Page 1 of 1
Zoneminder Source Settings for Chromecast
Posted: Fri Aug 31, 2018 9:15 pm
by databoy2k
I'm looking for some help making a Zoneminder stream match the Chromecast requirements (https://developers.google.com/cast/docs/media). I don't know what options to use and would appreciate some help.
I've got a LaView Doorbell Camera (a rebrand of the Hikvision one); PDB1520F1. It's running into Zoneminder (Monitor 6). I'm trying to cast the Zoneminder stream to a Chromecast through Home Assistant using the following URL: http://[ZM-IP]/zm/cgi-bin/nph-zms?mode=jpeg&monitor=6&scale=100&maxfps=5.
The camera natively streams at 1080p (1920x1080). Its codec is H264 - MPEG-4 AVC (part 10) according to VLC. Obviously I can access other resolutions by manipulating the capture width and height in ZM. Nothing that I've done, though, makes it possible for the Chromecast to access the stream.
There's a decent explanation of options to use with BlueIris here: https://community.home-assistant.io/t/g ... tant/63671. Any help translating those options or the Chromecast ones above into Zoneminder would be hugely appreciated.
Re: Zoneminder Source Settings for Chromecast
Posted: Mon Jan 06, 2020 1:57 pm
by Maximo1970
Did you ever get this resolved and working?
Posted: Wed Jan 20, 2021 12:29 am
by raymonvdm
I`m able to access the url, directly using the browser when i disable OPT_USE_AUTH
https://zoneminder_url/zm/cgi-bin/nph-zms?mode=jpeg&monitor=1&scale=100&maxfps=5
If this is working, the next step wil be to cast the image to a Google HUB
service: media_player.play_media
data:
  entity_id: media_player.babbelscherm
  media_content_id: >-
  media_content_type: image/jpg
So i`m having an authentication issue here and need some help to get past this. But when i disable authentication i CAN cast to Google Hub
Posted: Wed Jan 20, 2021 2:32 am
by burger
This might apply more to 1.32 and newer, but see:
https://wiki.zoneminder.com/External_Live_Stream
Post by rockedge» Fri Jun 30, 2017 8:09 pm
in a WordPress page or post I use something like this: Remember that
with certain authorizations set, the URL would be slightly different.
this URL works when :
Options->System->OPT_USE_AUTH = ON
Options->System->AUTH_TYPE = Builtin
Options->System->AUTH_RELAY = NONE
<h2><img class="aligncenter"
src="http://your_zm_server/cgi-bin/nph-zms?mode=jpeg&scale=100&maxfps=5&buffer=1000&monitor=1&user=admin" alt="stream down" width="420" height="340" /></h2>
You can have a password as well, such as:
http://IPOFZMSERVER/zm/cgi-bin/nph-zms?mode=jpeg&monitor=6&scale=100"&user="watchinguser"&pass="somepassword
