Error Installation Pi 1 : error 1698 (28000)
Michael.e
Post by Michael.e » Mon Jan 07, 2019 8:28 am
I am sorry for my English, I am French.
I'm trying to install ZM on a Pi 1 and I'm having a problem.
- The installation of raspbian is well installed.
- I followed the installation of ZM on this page https://wiki.zoneminder.com/Raspbian
I am then:
nano .my.cnf
[customer]
user = root
password = (mysqlpass)
And when I want to create the base
mysql </usr/share/zoneminder/db/zm_create.sql
I have an error message
error 1698 (28000): denied access denied for user 'root' @ 'localhost'
I think he can not find my mysql password?
I put in (mysqlpass) my session password "Pi"
Do you have an idea ?
Thank you in advance for your help.
Michael
snake
Re: Error Installation Pi 1 : error 1698 (28000)
Post by snake » Mon Jan 07, 2019 6:56 pm
Sounds like mysql doesn't like the password. You can enter the password in on the command line and omit the .my.cnf if you aren't worried particularly about security. I'm not sure why that guide used the .my.cnf file for the password. Seems overkill for the home user. I don't have an RPI1 though, so I'm unable to test the install guide.
Post by bbunge » Mon Jan 07, 2019 8:08 pm
Use these commands to install the database:
mysqladmin -uroot -p reload
You will be prompted for a password which is the password you set in mysql.
Michael.e
Post by Michael.e » Mon Jan 07, 2019 9:23 pm
Thank you very much to both of you for your answers.
I just tried
and he returns to me
Enter password:
I enter my session password pi when I connect under putty
ERROR 1698 (28000): Access denied for user 'root'@'localhost'
@bbunge you tell me to put the password I put in mysql, but at no point in the procedure I'm asked to put a password.
How can I put it because the problem seems to come from there?
Michael
snake
Post by snake » Mon Jan 07, 2019 11:27 pm
Mysql has a different password than what you are typing. Reset the password for mysql by doing
dpkg-reconfigure mysql-server-#.#
as root. Replace the # with the version of your mysql.
