trying to add first camera
I just installed ZM yesterday and i have been trying to add my sv3c dome cammera. I have tried to do it manually and using the ONVIF search option. ZM is able to find my camera and i can add it. however i dont see any video. i messed around with the function setting and changed it from monitor to several other choices. one of the choices seemed to create an event not sure which. i can see the event in the list when i select the monitor. however i cant review the video. if i click on the monitor then the event, there is a link called stills. if i click stills i get a list of pictures. if i click a still i can see 1 frame so the camera is working on some level. i just seem to be missing something. I am using this as source path rtsp://[username:password]@[my ip]:554/11. i got this from this website. i don't understand the /11 after the port number in the url. any assistance would be appreciated.
Re: trying to add first camera
Linux distro and version. Instructions you used to install Zoneminder. If Ubuntu did you change the path setting?
im using clean install of ubuntu 16.04.3 and i used the ppa installer instuctions. zone minder is v1.30.4
My log has the following events repeating over and over.
2018-06-28 08:34:27.805830 zmdc 28507 INF 'zmc -m 6' crashed, signal 134 zmdc.pl
2018-06-28 08:34:27.569100 zmdc 18470 INF 'zmc -m 6' started at 18/06/28 08:34:27 zmdc.pl
2018-06-28 08:34:27.567230 zmdc 28507 INF 'zmc -m 6' starting at 18/06/28 08:34:27, pid = 18470 zmdc.pl
2018-06-28 08:34:27.350710 zmwatch 18749 INF Restarting capture daemon for HDIPC, shared data not valid zmwatch.pl
i did a clean install of 16.04 and then followed the "Easy Way: Ubuntu 16.04" instructions from this site. i cut and pasted all the command right from the webpage.
Copy and paste is good.
Two common errors:
PATH_ZMS is not set to /zm/cgi-bin/nph-zms
Camera resolution in Zoneminder does not match camera output. Use VLC (Tools, Media Information, Codec) to check camera Display Resolution.
You may not need the port number in your source as rtsp is understood to be port 554. Get the camera to stream in VLC and use that setting in Zoneminder.
Two common errors:
i have no idea how to put a url into VLC. i would really like to get this going. i would like to run this over blue iris since zone minder runs on linux. however i was able to get blueiris configured in 5 minutes without any documentation.
