Hey,
I have a problem with the video export of an event. I am using Zoneminder 30.4 on Ubuntu 16.04 with several SV3C PoE IP Cameras.
Well, when I try to download the generated video file of an event my browser says 'the website is not available'. I tried the right mouse button and 'save file' as well with the same result... (Settings: Video format: .avi, frame rate: real, video size: actual)
But when I change the export settings and increase the frame rate to 50x or higher, the download works fine!
Does anyone have an idea what the problem is?
Problem video export
Re: Problem video export
Please check these settings in Options/Images:
OPT_FFMPEG (checked)
PATH_FFMPEG /usr/bin/ffmpeg
Make sure your frame rate is set at the camera and not i Zoneminder. Maximum FPS (?) and Alarm Maximum FPS (?) should be blank.
I have checked the options, but everything is fine...
I dont unterstand why it is possible with frame rate: 50x, but not with real or the lower rates...
