Firefox shows full screen when monitoring a camera
fatboy
Post by fatboy »
Built a pi zero (pi noir) using h264_v4l2_rtspserver (-W 640 -H 480 -F 60)
I do get 60+fps (only other camera is hard wired to a PV150A-4)
ZM running on a Xen VM under Debian Wheezy, 2G memory, 3 3Mhz CPU's, load never gets above .5 (usually about .3)
When I hit the hardwired camera in firefox, I get a screen size just enough to get the full image.
When I hit the Rpi I get full screen. Didn't used to do that. Have to hit the "+" button to shrink it down (not major but extra typing or hitting buttons does not save me any time at the end of the day)
Ideas of what have I done or not done anyone?
TIA
Re: Firefox shows full screen when monitoring a camera
Lower the camera resolution. 640x480 5 fps is good for security cameras...
fatboy
Post by fatboy »
That is going to reduce the full size window???
fatboy wrote: Tue May 15, 2018 10:04 pm That is going to reduce the full size window???
I know everything is big in Texas but give it a try. You can also choose to display the monitors in smaller size.
fatboy
Post by fatboy »
Ok, set to 1024X768 @5fps, we shall see. The new monitor frame shows the right size (fits the window right!).
Not exactly sure why 5fps is better than 30 or 60, maybe easies on zoneminder server?
Thanks @bbunge
fatboy wrote: Wed May 16, 2018 1:39 pm Ok, set to 1024X768 @5fps, we shall see. The new monitor frame shows the right size (fits the window right!).
Thanks @bbunge
Zoneminder is a security camera system not a HD video recorder. Save some resources with lower frame rate and increase the number of events you can save.
fatboy
Post by fatboy »
Been living with zero wireless at 5fps, it misses at times. I usually delete events when the VM starts getting full. I'll grow it if need be.
Got a cheap 360 pan tilt follow ezviz. got it streaming at 15fps. Great deal if it didn't have to phone home and had the hood it riveted down :x
Starting Nmap 7.01 ( https://nmap.org ) at 2018-08-13 11:34 CDT
NSE: Loaded 132 scripts for scanning.
NSE: Script Pre-scanning.
Initiating NSE at 11:34
Completed NSE at 11:34, 0.00s elapsed
Initiating Ping Scan at 11:34
Scanning 192.168.0.157 [4 ports]
Completed Ping Scan at 11:34, 0.22s elapsed (1 total hosts)
Initiating Parallel DNS resolution of 1 host. at 11:34
Completed Parallel DNS resolution of 1 host. at 11:34, 0.00s elapsed
Initiating SYN Stealth Scan at 11:34
Scanning 192.168.0.157 [1000 ports]
Discovered open port 554/tcp on 192.168.0.157
Discovered open port 8200/tcp on 192.168.0.157
Discovered open port 8000/tcp on 192.168.0.157
Discovered open port 9010/tcp on 192.168.0.157
Completed SYN Stealth Scan at 11:34, 1.29s elapsed (1000 total ports)
Initiating Service scan at 11:34
Scanning 4 services on 192.168.0.157
Service scan Timing: About 50.00% done; ETC: 11:37 (0:01:09 remaining)
Completed Service scan at 11:36, 135.18s elapsed (4 services on 1 host)
Initiating OS detection (try #1) against 192.168.0.157
Initiating Traceroute at 11:37
Completed Traceroute at 11:37, 0.01s elapsed
Initiating Parallel DNS resolution of 2 hosts. at 11:37
Completed Parallel DNS resolution of 2 hosts. at 11:37, 0.00s elapsed
NSE: Script scanning 192.168.0.157.
Initiating NSE at 11:37
Completed NSE at 11:37, 1.55s elapsed
Completed NSE at 11:37, 0.00s elapsed
Nmap scan report for 192.168.0.157
Host is up (0.0030s latency).
Not shown: 996 closed ports
PORT STATE SERVICE VERSION
554/tcp open rtsp Hikvision 7513 POE IP camera rtspd
8000/tcp open http-alt?
8200/tcp open trivnet1?
9010/tcp open sdr?
1 service unrecognized despite returning data. If you know the service/version, please submit the following fingerprint at https://nmap.org/cgi-bin/submit.cgi?new-service :
SF-Port9010-TCP:V=7.01%I=7%D=8/13%Time=5B71B33D%P=x86_64-pc-linux-gnu%r(DN
SF:SVersionBindReq,96,"\x9e\xba\xac\xe9\x01\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\
SF:0\0\0\0\0\0\0V\0\0\0\0<\?xml\x20version=\"1\.0\"\x20encoding=\"utf-8\"\
SF:?>\n<Response>\r\n<Result>129</Result>\r\n</Response>\r\n69da513c7a1fcc
SF:9ebe1b125c50bde3e0");
Device type: general purpose
Running: Linux 2.6.X|3.X
OS CPE: cpe:/o:linux:linux_kernel:2.6 cpe:/o:linux:linux_kernel:3
OS details: Linux 2.6.32 - 3.13
Uptime guess: 0.034 days (since Mon Aug 13 10:47:30 2018)
Network Distance: 2 hops
TCP Sequence Prediction: Difficulty=261 (Good luck!)
IP ID Sequence Generation: All zeros
Service Info: Device: webcam
