One of my cameras is still PTZ-controllable with the existing perl script but the remaining four, which worked with a modified onvif.pm script under zm 1.29, are not controllable in 1.30.4 and zm returns an error.
Running perl onvif.pm in the script directory does not return any errors.
zm's error log produces this error on any attempt to intitiate a PTZ movement:
zmcontrol 32338 ERR Error check failed:'404 Not Found' zmcontrol.pl
I can't work out why zmcontrol is producing this error when it works normally for the other camera.
Any suggestions?
PTZ broken on upgrading from 1.29 to 1.30.4
Re: PTZ broken on upgrading from 1.29 to 1.30.4
Did you ever figure out a solution to your issue?
I'm receiving the same error trying to setup an Axis 3027-pve camera with onvif.
Sorry no - I never did - and have given up.
