Hi
I've installed zonemider 1.30.4 on a debian stretch system. The cam is an szsinocam 2MP capable of ONVIF but running in the network with VLC perfectly with the following string:
rtsp://192.168.1.100:554/ucast/11
now according to my logfile the device is working (attachment LogFile.png).
My problem is now that over the monitor of zoneminder I don't get any picture (stream or image).
My CAM-Config is the following (CamConfig_Page1.png / CamConfig_Page2.png).
Can you help me?
Kind regards
szsinocam streaming no picture
- Config-Page 2 IPCam
- CamConfig_Page2.png (17.79 KiB) Viewed 1109 times
- Config-Page 1 IPCam
- CamConfig_Page1.png (19.06 KiB) Viewed 1109 times
- Logfile says it is capturing (working).
- LogFile.png (17.07 KiB) Viewed 1109 times
Re: szsinocam streaming no picture
Two common errors:
PATH_ZMS is not set to /zm/cgi-bin/nph-zms
Camera resolution in Zoneminder does not match camera output. Use VLC (Tools, Media Information, Codec) to check camera Display Resolution.
