Newbie Here trying to get Zone Minder Up
xatruch
Post by xatruch »
Good Morning Everyone
I am trying to get zone minder up, I've followed the steps here:
https://wiki.zoneminder.com/Debian_9_64 ... e_Easy_Way
But when I try to start the service I get this error:
Job for zoneminder.service failed because the control process exited with error code.
See "systemctl status zoneminder.service" and "journalctl -xe" for details.
invoke-rc.d: initscript zoneminder, action "start" failed.
● zoneminder.service - ZoneMinder CCTV recording and surveillance system
   Loaded: loaded (/lib/systemd/system/zoneminder.service; enabled; vendor preset: enabled)
   Active: failed (Result: exit-code) since Wed 2018-10-17 08:59:29 CDT; 7ms ago
  Process: 7031 ExecStart=/usr/bin/zmpkg.pl start (code=exited, status=255)
Oct 17 08:59:29 zoneminder zmpkg.pl[7031]: Can't connect to db at /usr/share/perl5/ZoneMinder/Config.pm line 129.
Oct 17 08:59:29 zoneminder zmpkg.pl[7031]: BEGIN failed--compilation aborted at /usr/share/perl5/ZoneMinder/Config.pm line 129.
Oct 17 08:59:29 zoneminder zmpkg.pl[7031]: Compilation failed in require at /usr/share/perl5/ZoneMinder.pm line 33.
Oct 17 08:59:29 zoneminder zmpkg.pl[7031]: BEGIN failed--compilation aborted at /usr/share/perl5/ZoneMinder.pm line 33.
Oct 17 08:59:29 zoneminder zmpkg.pl[7031]: Compilation failed in require at /usr/bin/zmpkg.pl line 48.
Oct 17 08:59:29 zoneminder zmpkg.pl[7031]: BEGIN failed--compilation aborted at /usr/bin/zmpkg.pl line 48.
Oct 17 08:59:29 zoneminder systemd[1]: zoneminder.service: Control process exited, code=exited status=255
Oct 17 08:59:29 zoneminder systemd[1]: Failed to start ZoneMinder CCTV recording and surveillance system.
Oct 17 08:59:29 zoneminder systemd[1]: zoneminder.service: Unit entered failed state.
Oct 17 08:59:29 zoneminder systemd[1]: zoneminder.service: Failed with result 'exit-code'.
dpkg: error processing package zoneminder (--configure):
 subprocess installed post-installation script returned error exit status 1
Errors were encountered while processing:
 zoneminder
Can I get a hand please?
Re: Newbie Here trying to get Zone Minder Up
Looks like the Zoneminder install did not create the database.
Create Zoneminder database in MySQL (Note: this also creates the default Zoneminder user and permissions in MySQL) You will be prompted for the password you set for MySQL or Mariadb.
mysqladmin -uroot -p reload
Edit: I just ran the install per https://wiki.zoneminder.com/Debian_9_64 ... e_Easy_Way with no issues.
