Review multiple events synchronously
It would be very nice if there was a way to see in a montage fashion, the recorded video from multiple cameras.
I tought the function was montage review. But that only shows a real time montage, a timeline with red areas (which I presume are events) and whenever you go in review, white no data squares, even if the time cursor overlaps the red areas I presumed are events.
Is there any plan to allow reviewing events from multiple cameras?
This would be very useful in case of linked alarms.
Fabio
Fabio
- knight-of-ni
Re: Review multiple events synchronously
I don't understand what drew you to that conclusion.
Montage review does in fact show a montage of past events, simultaneously, just like you want. That's it's primary purpose.
You can even drag the slider through the timeline to "scrub" through the video events. It's pretty slick how it works.
Thanks for your reply.
I was puzzled because when I stated that montage review was not working as I expected a few days ago in another post,I did not get any reply. I tought I did not understand how montage review was supposed to work and I could not find any docs about it, nor previous posts. Maybe I did not express myself clearly enough.
viewtopic.php?f=36&t=27162
I will try again.
In my installation I only get “no data” white screens in montage review as soon as I click on any option other than the live view it opens initially.
How can I investigate why montage review is only showing no data even when the time line cursor overlaps the red areas I suppose are the events?
Fabio
I will try again.
Fabio
- knight-of-ni
That is by design.
If you see "no data" in a window then that means no event was recorded for the monitor for that particular time period.
After switching to event mode, look at the timeline with the red blocks. There is a tall rectangle with a gray or black outline in the timeline. Drag that back and forth with your mouse. As you drag it over the red blocks in the timeline, the various monitors will populate below.
Hello thanks again for your reply.fsardone wrote: ↑Thu Apr 19, 2018 7:49 pm
As I said, as soon as I switch to event mode I get white no data screen including when the cursor (the tall rectangle with the grey or black outline) overlaps the red area (the events recorded).
So in my installation montage review appears not to work.
How may I investigate the cause?
Cheers
Fabio
Well I did ask for help troubleshooting the issue here and also here viewtopic.php?f=36&t=27162 but nothing came I initially tought it was because I did not fully understand how montare review would work. Then after clarifying that montage review would do exactly what I tought it should do, annd seen no reply to my latest post in this thread, I opened viewtopic.php?f=36&t=27186
Which was dutifully locked.
So let’s keep the discussion going here
Whch one are the logs I need to be reading?
Search on the forum search function did not yield anything useful and search on google provided this topic:
viewtopic.php?t=25532
which is exactly my issue but the solution does not fix the problem.
Some additional Elements:
in montage review, when reviewing events and the time cursor is on the events these lines appear in the event log:
2018-04-25 17:04:30.737882 web_php 2044 ERR Invalid image path /usr/share/zoneminder/www/views/image.php 132
Guess it is generated in this line:
if ( $errorText )
Error( $errorText );
Not sure what path should be referring to.
if ( $errorText )
Hello fsardone!
To keep the monitors on the time line easier to see individually you can change the color assigned to the camera monitor. Open a monitor settings window and select the "Misc" tab and modify the Web Color from red to some other value. Now in the timeline view each block of events attached to a monitor will be easy to follow by it's assigned color. Red is the default value of Misc->Web Color
Montage review does not work
Hi Rockedge,rockedge wrote: ↑Wed Apr 25, 2018 4:06 pm Hello fsardone!
unfortunately that is not the issue. I get "No Data" white screens in the montage review, even when there are events present.
I see the events in the timeline, I see no video when the cursor overlaps the marked events.
Cheers
Fabio
Some more info about the system
It is running under a Xen AMD 64 system running Debian Stretch (9) stable both in the Hypervisor Dom0 and the fully paravirtualized User Domain created by deboostrap (see below for full details of the installed packages). Install of zoneminder happened according to the zoneminder wiki:
https://wiki.zoneminder.com/Debian_9_64 ... der_1.30.4
zoneminder:
Installed: 2:1.30.4-dmo1+deb9u1
Candidate: 2:1.30.4-dmo1+deb9u1
Version table:
*** 2:1.30.4-dmo1+deb9u1 500
500 http://www.deb-multimedia.org stretch/main amd64 Packages
100 /var/lib/dpkg/status
xen-system-amd64:
Installed: (none)
Candidate: 4.8.2+xsa245-0+deb9u1
Version table:
4.8.2+xsa245-0+deb9u1 500
500 http://ftp.it.debian.org/debian stretch/main amd64 Packages
500 http://security.debian.org/debian-security stretch/updates/main amd64 Packages
A bit of the logs. As soon as the console goes on the events I get the errors:
zoneminder:
Version table:
xen-system-amd64:
Installed: (none)
Version table:
2018-04-26 21:28:56.408110 zms 12407 ERR Frame send time 432 msec too slow, throttling maxfps to 2.22 zm_monitor.cpp 3949
2018-04-26 21:28:48.726153 zms 12407 ERR Frame send time 7523 msec too slow, throttling maxfps to 3.33 zm_monitor.cpp 3949
2018-04-26 21:28:44.870317 zmc_m5 3778 INF Citofono: 1523000 - Capturing at 15.15 fps zm_monitor.cpp 3125
2018-04-26 21:28:37.243414 zms 12358 ERR Terminating, last frame sent time 50.046001 secs more than maximum of 10.000000 zm_monitor.cpp 4213
2018-04-26 21:28:37.142959 zms 12358 ERR Can't sendto on sd 8: No such file or directory zm_monitor.cpp 3799
2018-04-26 21:28:37.011879 zms 12358 ERR Frame send time 48913 msec too slow, throttling maxfps to 3.33 zm_monitor.cpp 3949
2018-04-26 21:28:34.338197 zms 12359 ERR Terminating, last frame sent time 40.841032 secs more than maximum of 10.000000 zm_monitor.cpp 4213
2018-04-26 21:28:34.263181 zms 12359 ERR Can't sendto on sd 8: No such file or directory zm_monitor.cpp 3799
2018-04-26 21:28:34.152058 zms 12359 ERR Frame send time 39730 msec too slow, throttling maxfps to 3.33 zm_monitor.cpp 3949
2018-04-26 21:28:32.045554 zms 12363 ERR Terminating, last frame sent time 26.010920 secs more than maximum of 10.000000 zm_monitor.cpp 4213
2018-04-26 21:28:31.913230 zms 12363 ERR Frame send time 24910 msec too slow, throttling maxfps to 3.33 zm_monitor.cpp 3949
2018-04-26 21:28:30.664843 web_php 9811 ERR Invalid image path /usr/share/zoneminder/www/views/image.php 132
2018-04-26 21:28:29.667948 web_php 12397 ERR Invalid image path /usr/share/zoneminder/www/views/image.php 132
2018-04-26 21:28:29.442484 zms 12376 ERR Frame send time 5128 msec too slow, throttling maxfps to 0.66 zm_monitor.cpp 3949
2018-04-26 21:28:28.661964 web_php 9811 ERR Invalid image path /usr/share/zoneminder/www/views/image.php 132
2018-04-26 21:28:27.663616 web_php 12397 ERR Invalid image path /usr/share/zoneminder/www/views/image.php 132
2018-04-26 21:28:26.657429 web_php 9811 ERR Invalid image path /usr/share/zoneminder/www/views/image.php 132
2018-04-26 21:28:25.657666 web_php 9811 ERR Invalid image path /usr/share/zoneminder/www/views/image.php 132
2018-04-26 21:28:24.656936 web_php 12397 ERR Invalid image path /usr/share/zoneminder/www/views/image.php 132
2018-04-26 21:28:23.658492 web_php 9811 ERR Invalid image path /usr/share/zoneminder/www/views/image.php 132
2018-04-26 21:28:22.656879 web_php 12397 ERR Invalid image path /usr/share/zoneminder/www/views/image.php 132
2018-04-26 21:28:21.654805 web_php 9811 ERR Invalid image path /usr/share/zoneminder/www/views/image.php 132
2018-04-26 21:28:21.349436 zms 12376 ERR Frame send time 7359 msec too slow, throttling maxfps to 0.99 zm_monitor.cpp 3949
2018-04-26 21:28:20.966835 zmc_m3 10488 INF Backyard: 253000 - Capturing at 8.06 fps zm_monitor.cpp 3125
2018-04-26 21:28:20.661421 web_php 8728 ERR Invalid image path /usr/share/zoneminder/www/views/image.php 132
2018-04-26 21:28:20.660405 web_php 12397 ERR Invalid image path /usr/share/zoneminder/www/views/image.php 132
2018-04-26 21:28:20.657604 web_php 9811 ERR Invalid image path /usr/share/zoneminder/www/views/image.php 132
2018-04-26 21:28:19.659858 web_php 9811 ERR Invalid image path /usr/share/zoneminder/www/views/image.php 132
2018-04-26 21:28:19.658488 web_php 12397 ERR Invalid image path /usr/share/zoneminder/www/views/image.php 132
2018-04-26 21:28:19.655990 web_php 8728 ERR Invalid image path /usr/share/zoneminder/www/views/image.php 132
2018-04-26 21:28:18.661963 web_php 8728 ERR Invalid image path /usr/share/zoneminder/www/views/image.php 132
2018-04-26 21:28:18.656893 web_php 12397 ERR Invalid image path /usr/share/zoneminder/www/views/image.php 132
2018-04-26 21:28:18.653613 web_php 9811 ERR Invalid image path /usr/share/zoneminder/www/views/image.php 132
2018-04-26 21:28:17.655861 web_php 9811 ERR Invalid image path /usr/share/zoneminder/www/views/image.php 132
2018-04-26 21:28:17.653009 web_php 12397 ERR Invalid image path /usr/share/zoneminder/www/views/image.php 132
2018-04-26 21:28:17.651507 web_php 8728 ERR Invalid image path /usr/share/zoneminder/www/views/image.php 132
2018-04-26 21:28:17.524546 web_php 12397 ERR Invalid image path /usr/share/zoneminder/www/views/image.php 132
2018-04-26 21:28:17.520811 web_php 9811 ERR Invalid image path /usr/share/zoneminder/www/views/image.php 132
2018-04-26 21:28:17.383354 web_php 12397 ERR Invalid image path /usr/share/zoneminder/www/views/image.php 132
2018-04-26 21:28:17.379261 web_php 9811 ERR Invalid image path /usr/share/zoneminder/www/views/image.php 132
2018-04-26 21:28:17.065207 web_php 12397 ERR Invalid image path /usr/share/zoneminder/www/views/image.php 132
2018-04-26 21:28:17.052655 web_php 8728 ERR Invalid image path /usr/share/zoneminder/www/views/image.php 132
2018-04-26 21:28:16.965340 web_php 9811 ERR Invalid image path /usr/share/zoneminder/www/views/image.php 132
2018-04-26 21:28:10.699410 zms 12376 ERR Frame send time 1206 msec too slow, throttling maxfps to 1.48 zm_monitor.cpp 3949
2018-04-26 21:28:09.833344 web_php 12371 ERR Timed out waiting for msg /var/run/zm/zms-805783s.sock /usr/share/zoneminder/www/includes/functions.php 2033
2018-04-26 21:28:07.415728 zms 12376 ERR Frame send time 2264 msec too slow, throttling maxfps to 2.22 zm_monitor.cpp 3949
2018-04-26 21:28:06.322703 zma_m4 932 INF GarageGate: 1289000 - Analysing at 7.94 fps zm_monitor.cpp 1296
2018-04-26 21:28:00.873843 zms 11771 ERR Terminating, last frame sent time 60.186324 secs more than maximum of 10.000000 zm_monitor.cpp 4213
2018-04-26 21:28:00.807344 zms 11771 ERR Can't sendto on sd 8: No such file or directory zm_monitor.cpp 3799
2018-04-26 21:28:00.782302 zms 11771 ERR Can't sendto on sd 8: No such file or directory zm_monitor.cpp 3799
2018-04-26 21:28:00.611513 zms 11771 ERR Frame send time 59014 msec too slow, throttling maxfps to 3.33 zm_monitor.cpp 3949
2018-04-26 21:28:00.546079 zms 12360 ERR Terminating, last frame sent time 12.215447 secs more than maximum of 10.000000 zm_monitor.cpp 4213
2018-04-26 21:28:00.364414 zms 12360 ERR Frame send time 11092 msec too slow, throttling maxfps to 1.48 zm_monitor.cpp 3949
2018-04-26 21:27:59.805846 zms 12376 ERR Frame send time 6985 msec too slow, throttling maxfps to 3.33 zm_monitor.cpp 3949
2018-04-26 21:27:58.638275 web_php 9293 ERR Timed out waiting for msg /var/run/zm/zms-766927s.sock /usr/share/zoneminder/www/includes/functions.php 2033
2018-04-26 21:27:52.002782 zmc_m4 9683 INF GarageGate: 366000 - Capturing at 7.87 fps zm_monitor.cpp 3125
2018-04-26 21:27:44.833131 zms 11772 ERR Terminating, last frame sent time 50.967223 secs more than maximum of 10.000000 zm_monitor.cpp 4213
2018-04-26 21:27:44.745432 zms 11772 ERR Can't sendto on sd 8: No such file or directory zm_monitor.cpp 3799
2018-04-26 21:27:44.715043 zms 11772 ERR Can't sendto on sd 8: No such file or directory zm_monitor.cpp 3799
2018-04-26 21:27:44.590739 zms 11772 ERR Frame send time 49842 msec too slow, throttling maxfps to 3.33 zm_monitor.cpp 3949
2018-04-26 21:27:43.579302 zms 12360 ERR Frame send time 4765 msec too slow, throttling maxfps to 2.22 zm_monitor.cpp 3949
2018-04-26 21:27:41.934273 web_php 9811 ERR Timed out waiting for msg /var/run/zm/zms-766927s.sock /usr/share/zoneminder/www/includes/functions.php 2033
2018-04-26 21:27:41.306580 zms 12357 ERR Terminating, last frame sent time 26.817277 secs more than maximum of 10.000000 zm_monitor.cpp 4213
2018-04-26 21:27:41.213927 zms 12357 ERR Can't sendto on sd 8: No such file or directory zm_monitor.cpp 3799
2018-04-26 21:27:41.070667 zms 12357 ERR Frame send time 25672 msec too slow, throttling maxfps to 3.33 zm_monitor.cpp 3949
2018-04-26 21:27:40.790940 zma_m2 3806 INF CancelloSu: 1011000 - Analysing at 9.90 fps zm_monitor.cpp 1296
2018-04-26 21:27:38.133509 zmc_m5 3778 INF Citofono: 1522000 - Capturing at 14.93 fps zm_monitor.cpp 3125
2018-04-26 21:27:36.418435 zms 12360 ERR Frame send time 822 msec too slow, throttling maxfps to 3.33 zm_monitor.cpp 3949
2018-04-26 21:27:34.899604 zmc_m2 3804 INF CancelloSu: 1011000 - Capturing at 9.90 fps zm_monitor.cpp 3125
2018-04-26 21:27:32.751592 web_php 8729 ERR Timed out waiting for msg /var/run/zm/zms-463778s.sock /usr/share/zoneminder/www/includes/functions.php 2033
2018-04-26 21:27:28.209074 web_php 8728 ERR Timed out waiting for msg /var/run/zm/zms-253272s.sock /usr/share/zoneminder/www/includes/functions.php 2033
2018-04-26 21:27:18.655042 web_php 8730 ERR Timed out waiting for msg /var/run/zm/zms-463778s.sock /usr/share/zoneminder/www/includes/functions.php 2033
2018-04-26 21:27:14.178546 web_php 8731 ERR Socket /var/run/zm/zms-805783s.sock does not exist. This file is created by zms, and since it does not exist, either zms did not run, or zms exited early. Please check your zms logs and ensure that CGI is enabled in apache and check that the PATH_ZMS is set correctly. Make sure that ZM is actually recording. If you are trying to view a live stream and the capture process (zmc) is not running then zms will exit. Please go to http://zoneminder.readthedocs.io/en/latest/faq.html#why-can-t-i-see-streamed-images-when-i-can-see-stills-in-the-zone-window-etc for more information. /usr/share/zoneminder/www/includes/functions.php 2033
2018-04-26 21:27:12.657390 zms 11773 ERR Terminating, last frame sent time 21.795445 secs more than maximum of 10.000000 zm_monitor.cpp 4213
2018-04-26 21:27:12.566527 zms 11773 ERR Can't sendto on sd 8: No such file or directory zm_monitor.cpp 3799
2018-04-26 21:27:12.443434 zms 11773 ERR Frame send time 20671 msec too slow, throttling maxfps to 3.33 zm_monitor.cpp 3949
2018-04-26 21:27:08.008994 web_php 8730 ERR Timed out waiting for msg /var/run/zm/zms-766927s.sock /usr/share/zoneminder/www/includes/functions.php 2033
2018-04-26 21:27:07.977563 web_php 10069 ERR Timed out waiting for msg /var/run/zm/zms-253272s.sock /usr/share/zoneminder/www/includes/functions.php 2033
2018-04-26 21:27:07.608898 zms 11770 ERR Terminating, last frame sent time 10.369654 secs more than maximum of 10.000000 zm_monitor.cpp 4213
2018-04-26 21:27:07.356019 zms 11770 ERR Frame send time 9164 msec too slow, throttling maxfps to 3.33 zm_monitor.cpp 3949
2018-04-26 21:27:07.158449 zma_m3 930 INF Backyard: 1293000 - Analysing at 8.00 fps zm_monitor.cpp 1296
2018-04-26 21:26:31.393500 zmc_m5 3778 INF Citofono: 1521000 - Capturing at 14.93 fps zm_monitor.cpp 3125
2018-04-26 21:26:16.045339 zmc_m3 10488 INF Backyard: 252000 - Capturing at 8.00 fps zm_monitor.cpp 3125
2018-04-26 21:26:00.027076 zma_m4 932 INF GarageGate: 1288000 - Analysing at 7.87 fps zm_monitor.cpp 1296
2018-04-26 21:25:59.715218 zma_m2 3806 INF CancelloSu: 1010000 - Analysing at 9.90 fps zm_monitor.cpp 1296
2018-04-26 21:25:53.931037 zmc_m2 3804 INF CancelloSu: 1010000 - Capturing at 9.90 fps zm_monitor.cpp 3125
2018-04-26 21:25:45.622572 zmc_m4 9683 INF GarageGate: 365000 - Capturing at 7.94 fps zm_monitor.cpp 3125
2018-04-26 21:25:24.696863 zmc_m5 3778 INF Citofono: 1520000 - Capturing at 14.93 fps zm_monitor.cpp 3125
2018-04-26 21:25:02.206150 zma_m3 930 INF Backyard: 1292000 - Analysing at 8.00 fps zm_monitor.cpp 1296
2018-04-26 21:24:18.672200 zma_m2 3806 INF CancelloSu: 1009000 - Analysing at 9.90 fps zm_monitor.cpp 1296
2018-04-26 21:24:17.958916 zmc_m5 3778 INF Citofono: 1519000 - Capturing at 15.15 fps zm_monitor.cpp 3125
2018-04-26 21:24:12.810822 zmc_m2 3804 INF CancelloSu: 1009000 - Capturing at 9.90 fps zm_monitor.cpp 3125
2018-04-26 21:24:11.162745 zmc_m3 10488 INF Backyard: 251000 - Capturing at 8.00 fps zm_monitor.cpp 3125
2018-04-26 21:23:53.620378 zma_m4 932 INF GarageGate: 1287000 - Analysing at 7.94 fps zm_monitor.cpp 1296
2018-04-26 21:23:39.300774 zmc_m4 9683 INF GarageGate: 364000 - Capturing at 7.87 fps zm_monitor.cpp 3125
2018-04-26 21:23:11.220627 zmc_m5 3778 INF Citofono: 1518000 - Capturing at 14.93 fps zm_monitor.cpp 3125
2018-04-26 21:22:57.269567 zma_m3 930 INF Backyard: 1291000 - Analysing at 8.00 fps zm_monitor.cpp 1296
2018-04-26 21:22:37.614819 zma_m2 3806 INF CancelloSu: 1008000 - Analysing at 9.90 fps zm_monitor.cpp 1296
2018-04-26 21:22:31.718368 zmc_m2 3804 INF CancelloSu: 1008000 - Capturing at 9.90 fps zm_monitor.cpp 3125
2018-04-26 21:22:06.228740 zmc_m3 10488 INF Backyard: 250000 - Capturing at 8.00 fps zm_monitor.cpp 3125
2018-04-26 21:22:04.471296 zmc_m5 3778 INF Citofono: 1517000 - Capturing at 14.93 fps zm_monitor.cpp 3125
2018-04-26 21:21:47.390819 zma_m4 932 INF GarageGate: 1286000 - Analysing at 7.87 fps zm_monitor.cpp 1296
2018-04-26 21:21:32.964233 zmc_m4 9683 INF GarageGate: 363000 - Capturing at 7.94 fps zm_monitor.cpp 3125
2018-04-26 21:20:57.735675 zmc_m5 3778 INF Citofono: 1516000 - Capturing at 14.93 fps zm_monitor.cpp 3125
2018-04-26 21:20:56.547628 zma_m2 3806 INF CancelloSu: 1007000 - Analysing at 9.90 fps zm_monitor.cpp 1296
2018-04-26 21:20:52.340233 zma_m3 930 INF Backyard: 1290000 - Analysing at 8.00 fps zm_monitor.cpp 1296
2018-04-26 21:20:50.677295 zmc_m2 3804 INF CancelloSu: 1007000 - Capturing at 9.90 fps zm_monitor.cpp 3125
2018-04-26 21:20:01.286725 zmc_m3 10488 INF Backyard: 249000 - Capturing at 8.00 fps zm_monitor.cpp 3125
2018-04-26 21:19:50.997020 zmc_m5 3778 INF Citofono: 1515000 - Capturing at 15.15 fps zm_monitor.cpp 3125
2018-04-26 21:19:40.968720 zma_m4 932 INF GarageGate: 1285000 - Analysing at 7.94 fps zm_monitor.cpp 1296
2018-04-26 21:19:32.566290 zmfilter 902 INF Deleting event 14618 from Monitor 2 zmfilter.pl
2018-04-26 21:19:32.303640 zmfilter 902 INF Deleting event 14617 from Monitor 2 zmfilter.pl
2018-04-26 21:19:26.731714 zmc_m4 9683 INF GarageGate: 362000 - Capturing at 7.94 fps zm_monitor.cpp 3125
2018-04-26 21:19:15.528065 zma_m2 3806 INF CancelloSu: 1006000 - Analysing at 9.90 fps zm_monitor.cpp 1296
2018-04-26 21:19:09.632808 zmc_m2 3804 INF CancelloSu: 1006000 - Capturing at 9.90 fps zm_monitor.cpp 3125
2018-04-26 21:18:47.447142 zma_m3 930 INF Backyard: 1289000 - Analysing at 8.00 fps zm_monitor.cpp 1296
2018-04-26 21:18:44.262484 zmc_m5 3778 INF Citofono: 1514000 - Capturing at 14.93 fps zm_monitor.cpp 3125
2018-04-26 21:17:56.329604 zmc_m3 10488 INF Backyard: 248000 - Capturing at 8.00 fps zm_monitor.cpp 3125
2018-04-26 21:17:37.521925 zmc_m5 3778 INF Citofono: 1513000 - Capturing at 14.93 fps zm_monitor.cpp 3125
2018-04-26 21:17:34.672534 zma_m4 932 INF GarageGate: 1284000 - Analysing at 7.94 fps zm_monitor.cpp 1296
2018-04-26 21:17:34.429227 zma_m2 3806 INF CancelloSu: 1005000 - Analysing at 9.90 fps zm_monitor.cpp 1296
2018-04-26 21:17:28.535916 zmc_m2 3804 INF CancelloSu: 1005000 - Capturing at 9.90 fps zm_monitor.cpp 3125
2018-04-26 21:17:20.362838 zmc_m4 9683 INF GarageGate: 361000 - Capturing at 7.94 fps zm_monitor.cpp 3125
2018-04-26 21:16:42.501998 zma_m3 930 INF Backyard: 1288000 - Analysing at 8.00 fps zm_monitor.cpp 1296
2018-04-26 21:16:30.786593 zmc_m5 3778 INF Citofono: 1512000 - Capturing at 15.15 fps zm_monitor.cpp 3125
2018-04-26 21:15:53.306462 zma_m2 3806 INF CancelloSu: 1004000 - Analysing at 9.90 fps zm_monitor.cpp 1296
2018-04-26 21:15:51.362379 zmc_m3 10488 INF Backyard: 247000 - Capturing at 8.00 fps zm_monitor.cpp 3125
2018-04-26 21:15:47.496076 zmc_m2 3804 INF CancelloSu: 1004000 - Capturing at 9.90 fps zm_monitor.cpp 3125
2018-04-26 21:15:28.415024 zma_m4 932 INF GarageGate: 1283000 - Analysing at 7.87 fps zm_monitor.cpp 1296
2018-04-26 21:15:24.089906 zmc_m5 3778 INF Citofono: 1511000 - Capturing at 14.93 fps zm_monitor.cpp 3125
2018-04-26 21:15:14.006977 zmc_m4 9683 INF GarageGate: 360000 - Capturing at 7.87 fps zm_monitor.cpp 3125
2018-04-26 21:14:37.509221 zma_m3 930 INF Backyard: 1287000 - Analysing at 8.00 fps zm_monitor.cpp 1296
2018-04-26 21:14:17.352037 zmc_m5 3778 INF Citofono: 1510000 - Capturing at 14.93 fps zm_monitor.cpp 3125
2018-04-26 21:14:12.223141 zma_m2 3806 INF CancelloSu: 1003000 - Analysing at 9.90 fps zm_monitor.cpp 1296
2018-04-26 21:14:06.425910 zmc_m2 3804 INF CancelloSu: 1003000 - Capturing at 9.90 fps zm_monitor.cpp 3125
2018-04-26 21:13:46.481222 zmc_m3 10488 INF Backyard: 246000 - Capturing at 8.00 fps zm_monitor.cpp 3125
2018-04-26 21:13:21.989972 zma_m4 932 INF GarageGate: 1282000 - Analysing at 7.94 fps zm_monitor.cpp 1296
2018-04-26 21:13:10.615548 zmc_m5 3778 INF Citofono: 1509000 - Capturing at 14.93 fps zm_monitor.cpp 3125
2018-04-26 21:13:07.756682 zmc_m4 9683 INF GarageGate: 359000 - Capturing at 7.94 fps zm_monitor.cpp 3125
2018-04-26 21:12:32.651671 zma_m3 930 INF Backyard: 1286000 - Analysing at 8.00 fps zm_monitor.cpp 1296
2018-04-26 21:12:31.189908 zma_m2 3806 INF CancelloSu: 1002000 - Analysing at 9.90 fps zm_monitor.cpp 1296
2018-04-26 21:12:25.327039 zmc_m2 3804 INF CancelloSu: 1002000 - Capturing at 9.90 fps zm_monitor.cpp 3125
2018-04-26 21:12:03.876818 zmc_m5 3778 INF Citofono: 1508000 - Capturing at 15.15 fps zm_monitor.cpp 3125
2018-04-26 21:11:41.613328 zmc_m3 10488 INF Backyard: 245000 - Capturing at 8.00 fps zm_monitor.cpp 3125
2018-04-26 21:11:15.709790 zma_m4 932 INF GarageGate: 1281000 - Analysing at 7.94 fps zm_monitor.cpp 1296
2018-04-26 21:11:03.819260 zmaudit 913 INF Deleted 151 log table entries by time zmaudit.pl
2018-04-26 21:11:01.391631 zmc_m4 9683 INF GarageGate: 358000 - Capturing at 7.94 fps zm_monitor.cpp 3125
2018-04-26 21:10:57.140280 zmc_m5 3778 INF Citofono: 1507000 - Capturing at 14.93 fps zm_monitor.cpp 3125
2018-04-26 21:10:50.191715 zma_m2 3806 INF CancelloSu: 1001000 - Analysing at 9.90 fps zm_monitor.cpp 1296
2018-04-26 21:10:44.304975 zmc_m2 3804 INF CancelloSu: 1001000 - Capturing at 9.90 fps zm_monitor.cpp 3125
2018-04-26 21:10:27.696084 zma_m3 930 INF Backyard: 1285000 - Analysing at 8.00 fps zm_monitor.cpp 1296
2018-04-26 21:09:51.633396 zma_m3 930 INF Backyard: 1284710 - Closing event 14908, alarm end zm_monitor.cpp 1716
2018-04-26 21:09:51.573094 zma_m3 930 INF Backyard: 1284710 - Left alarm state (14908) - 52(2) images zm_monitor.cpp 1711
2018-04-26 21:09:51.545229 zma_m4 932 INF GarageGate: 1280332 - Closing event 14907, alarm end zm_monitor.cpp 1716
2018-04-26 21:09:51.364304 zma_m4 932 INF GarageGate: 1280332 - Left alarm state (14907) - 51(1) images zm_monitor.cpp 1711
2018-04-26 21:09:50.405703 zmc_m5 3778 INF Citofono: 1506000 - Capturing at 14.93 fps zm_monitor.cpp 3125
2018-04-26 21:09:48.474906 zma_m3 930 INF Backyard: 1284685 - Gone into alert state zm_monitor.cpp 1704
2018-04-26 21:09:48.405287 zma_m4 932 INF GarageGate: 1280307 - Gone into alert state zm_monitor.cpp 1704
2018-04-26 21:09:48.188299 zma_m3 930 INF Backyard: 1284683 - Opening new event 14908, alarm start zm_monitor.cpp 1660
2018-04-26 21:09:48.104464 zma_m4 932 INF GarageGate: 1280306 - Opening new event 14907, alarm start zm_monitor.cpp 1660
2018-04-26 21:09:48.088611 zma_m3 930 INF Backyard: 1284683 - Gone into alarm state zm_monitor.cpp 1614
2018-04-26 21:09:48.010702 zma_m4 932 INF GarageGate: 1280306 - Gone into alarm state zm_monitor.cpp 1614
2018-04-26 21:09:36.647653 zmc_m3 10488 INF Backyard: 244000 - Capturing at 8.00 fps zm_monitor.cpp 3125
2018-04-26 21:09:09.410015 zma_m4 932 INF GarageGate: 1280000 - Analysing at 7.94 fps zm_monitor.cpp 1296
2018-04-26 21:09:09.111736 zma_m2 3806 INF CancelloSu: 1000000 - Analysing at 9.90 fps zm_monitor.cpp 1296
2018-04-26 21:09:03.239086 zmc_m2 3804 INF CancelloSu: 1000000 - Capturing at 9.90 fps zm_monitor.cpp 3125
2018-04-26 21:08:55.004513 zmc_m4 9683 INF GarageGate: 357000 - Capturing at 7.87 fps zm_monitor.cpp 3125
2018-04-26 21:08:43.672483 zmc_m5 3778 INF Citofono: 1505000 - Capturing at 14.93 fps zm_monitor.cpp 3125
2018-04-26 21:08:22.806326 zma_m3 930 INF Backyard: 1284000 - Analysing at 8.00 fps zm_monitor.cpp 1296
2018-04-26 21:07:36.936647 zmc_m5 3778 INF Citofono: 1504000 - Capturing at 15.15 fps zm_monitor.cpp 3125
2018-04-26 21:07:31.654169 zmc_m3 10488 INF Backyard: 243000 - Capturing at 8.00 fps zm_monitor.cpp 3125
2018-04-26 21:07:28.034169 zma_m2 3806 INF CancelloSu: 999000 - Analysing at 9.80 fps zm_monitor.cpp 1296
2018-04-26 21:07:22.171637 zmc_m2 3804 INF CancelloSu: 999000 - Capturing at 9.90 fps zm_monitor.cpp 3125
2018-04-26 21:07:03.067449 zma_m4 932 INF GarageGate: 1279000 - Analysing at 7.87 fps zm_monitor.cpp 1296
2018-04-26 21:06:48.721472 zmc_m4 9683 INF GarageGate: 356000 - Capturing at 7.94 fps zm_monitor.cpp 3125
2018-04-26 21:06:30.198498 zmc_m5 3778 INF Citofono: 1503000 - Capturing at 14.93 fps zm_monitor.cpp 3125
2018-04-26 21:06:17.806304 zma_m3 930 INF Backyard: 1283000 - Analysing at 8.00 fps zm_monitor.cpp 1296
2018-04-26 21:05:46.927429 zma_m2 3806 INF CancelloSu: 998000 - Analysing at 9.90 fps zm_monitor.cpp 1296
2018-04-26 21:05:41.162525 zmc_m2 3804 INF CancelloSu: 998000 - Capturing at 9.90 fps zm_monitor.cpp 3125
2018-04-26 21:05:26.777469 zmc_m3 10488 INF Backyard: 242000 - Capturing at 8.00 fps zm_monitor.cpp 3125
2018-04-26 21:05:23.461342 zmc_m5 3778 INF Citofono: 1502000 - Capturing at 14.93 fps zm_monitor.cpp 3125
2018-04-26 21:04:56.731479 zma_m4 932 INF GarageGate: 1278000 - Analysing at 7.94 fps zm_monitor.cpp 1296
2018-04-26 21:04:42.415466 zmc_m4 9683 INF GarageGate: 355000 - Capturing at 7.94 fps zm_monitor.cpp 3125
2018-04-26 21:04:16.722334 zmc_m5 3778 INF Citofono: 1501000 - Capturing at 14.93 fps zm_monitor.cpp 3125
2018-04-26 21:04:12.955285 zma_m3 930 INF Backyard: 1282000 - Analysing at 8.00 fps zm_monitor.cpp 1296
2018-04-26 21:04:05.851590 zma_m2 3806 INF CancelloSu: 997000 - Analysing at 9.90 fps zm_monitor.cpp 1296
2018-04-26 21:04:00.062298 zmc_m2 3804 INF CancelloSu: 997000 - Capturing at 9.90 fps zm_monitor.cpp 3125
2018-04-26 21:03:21.842509 zmc_m3 10488 INF Backyard: 241000 - Capturing at 8.00 fps zm_monitor.cpp 3125
2018-04-26 21:03:09.987354 zmc_m5 3778 INF Citofono: 1500000 - Capturing at 15.15 fps zm_monitor.cpp 3125
2018-04-26 21:02:50.449076 zma_m4 932 INF GarageGate: 1277000 - Analysing at 7.94 fps zm_monitor.cpp 1296
2018-04-26 21:02:36.025990 zmc_m4 9683 INF GarageGate: 354000 - Capturing at 7.87 fps zm_monitor.cpp 3125
2018-04-26 21:02:24.798439 zma_m2 3806 INF CancelloSu: 996000 - Analysing at 9.90 fps zm_monitor.cpp 1296
2018-04-26 21:02:19.029485 zmc_m2 3804 INF CancelloSu: 996000 - Capturing at 9.80 fps zm_monitor.cpp 3125
2018-04-26 21:02:07.988853 zma_m3 930 INF Backyard: 1281000 - Analysing at 8.06 fps zm_monitor.cpp 1296
2018-04-26 21:02:03.255393 zmc_m5 3778 INF Citofono: 1499000 - Capturing at 14.93 fps zm_monitor.cpp 3125
2018-04-26 21:01:16.948726 zmc_m3 10488 INF Backyard: 240000 - Capturing at 8.00 fps zm_monitor.cpp 3125
2018-04-26 21:00:56.518747 zmc_m5 3778 INF Citofono: 1498000 - Capturing at 14.93 fps zm_monitor.cpp 3125
2018-04-26 21:00:44.131476 zma_m4 932 INF GarageGate: 1276000 - Analysing at 7.87 fps zm_monitor.cpp 1296
2018-04-26 21:00:43.850957 zma_m2 3806 INF CancelloSu: 995000 - Analysing at 9.90 fps zm_monitor.cpp 1296
2018-04-26 21:00:37.953027 zmc_m2 3804 INF CancelloSu: 995000 - Capturing at 9.90 fps zm_monitor.cpp
Hello everybody:
in order to try and find out why I was getting the error in the log I tracked down the source code doing so and changed it in order to try to understand what path was wrong.
I changed the error text from Invalid to Xnvalid to validate my insertion point and appended the $path variable. The consequent errors I got into the log contain no text after the error message so I have to assume the $path variable is empty.
Also I defined the $debug=true variable and these are the system variables.
Any suggestions why the Montage review is not working and the $path variable is not being set?
Does Mintage Review works fine for everybody else using debian?
Fabio
# If we are only specifying fid, then the fid must be the primary key into the frames table. But when the event is specified, then it is the frame #
$Frame = new Frame( $_REQUEST['fid'] );
$Event = new Event( $Frame->EventId() );
$path = $Event->Path().'/'.sprintf("%'.0".ZM_EVENT_IMAGE_DIGITS.'d',$Frame->FrameId()).'-'.$show.'.jpg';
} else {
$errorText = "No image path";
} else {
$dir_events = realpath(ZM_DIR_EVENTS);
$path = realpath($dir_events . '/' . $_REQUEST['path']);
$pos = strpos($path, $dir_events);
if($pos == 0 && $pos !== false) {
if ( !empty($user['MonitorIds']) ) {
$imageOk = false;
$pathMonId = substr( $path, 0, strspn( $path, "1234567890" ) );
foreach ( preg_split( '/["\'\s]*,["\'\s]*/', $user['MonitorIds'] ) as $monId ) {
if ( $pathMonId == $monId ) {
$imageOk = true;
break;
if ( !$imageOk )
$errorText = "No image permissions";
} else {
$errorText = "Xnvalid image path" . $path;
2018-04-27 16:38:17.555639 zmc_m2 3804 INF CancelloSu: 1698000 - Capturing at 10.00 fps zm_monitor.cpp 3125
2018-04-27 16:38:08.960837 zma_m3 930 INF Backyard: 1923000 - Analysing at 10.00 fps zm_monitor.cpp 1296
2018-04-27 16:38:07.327630 web_php 16368 ERR Xnvalid image path /usr/share/zoneminder/www/views/image.php 132
2018-04-27 16:38:07.095368 web_php 16368 ERR Xnvalid image path /usr/share/zoneminder/www/views/image.php 132
2018-04-27 16:37:41.309877 zmc_m5 3778 INF Citofono: 2556000 - Capturing at 14.93 fps zm_monitor.cpp 3125
2018-04-27 16:37:31.832120 zma_m4 932 INF GarageGate: 1915000 - Analysing at 10.00 fps zm_monitor.cpp 1296
Fabio
- phpVarMontageRev.jpg (198.18 KiB) Viewed 4855 times
anybody interested I have opened issue 2094:
https://github.com/ZoneMinder/zoneminder/issues/2094
Regards
Fabio
Regards
Fabio
Hello everybody,
After a brief interaction on the developers' platform and a bit of debugging digging down to variable content, I found out that the problem was a path difference on the hour position. Zoneminder uses the file path to store date/time of the events. This difference clearly pointed out to a timezone issue.
The PHP date setup was correct but the system TZ was set to GMT, causing the checks on $path (the variable containing the path to the event images) to fail. The issue is unrelated to zoneminder but to the setup of the server.
It might be appropriate to warn about this difference which might happen for configuration error or on purpose
Kind regards
Fabio
Kind regards
Fabio
