 received, 0% packet loss, time 4002ms
rtt min/avg/max/mdev = 31.318/32.268/33.206/0.705 ms
*BandWidth test to the OpenWrt Router from ZM server
root@zm:~# bwm-ng -o plain -c 1
bwm-ng v0.6.1 (delay 0.500s); input: /proc/net/dev
iface Rx Tx Total
eth0: 0.13 KB/s 1.86 KB/s 1.99 KB/s
lo: 0.00 KB/s 0.00 KB/s 0.00 KB/s
tun0: 0.00 KB/s 0.00 KB/s 0.00 KB/s
total: 0.13 KB/s 1.86 KB/s 1.99 KB/s
*Iperf3 test to the OpenWrt Router from ZM server
root@zm:~# iperf3 -c 192.168.1.1
Connecting to host 192.168.1.1, port 5201
[ 4] local 10.0.0.2 port 59710 connected to 192.168.1.1 port 5201
[ ID] Interval Transfer Bandwidth Retr Cwnd
[ 4] 0.00-1.00 sec 1.52 MBytes 12.7 Mbits/sec 0 99.2 KBytes
[ 4] 1.00-2.00 sec 444 KBytes 3.64 Mbits/sec 9 1.32 KBytes
[ 4] 2.00-3.00 sec 0.00 Bytes 0.00 bits/sec 1 1.32 KBytes
[ 4] 3.00-4.00 sec 0.00 Bytes 0.00 bits/sec 1 1.32 KBytes
[ 4] 4.00-5.00 sec 0.00 Bytes 0.00 bits/sec 0 1.32 KBytes
[ 4] 5.00-6.00 sec 0.00 Bytes 0.00 bits/sec 1 1.32 KBytes
[ 4] 6.00-7.00 sec 0.00 Bytes 0.00 bits/sec 0 1.32 KBytes
[ 4] 7.00-8.00 sec 0.00 Bytes 0.00 bits/sec 0 1.32 KBytes
[ 4] 8.00-9.00 sec 0.00 Bytes 0.00 bits/sec 0 1.32 KBytes
[ 4] 9.00-10.00 sec 0.00 Bytes 0.00 bits/sec 0 1.32 KBytes
[ 4] 0.00-10.00 sec 1.95 MBytes 1.64 Mbits/sec 12 sender
[ 4] 0.00-10.00 sec 1.58 MBytes 1.32 Mbits/sec receiver
iperf Done.
**ZM running
*Ping test
64 bytes from 192.168.1.251: icmp_seq=1 ttl=63 time=2660 ms
64 bytes from 192.168.1.251: icmp_seq=2 ttl=63 time=2647 ms
64 bytes from 192.168.1.251: icmp_seq=3 ttl=63 time=2703 ms
64 bytes from 192.168.1.251: icmp_seq=4 ttl=63 time=2699 ms
64 bytes from 192.168.1.251: icmp_seq=5 ttl=63 time=1846 ms
5 packets transmitted, 5 received, 0% packet loss, time 4032ms
rtt min/avg/max/mdev = 1846.074/2511.434/2703.809/333.402 ms, pipe 3
iface Rx Tx Total
eth0: 107.52 KB/s 7.32 KB/s 114.84 KB/s
tun0: 101.61 KB/s 2.84 KB/s 104.45 KB/s
total: 209.12 KB/s 10.16 KB/s 219.29 KB/s
[ 4] local 10.0.0.2 port 59706 connected to 192.168.1.1 port 5201
[ 4] 0.00-1.00 sec 39.7 KBytes 325 Kbits/sec 1 13.2 KBytes
[ 4] 1.00-2.00 sec 0.00 Bytes 0.00 bits/sec 0 13.2 KBytes
[ 4] 2.00-3.00 sec 27.8 KBytes 227 Kbits/sec 0 26.4 KBytes
[ 4] 3.00-4.00 sec 0.00 Bytes 0.00 bits/sec 0 26.4 KBytes
[ 4] 4.00-5.00 sec 0.00 Bytes 0.00 bits/sec 0 26.4 KBytes
[ 4] 5.00-6.00 sec 95.2 KBytes 780 Kbits/sec 0 39.7 KBytes
[ 4] 6.00-7.00 sec 0.00 Bytes 0.00 bits/sec 0 39.7 KBytes
[ 4] 7.00-8.00 sec 80.7 KBytes 661 Kbits/sec 0 58.2 KBytes
[ 4] 8.00-9.00 sec 127 KBytes 1.04 Mbits/sec 0 75.4 KBytes
[ 4] 9.00-10.00 sec 0.00 Bytes 0.00 bits/sec 0 75.4 KBytes
[ 4] 0.00-10.00 sec 370 KBytes 303 Kbits/sec 1 sender
[ 4] 0.00-10.00 sec 208 KBytes 170 Kbits/sec receiver
iperf Done.
Any suggestion to improve smoothness viewing events ad the delay in live stream?
I suspect the big problem is the slow DSL line, thinking about an upgrade to fiber line.
Regards,
francis3
Re: Delay issue in live stream
Post by bbunge » Thu Jan 17, 2019 2:38 am
Suggest setting up a server within your LAN. The "cloud server" seems a bit under powered especially if you have too high a resolution. Two GIG of RAM may not be enough especially if your camera resolution is higher than 640x480 at 5 FPS. Using a VPN to tunnel the camera traffic and recieve the video back to your LAN is not a great idea either. (Yes, you can run Zoneminder on a Raspberry Pi...one camera and maybe two) Remember half of your RAM is used for tmpfs and not available to the OS or database server.
I applaud your try! But get an old PC and use that for a server. Will work better...
francis3
Post by francis3 » Thu Jan 17, 2019 9:35 am
Thank you for your answer!
The cloud server does not seems suffering too much, btw I can add more RAM.
--- ZM RUNNING
root@zm:~# free -m
total used free shared buff/cache available
Mem: 1972 392 149 419 1430 935
Swap: 0 0 0
--- ZM STOPPED
root@zm:~# free -m
Mem: 1972 276 616 67 1079 1402
Swap: 0 0 0
About traffic back and forth, I rarely connect to ZM from inside that LAN.
I was aware of possible problems in this setup, but indeed
I'm a little surprised by the smoothness of the setup. :-)
Anyway ... gonna think about a PC in the lan!
Many thanks,
francis3
francis3
Post by francis3 » Mon Jan 21, 2019 1:44 pm
Just for the record.
I've set up ip camera and ZM source tab for the monitors
to capture at:
640*480
5 FPS
and set
Maximum FPS at 5
Still a bit of delay in live stream, but rock solid setup.
Performance has dramatically improved, and the load an the ZM cloud server has dropped near 0.
I was skeptical about downgrading resolution but, for security purposes, as suggested, is perfectly fine!
Again thx,
francis3
Users browsing this forum: No registered users and 6 guests
