Cannot View Event Video!!
qwab
Post by qwab » Fri Jan 11, 2019 9:33 am
I'm currently running ZM 1.30.4 on Ubuntu 16.04.2 LTS. I had a previous, identical installation (at least I'm pretty sure it was identical except for this problem) on a VM server running with no issues. Same cameras, same config, etc.
I built a more powerful VM server and created a new, clean VM and installed Zoneminder according to the Easy Way: Ubuntu 16.04 installation guide. Live streaming works, filters are working, defined zones and motion detection are working and events are captured and logged. The trouble is replaying recorded event video. When I try to playback it will display one frame from the event then immediately go black displaying "Time to next event = X seconds". This happens regardless of web browser and also happens in zmNinja. Still images display and I can download the event video file and it will play fine on the computer.
I've double checked the CGI paths, all seem correct. I did change the PATH_ZMS from /zm/cgi-bin/nph-zms to just /zm/cgi-bin/zms with no differences noted.
Here's the logfile for the last 10 minutes after a ZM restart. During this time I did several live views and tried to view events individually and via montage.
Help? Thanks.
dltutuapp.com/ 9apps.ooo/ https://bluestacks.vip/
2017-11-27 16:40:34.486105 zma_m4 16923 INF Pool: 6000 - Analysing at 9.90 fps zm_monitor.cpp 1296
2017-11-27 16:40:34.482165 zma_m5 16921 INF Garage: 6000 - Analysing at 9.90 fps zm_monitor.cpp 1296
2017-11-27 16:40:34.441150 zma_m3 16920 INF East Side: 6000 - Analysing at 9.90 fps zm_monitor.cpp 1296
2017-11-27 16:40:34.396806 zma_m2 16922 INF Front Door: 6000 - Analysing at 9.90 fps zm_monitor.cpp 1296
2017-11-27 16:40:32.359300 zmc_m5 16856 INF Garage: 6000 - Capturing at 9.90 fps zm_monitor.cpp 3125
2017-11-27 16:40:32.139414 zmc_m4 16844 INF Pool: 6000 - Capturing at 9.90 fps zm_monitor.cpp 3125
2017-11-27 16:40:31.952300 zmc_m3 16833 INF East Side: 6000 - Capturing at 9.90 fps zm_monitor.cpp 3125
2017-11-27 16:40:31.737957 zmc_m2 16823 INF Front Door: 6000 - Capturing at 9.90 fps zm_monitor.cpp 3125
2017-11-27 16:40:28.249101 zms 17343 INF Got signal 15 (Terminated), exiting zm_signal.cpp 40
2017-11-27 16:38:53.517958 zma_m5 16921 INF Garage: 5000 - Analysing at 9.90 fps zm_monitor.cpp 1296
2017-11-27 16:38:53.514038 zma_m4 16923 INF Pool: 5000 - Analysing at 9.90 fps zm_monitor.cpp 1296
2017-11-27 16:38:53.402160 zma_m3 16920 INF East Side: 5000 - Analysing at 9.90 fps zm_monitor.cpp 1296
2017-11-27 16:38:53.385077 zma_m2 16922 INF Front Door: 5000 - Analysing at 9.90 fps zm_monitor.cpp 1296
2017-11-27 16:38:51.327996 zmc_m5 16856 INF Garage: 5000 - Capturing at 9.90 fps zm_monitor.cpp 31
