Question please, as far as i see there is in Zone Minder deleting records via event filter. I know how it is deleted manually. But the question is how i could delete video records automatic when the disk is load to 90 percent?
Prtsc of event filter is in the Attachments.
Kind Regards
ZONE MINDER Filter
ZONE MINDER Filter
- c723df41-bc41-402f-97ed-d00e8667ebf6.png (5.81 KiB) Viewed 1284 times
Re: ZONE MINDER Filter
Just change the default filter from 95 to 90
Good day !
As can be seen from the attached picture, I used the PurgeWhenFull background default filter where I set up to delete and archive all matches when disk percent will be greater than 90. I have saved that setting and I think that the program will be executed in the background when the disk is 90%.
Is that correct?
Thank you !
Kind regards !
Is that correct?
Thank you !
Kind regards !
- Screenshot_2018-11-02 ZM - Event Filter.png (7.61 KiB) Viewed 1257 times
