Ubuntu Gnome
idgforum
Ubuntu Gnome
Post by idgforum »
First install on Ubuntu Server 16.04 works fine. But on a computer with Ubuntu Gnome 16.04 its a hell. 2 days now and tested, reistall and testet a lot of guides. Latest is that I can̈́t click add new monitor and I begun laughing. Before I use a day to install on Ubuntu 18.04 but the log was all read and not all camera works. I use the wikki to install.
Someone how try Ubuntu Gnome and Zoneminder an succeed? Ore Ubuntu 18.04?
idgforum
Re: Ubuntu Gnome
Post by idgforum »
This guide work: https://www.linuxhelp.com/how-to-instal ... ntu-16-04/
But same like on Ubuntu 18.04, the camera I only can reach with "cURL (HTTP(S)) only" don't work and the log is read
On the Ubuntu Server it work and use same settings when I added monitor.
viewtopic.php?t=25757
(gonna use my Ubuntu Server only to Kodi sync because no space to recording from Zoneminder)
Date/Time
Component	Server	PID	Level	Message	File	Line
2018-09-19 14:20:07	zms_m1		26434	WAR	no last_frame_sent. Shouldn't happen. frame_mod was (1) frame_count (0)	zm_monitorstream.cpp	705
2018-09-19 14:20:07	zmc_m2		25690	INF	Nexus 5: images:7300 - Capturing at 9.09 fps, capturing bandwidth 1297025bytes/sec	zm_monitor.cpp	2478
2018-09-19 14:20:06	zmdc		26429	INF	'zmc -m 1' started at 18/09/19 14:20:06	zmdc.pl
2018-09-19 14:20:06	zmdc		25272	INF	Starting pending process, zmc -m 1	zmdc.pl
2018-09-19 14:20:06	zmdc		25272	INF	'zmc -m 1' starting at 18/09/19 14:20:06, pid = 26429	zmdc.pl
2018-09-19 14:20:06	web_php		25359	ERR	Socket /var/run/zm/zms-739231s.sock does not exist. This file is created by zms, and since it
 does not exist, either zms did not run, or zms exited early. Please check your zms logs and ensure that CGI is enabled in apache and check that the
 PATH_ZMS is set correctly. Make sure that ZM is actually recording. If you are trying to view a live stream and the capture process (zmc) is not running
 then zms will exit. Please go to http://zoneminder.readthedocs.io/en/latest/faq.html#why-can-t-i-see-streamed-images-when-i-can-see-stills-in-the-zone-
 window-etc for more information.
Re: Ubuntu Gnome
There is nothing special about Ubuntu Gnome. Like any desktop version of Ubuntu you need to install LAMP with tasksel or manually before installing Zoneminder. There is an install script that would do all of that for you before 1.30.4 was removed from the PPA. Now it is a bit harder. Am willing to give you help if you still need it...
bb
idgforum
Re: Ubuntu Gnome
Post by idgforum »
I have Lamp installer on the laptop but no help needed anymore. I given upp and move the Virtual Ubuntu 16.04 server in Unraid from a USB handdisk dock with power cord to a 480 GB 2,5 usb disk ho take the power from the usb port and are protected bye the UPS connected to the Unraid machine. Zonemainder v1.30.4 works perfekt on the virtual Ubuntu Server.
PS -
I now only use the Lenovo Yoga I7 Laptop with broken keyboard and screen to sync Dropbox + Gooogle Drive with OpenDrive. I don't want Dropbox and Google Drive mess around on my gaming computer.
But Tank You for your care bbunge!
https://youtu.be/kYT0L5pg7vw
