PHP logo
PHP Version 7.0.27-0+deb9u1
System Linux T2 4.9.0-6-amd64 #1 SMP Debian 4.9.82-1+deb9u3 (2018-03-02) x86_64
Build Date Jan 5 2018 13:51:52
Server API Apache 2.0 Handler
Virtual Directory Support disabled
Configuration File (php.ini) Path /etc/php/7.0/apache2
Loaded Configuration File /etc/php/7.0/apache2/php.ini
Scan this dir for additional .ini files /etc/php/7.0/apache2/conf.d
Additional .ini files parsed /etc/php/7.0/apache2/conf.d/10-mysqlnd.ini, /etc/php/7.0/apache2/conf.d/10-opcache.ini, /etc/php/7.0/apache2/conf.d/10-pdo.ini, /etc/php/7.0/apache2/conf.d/15-xml.ini, /etc/php/7.0/apache2/conf.d/20-apcu.ini, /etc/php/7.0/apache2/conf.d/20-apcu_bc.ini, /etc/php/7.0/apache2/conf.d/20-bcmath.ini, /etc/php/7.0/apache2/conf.d/20-calendar.ini, /etc/php/7.0/apache2/conf.d/20-ctype.ini, /etc/php/7.0/apache2/conf.d/20-dom.ini, /etc/php/7.0/apache2/conf.d/20-exif.ini, /etc/php/7.0/apache2/conf.d/20-fileinfo.ini, /etc/php/7.0/apache2/conf.d/20-ftp.ini, /etc/php/7.0/apache2/conf.d/20-gd.ini, /etc/php/7.0/apache2/conf.d/20-gettext.ini, /etc/php/7.0/apache2/conf.d/20-iconv.ini, /etc/php/7.0/apache2/conf.d/20-json.ini, /etc/php/7.0/apache2/conf.d/20-mbstring.ini, /etc/php/7.0/apache2/conf.d/20-mcrypt.ini, /etc/php/7.0/apache2/conf.d/20-mysqli.ini, /etc/php/7.0/apache2/conf.d/20-pdo_mysql.ini, /etc/php/7.0/apache2/conf.d/20-phar.ini, /etc/php/7.0/apache2/conf.d/20-posix.ini, /etc/php/7.0/apache2/conf.d/20-readline.ini, /etc/php/7.0/apache2/conf.d/20-shmop.ini, /etc/php/7.0/apache2/conf.d/20-simplexml.ini, /etc/php/7.0/apache2/conf.d/20-sockets.ini, /etc/php/7.0/apache2/conf.d/20-sysvmsg.ini, /etc/php/7.0/apache2/conf.d/20-sysvsem.ini, /etc/php/7.0/apache2/conf.d/20-sysvshm.ini, /etc/php/7.0/apache2/conf.d/20-tokenizer.ini, /etc/php/7.0/apache2/conf.d/20-wddx.ini, /etc/php/7.0/apache2/conf.d/20-xmlreader.ini, /etc/php/7.0/apache2/conf.d/20-xmlwriter.ini, /etc/php/7.0/apache2/conf.d/20-xsl.ini
PHP API 20151012
PHP Extension 20151012
Zend Extension 320151012
Zend Extension Build API320151012,NTS
PHP Extension Build API20151012,NTS
Debug Build no
Thread Safety disabled
Zend Signal Handling disabled
Zend Memory Manager enabled
Zend Multibyte Support provided by mbstring
IPv6 Support enabled
DTrace Support available, disabled
Registered PHP Streams https, ftps, compress.zlib, php, file, glob, data, http, ftp, phar
Registered Stream Socket Transports tcp, udp, unix, udg, ssl, sslv2, tls, tlsv1.0, tlsv1.1, tlsv1.2
Registered Stream Filters zlib.*, string.rot13, string.toupper, string.tolower, string.strip_tags, convert.*, consumed, dechunk, convert.iconv.*, mcrypt.*, mdecrypt.*
Zend logo This program makes use of the Zend Scripting Language Engine:
Zend Engine v3.0.0, Copyright (c) 1998-2017 Zend Technologies
with Zend OPcache v7.0.27-0+deb9u1, Copyright (c) 1999-2017, by Zend Technologies
Configuration
apache2handler
Apache Version Apache/2.4.25 (Debian)
Apache API Version 20120211
Server Administrator webmaster@localhost
Hostname:Port localhost:0
User/Group www-data(33)/33
Max Requests Per Child: 0 - Keep Alive: on - Max Per Connection: 100
Timeouts Connection: 300 - Keep-Alive: 5
Virtual Server Yes
Server Root /etc/apache2
Loaded Modules core mod_so mod_watchdog http_core mod_log_config mod_logio mod_version mod_unixd mod_access_compat mod_alias mod_auth_basic mod_authn_core mod_authn_file mod_authz_core mod_authz_host mod_authz_user mod_autoindex mod_cgi mod_cgid mod_deflate mod_dir mod_env mod_filter mod_mime prefork mod_negotiation mod_php7 mod_proxy mod_proxy_fcgi mod_reqtimeout mod_rewrite mod_setenvif mod_status
Directive Local Value Master Value
engine 1 1
last_modified 0 0
xbithack 0 0
Apache Environment
Variable Value
HTTP_HOST t2
HTTP_CONNECTION keep-alive
HTTP_UPGRADE_INSECURE_REQUESTS 1
HTTP_USER_AGENT Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/65.0.3325.181 Safari/537.36
HTTP_ACCEPT text/html,application/xhtml+xml,application/xml;q=0.9,image/webp,image/apng,*/*;q=0.8
HTTP_ACCEPT_ENCODING gzip, deflate
HTTP_ACCEPT_LANGUAGE de-DE,de;q=0.9,en-US;q=0.8,en;q=0.7
HTTP_COOKIE X-OPENMEDIAVAULT-LOGIN-%242y%2410%24hjcL0Kwq0WgseEq2XRmdeueJiU%2FM.OM88oV7Il84LJcY7N5l7hSey=The+beginning+of+knowledge+is+the+discovery+of+something+we+do+not+understand.; replayMode=single; X-OPENMEDIAVAULT-LOGIN-%242y%2410%249xvvK.s4TgJS5h6EWU12EO00xfisSrSeWPsfGM9LdXJtTIUq3ubze=Fear+is+the+mind-killer.; X-OPENMEDIAVAULT-LOGIN-%242y%2410%24sSOT5r47a80BVFL%2FwRNXt.XfDseilM24uLlH9gy.g27P0LRbBPPVa=He+who+controls+the+spice+controls+the+universe.; zmMontageLayout=montage_freeform.css; zmMontageScale=33; X-OPENMEDIAVAULT-LOGIN-%242y%2410%24QE96ds%2Fi1uAAo9orZhMFT.yZLmqPuvX9NI4tr4KgWdhRT81wMwNN2=Without+change+something+sleeps+inside+us%2C+and+seldom+awakens.+The+sleeper+must+awaken.; X-OPENMEDIAVAULT-LOGIN-%242y%2410%24JD1nqzzkR12AihFAwzl%2Fq.WHMkKIkGcogCwIXsKvCVHTZ8m8uEdze=A+large+populace+held+in+check+by+a+small+but+powerful+force+is+quite+a+common+situation+in+our+universe.+And+we+know+the+major+conditions+wherein+this+large+populace+may+turn+upon+its+keepers%3A+When+they+find+a+leader.+This+is+the+most+volatile+threat+to+the+powerful%3B+they+must+retain+control+of+leaders.+When+the+populace+recognizes+its+chains.+Keep+the+populace+blind+and+unquestioning.+When+the+populace+perceives+a+hope+of+escape+from+bondage.+They+must+never+even+believe+that+escape+is+possible%21; X-OPENMEDIAVAULT-LOGIN-%242y%2410%24O8DjusksBRDxWDQUfXBaKegLqmUSJyZYoEZsgyXpUcGSBbBoOhgWK=Fear+is+the+mind-killer.; X-OPENMEDIAVAULT-SESSIONID=18gm9clur1cks0le6078k4sql2; ZMSESSID=k0vghbj1sbauugsrksp5u28a84
PATH /usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin
SERVER_SIGNATURE <address>Apache/2.4.25 (Debian) Server at t2 Port 80</address>
SERVER_SOFTWARE Apache/2.4.25 (Debian)
SERVER_NAME t2
SERVER_ADDR 192.168.0.5
SERVER_PORT 80
REMOTE_ADDR 192.168.0.109
DOCUMENT_ROOT /var/www/html
REQUEST_SCHEME http
CONTEXT_PREFIX no value
CONTEXT_DOCUMENT_ROOT /var/www/html
SERVER_ADMIN webmaster@localhost
SCRIPT_FILENAME /var/www/html/test.php
REMOTE_PORT 60261
GATEWAY_INTERFACE CGI/1.1
SERVER_PROTOCOL HTTP/1.1
REQUEST_METHOD GET
QUERY_STRING no value
REQUEST_URI /test.php
SCRIPT_NAME /test.php
HTTP Headers Information
HTTP Request Headers
HTTP Request GET /test.php HTTP/1.1
Host t2
Connection keep-alive
Upgrade-Insecure-Requests 1
User-Agent Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/65.0.3325.181 Safari/537.36
Accept text/html,application/xhtml+xml,application/xml;q=0.9,image/webp,image/apng,*/*;q=0.8
Accept-Encoding gzip, deflate
Accept-Language de-DE,de;q=0.9,en-US;q=0.8,en;q=0.7
Cookie X-OPENMEDIAVAULT-LOGIN-%242y%2410%24hjcL0Kwq0WgseEq2XRmdeueJiU%2FM.OM88oV7Il84LJcY7N5l7hSey=The+beginning+of+knowledge+is+the+discovery+of+something+we+do+not+understand.; replayMode=single; X-OPENMEDIAVAULT-LOGIN-%242y%2410%249xvvK.s4TgJS5h6EWU12EO00xfisSrSeWPsfGM9LdXJtTIUq3ubze=Fear+is+the+mind-killer.; X-OPENMEDIAVAULT-LOGIN-%242y%2410%24sSOT5r47a80BVFL%2FwRNXt.XfDseilM24uLlH9gy.g27P0LRbBPPVa=He+who+controls+the+spice+controls+the+universe.; zmMontageLayout=montage_freeform.css; zmMontageScale=33; X-OPENMEDIAVAULT-LOGIN-%242y%2410%24QE96ds%2Fi1uAAo9orZhMFT.yZLmqPuvX9NI4tr4KgWdhRT81wMwNN2=Without+change+something+sleeps+inside+us%2C+and+seldom+awakens.+The+sleeper+must+awaken.; X-OPENMEDIAVAULT-LOGIN-%242y%2410%24JD1nqzzkR12AihFAwzl%2Fq.WHMkKIkGcogCwIXsKvCVHTZ8m8uEdze=A+large+populace+held+in+check+by+a+small+but+powerful+force+is+quite+a+common+situation+in+our+universe.+And+we+know+the+major+conditions+wherein+this+large+populace+may+turn+upon+its+keepers%3A+When+they+find+a+leader.+This+is+the+most+volatile+threat+to+the+powerful%3B+they+must+retain+control+of+leaders.+When+the+populace+recognizes+its+chains.+Keep+the+populace+blind+and+unquestioning.+When+the+populace+perceives+a+hope+of+escape+from+bondage.+They+must+never+even+believe+that+escape+is+possible%21; X-OPENMEDIAVAULT-LOGIN-%242y%2410%24O8DjusksBRDxWDQUfXBaKegLqmUSJyZYoEZsgyXpUcGSBbBoOhgWK=Fear+is+the+mind-killer.; X-OPENMEDIAVAULT-SESSIONID=18gm9clur1cks0le6078k4sql2; ZMSESSID=k0vghbj1sbauugsrksp5u28a84
HTTP Response Headers
apc
APC Compatibility 1.0.3
APCu Version 5.1.3
Build Date Mar 1 2016 10:10:17
apcu
APCu Support Enabled
Version 5.1.8
APCu Debugging Disabled
MMAP Support Enabled
MMAP File Mask no value
Serialization Support php
Build Date Jan 23 2017 10:24:34
apc.coredump_unmap Off Off
apc.enable_cli Off Off
apc.enabled On On
apc.entries_hint 4096 4096
apc.gc_ttl 3600 3600
apc.mmap_file_mask no value no value
apc.preload_path no value no value
apc.serializer php php
apc.shm_segments 1 1
apc.shm_size 32M 32M
apc.slam_defense On On
apc.smart 0 0
apc.ttl 0 0
apc.use_request_time On On
apc.writable /tmp /tmp
bcmath
BCMath support enabled
bcmath.scale 0 0
calendar
Calendar support enabled
Core
allow_url_fopen On On
allow_url_include Off Off
arg_separator.input & &
arg_separator.output & &
auto_append_file no value no value
auto_globals_jit On On
auto_prepend_file no value no value
browscap no value no value
default_charset UTF-8 UTF-8
default_mimetype text/html text/html
disable_classes no value no value
disable_functions pcntl_alarm,pcntl_fork,pcntl_waitpid,pcntl_wait,pcntl_wifexited,pcntl_wifstopped,pcntl_wifsignaled,pcntl_wifcontinued,pcntl_wexitstatus,pcntl_wtermsig,pcntl_wstopsig,pcntl_signal,pcntl_signal_dispatch,pcntl_get_last_error,pcntl_strerror,pcntl_sigprocmask,pcntl_sigwaitinfo,pcntl_sigtimedwait,pcntl_exec,pcntl_getpriority,pcntl_setpriority, pcntl_alarm,pcntl_fork,pcntl_waitpid,pcntl_wait,pcntl_wifexited,pcntl_wifstopped,pcntl_wifsignaled,pcntl_wifcontinued,pcntl_wexitstatus,pcntl_wtermsig,pcntl_wstopsig,pcntl_signal,pcntl_signal_dispatch,pcntl_get_last_error,pcntl_strerror,pcntl_sigprocmask,pcntl_sigwaitinfo,pcntl_sigtimedwait,pcntl_exec,pcntl_getpriority,pcntl_setpriority,
display_errors Off Off
display_startup_errors Off Off
doc_root no value no value
docref_ext no value no value
docref_root no value no value
enable_dl Off Off
enable_post_data_reading On On
error_append_string no value no value
error_log no value no value
error_prepend_string no value no value
error_reporting 22527 22527
exit_on_timeout Off Off
expose_php Off Off
extension_dir /usr/lib/php/20151012 /usr/lib/php/20151012
file_uploads On On
highlight.comment #FF8000 #FF8000
highlight.default #0000BB #0000BB
highlight.html #000000 #000000
highlight.keyword #007700 #007700
highlight.string #DD0000 #DD0000
html_errors On On
ignore_repeated_errors Off Off
ignore_repeated_source Off Off
ignore_user_abort Off Off
implicit_flush Off Off
include_path .:/usr/share/php .:/usr/share/php
input_encoding no value no value
internal_encoding no value no value
log_errors On On
log_errors_max_len 1024 1024
mail.add_x_header On On
mail.force_extra_parameters no value no value
mail.log no value no value
max_execution_time 30 30
max_file_uploads 20 20
max_input_nesting_level 64 64
max_input_time 60 60
max_input_vars 1000 1000
memory_limit 128M 128M
open_basedir no value no value
output_buffering 4096 4096
output_encoding no value no value
output_handler no value no value
post_max_size 8M 8M
precision 14 14
realpath_cache_size 4096K 4096K
realpath_cache_ttl 120 120
register_argc_argv Off Off
report_memleaks On On
report_zend_debug On On
request_order GP GP
sendmail_from no value no value
sendmail_path /usr/sbin/sendmail -t -i /usr/sbin/sendmail -t -i
serialize_precision 17 17
short_open_tag Off Off
SMTP localhost localhost
smtp_port 25 25
sql.safe_mode Off Off
sys_temp_dir no value no value
track_errors Off Off
unserialize_callback_func no value no value
upload_max_filesize 2M 2M
upload_tmp_dir no value no value
user_dir no value no value
user_ini.cache_ttl 300 300
user_ini.filename .user.ini .user.ini
variables_order GPCS GPCS
xmlrpc_error_number 0 0
xmlrpc_errors Off Off
zend.assertions -1 -1
zend.detect_unicode On On
zend.enable_gc On On
zend.multibyte Off Off
zend.script_encoding no value no value
ctype
ctype functions enabled
date
date/time support enabled
timelib version 2016.02
"Olson" Timezone Database Version 0.system
Timezone Database internal
Default timezone Europe/Berlin
date.default_latitude 31.7667 31.7667
date.default_longitude 35.2333 35.2333
date.sunrise_zenith 90.583333 90.583333
date.sunset_zenith 90.583333 90.583333
date.timezone Europe/Berlin Europe/Berlin
dom
DOM/XML enabled
DOM/XML API Version 20031129
libxml Version 2.9.4
HTML Support enabled
XPath Support enabled
XPointer Support enabled
Schema Support enabled
RelaxNG Support enabled
exif
EXIF Support enabled
EXIF Version 7.0.27-0+deb9u1
Supported EXIF Version 0220
Supported filetypes JPEG,TIFF
exif.decode_jis_intel JIS JIS
exif.decode_jis_motorola JIS JIS
exif.decode_unicode_intel UCS-2LE UCS-2LE
exif.decode_unicode_motorola UCS-2BE UCS-2BE
exif.encode_jis no value no value
exif.encode_unicode ISO-8859-15 ISO-8859-15
fileinfo
fileinfo support enabled
version 1.0.5
libmagic 522
filter
Input Validation and Filtering enabled
Revision $Id: 28fcca4bfda9c9907588a64d245b49cb398249d8 $
filter.default unsafe_raw unsafe_raw
filter.default_flags no value no value
ftp
FTP support enabled
FTPS support enabled
gd
GD Support enabled
GD headers Version 2.2.4
GD library Version 2.2.4
FreeType Support enabled
FreeType Linkage with freetype
FreeType Version 2.6.3
GIF Read Support enabled
GIF Create Support enabled
JPEG Support enabled
libJPEG Version 6b
PNG Support enabled
libPNG Version 1.6.28
WBMP Support enabled
XPM Support enabled
libXpm Version 30411
XBM Support enabled
WebP Support enabled
gd.jpeg_ignore_warning 0 0
gettext
GetText Support enabled
hash
hash support enabled
Hashing Engines md2 md4 md5 sha1 sha224 sha256 sha384 sha512 ripemd128 ripemd160 ripemd256 ripemd320 whirlpool tiger128,3 tiger160,3 tiger192,3 tiger128,4 tiger160,4 tiger192,4 snefru snefru256 gost gost-crypto adler32 crc32 crc32b fnv132 fnv1a32 fnv164 fnv1a64 joaat haval128,3 haval160,3 haval192,3 haval224,3 haval256,3 haval128,4 haval160,4 haval192,4 haval224,4 haval256,4 haval128,5 haval160,5 haval192,5 haval224,5 haval256,5
MHASH support Enabled
MHASH API Version Emulated Support
iconv
iconv support enabled
iconv implementation glibc
iconv library version 2.24
iconv.input_encoding no value no value
iconv.internal_encoding no value no value
iconv.output_encoding no value no value
json
json support enabled
json version 1.4.0
libxml
libXML support active
libXML Compiled Version 2.9.4
libXML Loaded Version 20904
libXML streams enabled
mbstring
Multibyte Support enabled
Multibyte string engine libmbfl
HTTP input encoding translation disabled
libmbfl version 1.3.2
oniguruma version 5.9.6
mbstring extension makes use of "streamable kanji code filter and converter", which is distributed under the GNU Lesser General Public License version 2.1.
Multibyte (japanese) regex support enabled
Multibyte regex (oniguruma) backtrack check On
Multibyte regex (oniguruma) version 5.9.6
mbstring.detect_order no value no value
mbstring.encoding_translation Off Off
mbstring.func_overload 0 0
mbstring.http_input no value no value
mbstring.http_output no value no value
mbstring.http_output_conv_mimetypes ^(text/|application/xhtml\+xml) ^(text/|application/xhtml\+xml)
mbstring.internal_encoding no value no value
mbstring.language neutral neutral
mbstring.strict_detection Off Off
mbstring.substitute_character no value no value
mcrypt
mcrypt support enabled
mcrypt_filter support enabled
Version 2.5.8
Api No 20021217
Supported ciphers cast-128 gost rijndael-128 twofish arcfour cast-256 loki97 rijndael-192 saferplus wake blowfish-compat des rijndael-256 serpent xtea blowfish enigma rc2 tripledes
Supported modes cbc cfb ctr ecb ncfb nofb ofb stream
mcrypt.algorithms_dir no value no value
mcrypt.modes_dir no value no value
mysqli
MysqlI Support enabled
Client API library version mysqlnd 5.0.12-dev - 20150407 - $Id: b5c5906d452ec590732a93b051f3827e02749b83 $
Active Persistent Links 0
Inactive Persistent Links 0
Active Links 0
mysqli.allow_local_infile On On
mysqli.allow_persistent On On
mysqli.default_host no value no value
mysqli.default_port 3306 3306
mysqli.default_pw no value no value
mysqli.default_socket no value no value
mysqli.default_user no value no value
mysqli.max_links Unlimited Unlimited
mysqli.max_persistent Unlimited Unlimited
mysqli.reconnect Off Off
mysqli.rollback_on_cached_plink Off Off
mysqlnd
mysqlnd enabled
Version mysqlnd 5.0.12-dev - 20150407 - $Id: b5c5906d452ec590732a93b051f3827e02749b83 $
Compression supported
core SSL supported
extended SSL supported
Command buffer size 4096
Read buffer size 32768
Read timeout 31536000
Collecting statistics Yes
Collecting memory statistics No
Tracing n/a
Loaded plugins mysqlnd,debug_trace,auth_plugin_mysql_native_password,auth_plugin_mysql_clear_password,auth_plugin_sha256_password
API Extensions mysqli,pdo_mysql
mysqlnd statistics
bytes_sent 2970
bytes_received 247142
packets_sent 44
packets_received 546
protocol_overhead_in 2184
protocol_overhead_out 176
bytes_received_ok_packet 0
bytes_received_eof_packet 0
bytes_received_rset_header_packet 72
bytes_received_rset_field_meta_packet 0
bytes_received_rset_row_packet 54
bytes_received_prepare_response_packet 3568
bytes_received_change_user_packet 243116
packets_sent_command 20
packets_received_ok 0
packets_received_eof 0
packets_received_rset_header 8
packets_received_rset_field_meta 0
packets_received_rset_row 6
packets_received_prepare_response 84
packets_received_change_user 438
result_set_queries 2
non_result_set_queries 4
no_index_used 2
bad_index_used 0
slow_queries 0
buffered_sets 0
unbuffered_sets 0
ps_buffered_sets 2
ps_unbuffered_sets 0
flushed_normal_sets 0
flushed_ps_sets 0
ps_prepared_never_executed 0
ps_prepared_once_executed 6
rows_fetched_from_server_normal 0
rows_fetched_from_server_ps 436
rows_buffered_from_client_normal 0
rows_buffered_from_client_ps 436
rows_fetched_from_client_normal_buffered 0
rows_fetched_from_client_normal_unbuffered 0
rows_fetched_from_client_ps_buffered 436
rows_fetched_from_client_ps_unbuffered 0
rows_fetched_from_client_ps_cursor 0
rows_affected_normal 0
rows_affected_ps 0
rows_skipped_normal 0
rows_skipped_ps 436
copy_on_write_saved 0
copy_on_write_performed 0
command_buffer_too_small 0
connect_success 2
connect_failure 0
connection_reused 0
reconnect 0
pconnect_success 0
active_connections 18446744073709551614
active_persistent_connections 0
explicit_close 2
implicit_close 0
disconnect_close 0
in_middle_of_command_close 0
explicit_free_result 8
implicit_free_result 0
explicit_stmt_close 6
implicit_stmt_close 0
mem_emalloc_count 0
mem_emalloc_amount 0
mem_ecalloc_count 0
mem_ecalloc_amount 0
mem_erealloc_count 0
mem_erealloc_amount 0
mem_efree_count 0
mem_efree_amount 0
mem_malloc_count 0
mem_malloc_amount 0
mem_calloc_count 0
mem_calloc_amount 0
mem_realloc_count 0
mem_realloc_amount 0
mem_free_count 0
mem_free_amount 0
mem_estrndup_count 0
mem_strndup_count 0
mem_estndup_count 0
mem_strdup_count 0
proto_text_fetched_null 0
proto_text_fetched_bit 0
proto_text_fetched_tinyint 0
proto_text_fetched_short 0
proto_text_fetched_int24 0
proto_text_fetched_int 0
proto_text_fetched_bigint 0
proto_text_fetched_decimal 0
proto_text_fetched_float 0
proto_text_fetched_double 0
proto_text_fetched_date 0
proto_text_fetched_year 0
proto_text_fetched_time 0
proto_text_fetched_datetime 0
proto_text_fetched_timestamp 0
proto_text_fetched_string 0
proto_text_fetched_blob 0
proto_text_fetched_enum 0
proto_text_fetched_set 0
proto_text_fetched_geometry 0
proto_text_fetched_other 0
proto_binary_fetched_null 0
proto_binary_fetched_bit 0
proto_binary_fetched_tinyint 0
proto_binary_fetched_short 436
proto_binary_fetched_int24 436
proto_binary_fetched_int 0
proto_binary_fetched_bigint 0
proto_binary_fetched_decimal 0
proto_binary_fetched_float 0
proto_binary_fetched_double 0
proto_binary_fetched_date 0
proto_binary_fetched_year 0
proto_binary_fetched_time 0
proto_binary_fetched_datetime 0
proto_binary_fetched_timestamp 0
proto_binary_fetched_string 0
proto_binary_fetched_json 872
proto_binary_fetched_blob 3924
proto_binary_fetched_enum 0
proto_binary_fetched_set 0
proto_binary_fetched_geometry 0
proto_binary_fetched_other 0
init_command_executed_count 0
init_command_failed_count 0
com_quit 2
com_init_db 0
com_query 0
com_field_list 0
com_create_db 0
com_drop_db 0
com_refresh 0
com_shutdown 0
com_statistics 0
com_process_info 0
com_connect 0
com_process_kill 0
com_debug 0
com_ping 0
com_time 0
com_delayed_insert 0
com_change_user 0
com_binlog_dump 0
com_table_dump 0
com_connect_out 0
com_register_slave 0
com_stmt_prepare 6
com_stmt_execute 6
com_stmt_send_long_data 0
com_stmt_close 6
com_stmt_reset 0
com_stmt_set_option 0
com_stmt_fetch 0
com_deamon 0
bytes_received_real_data_normal 0
bytes_received_real_data_ps 234640
openssl
OpenSSL support enabled
OpenSSL Library Version OpenSSL 1.1.0f 25 May 2017
OpenSSL Header Version OpenSSL 1.1.0f 25 May 2017
Openssl default config /usr/lib/ssl/openssl.cnf
openssl.cafile no value no value
openssl.capath no value no value
pcre
PCRE (Perl Compatible Regular Expressions) Support enabled
PCRE Library Version 8.39 2016-06-14
PCRE JIT Support enabled
pcre.backtrack_limit 1000000 1000000
pcre.jit 1 1
pcre.recursion_limit 100000 100000
PDO
PDO support enabled
PDO drivers mysql
pdo_mysql
PDO Driver for MySQL enabled
Client API version mysqlnd 5.0.12-dev - 20150407 - $Id: b5c5906d452ec590732a93b051f3827e02749b83 $
pdo_mysql.default_socket /var/run/mysqld/mysqld.sock /var/run/mysqld/mysqld.sock
Phar
Phar: PHP Archive support enabled
Phar EXT version 2.0.2
Phar API version 1.1.1
SVN revision $Id: 9d91fd26ae99260111b934cc25174387d4bd7059 $
Phar-based phar archives enabled
Tar-based phar archives enabled
ZIP-based phar archives enabled
gzip compression enabled
bzip2 compression disabled (install pecl/bz2)
Native OpenSSL support enabled
Phar based on pear/PHP_Archive, original concept by Davey Shafik.
Phar fully realized by Gregory Beaver and Marcus Boerger.
Portions of tar implementation Copyright (c) 2003-2009 Tim Kientzle.
phar.cache_list no value no value
phar.readonly On On
phar.require_hash On On
posix
Revision $Id: b691ca925e7a085e6929579c4eba8fed0732e0ef $
readline
Readline Support enabled
Readline library EditLine wrapper
cli.pager no value no value
cli.prompt \b \> \b \>
Reflection
Reflection enabled
Version $Id: e5303663dcb329e17818853ff223e5ee01481f2c $
session
Session Support enabled
Registered save handlers files user
Registered serializer handlers php_serialize php php_binary wddx
session.auto_start Off Off
session.cache_expire 180 180
session.cache_limiter nocache nocache
session.cookie_domain no value no value
session.cookie_httponly Off Off
session.cookie_lifetime 0 0
session.cookie_path / /
session.cookie_secure Off Off
session.entropy_file /dev/urandom /dev/urandom
session.entropy_length 32 32
session.gc_divisor 1000 1000
session.gc_maxlifetime 1440 1440
session.gc_probability 0 0
session.hash_bits_per_character 5 5
session.hash_function 0 0
session.lazy_write On On
session.name PHPSESSID PHPSESSID
session.referer_check no value no value
session.save_handler files files
session.save_path /var/lib/php/sessions /var/lib/php/sessions
session.serialize_handler php php
session.upload_progress.cleanup On On
session.upload_progress.enabled On On
session.upload_progress.freq 1% 1%
session.upload_progress.min_freq 1 1
session.upload_progress.name PHP_SESSION_UPLOAD_PROGRESS PHP_SESSION_UPLOAD_PROGRESS
session.upload_progress.prefix upload_progress_ upload_progress_
session.use_cookies On On
session.use_only_cookies On On
session.use_strict_mode Off Off
session.use_trans_sid 0 0
shmop
shmop support enabled
SimpleXML
Simplexml support enabled
Revision $Id: 0637e06af859ca1d0dea9c2f1530e51b98f1970e $
Schema support enabled
sockets
Sockets Support enabled
SPL
SPL support enabled
Interfaces Countable, OuterIterator, RecursiveIterator, SeekableIterator, SplObserver, SplSubject
Classes AppendIterator, ArrayIterator, ArrayObject, BadFunctionCallException, BadMethodCallException, CachingIterator, CallbackFilterIterator, DirectoryIterator, DomainException, EmptyIterator, FilesystemIterator, FilterIterator, GlobIterator, InfiniteIterator, InvalidArgumentException, IteratorIterator, LengthException, LimitIterator, LogicException, MultipleIterator, NoRewindIterator, OutOfBoundsException, OutOfRangeException, OverflowException, ParentIterator, RangeException, RecursiveArrayIterator, RecursiveCachingIterator, RecursiveCallbackFilterIterator, RecursiveDirectoryIterator, RecursiveFilterIterator, RecursiveIteratorIterator, RecursiveRegexIterator, RecursiveTreeIterator, RegexIterator, RuntimeException, SplDoublyLinkedList, SplFileInfo, SplFileObject, SplFixedArray, SplHeap, SplMinHeap, SplMaxHeap, SplObjectStorage, SplPriorityQueue, SplQueue, SplStack, SplTempFileObject, UnderflowException, UnexpectedValueException
standard
Dynamic Library Support enabled
Path to sendmail /usr/sbin/sendmail -t -i
assert.active 1 1
assert.bail 0 0
assert.callback no value no value
assert.exception 0 0
assert.quiet_eval 0 0
assert.warning 1 1
auto_detect_line_endings 0 0
default_socket_timeout 60 60
url_rewriter.tags a=href,area=href,frame=src,input=src,form=fakeentry a=href,area=href,frame=src,input=src,form=fakeentry
user_agent no value no value
sysvmsg
sysvmsg support enabled
Revision $Id: dfb999763f95bfe9609fae60b4e07a492888ec7c $
sysvsem
sysvshm
tokenizer
Tokenizer Support enabled
wddx
WDDX Support enabled
WDDX Session Serializer enabled
xml
XML Support active
XML Namespace Support active
libxml2 Version 2.9.4
xmlreader
XMLReader enabled
xmlwriter
XMLWriter enabled
xsl
XSL enabled
libxslt Version 1.1.29
libxslt compiled against libxml Version 2.9.4
EXSLT enabled
libexslt Version 1.1.29
Zend OPcache
Opcode Caching Up and Running
Optimization Enabled
SHM Cache Enabled
File Cache Disabled
Startup OK
Shared memory model mmap
Cache hits 82
Cache misses 23
Used memory 9794664
Free memory 57314200
Wasted memory 0
Interned Strings Used memory 358632
Interned Strings Free memory 3835672
Cached scripts 23
Cached keys 44
Max keys 3907
OOM restarts 0
Hash keys restarts 0
Manual restarts 0
opcache.blacklist_filename no value no value
opcache.consistency_checks 0 0
opcache.dups_fix Off Off
opcache.enable On On
opcache.enable_cli Off Off
opcache.enable_file_override Off Off
opcache.error_log no value no value
opcache.fast_shutdown 0 0
opcache.file_cache no value no value
opcache.file_cache_consistency_checks 1 1
opcache.file_cache_only 0 0
opcache.file_update_protection 2 2
opcache.force_restart_timeout 180 180
opcache.huge_code_pages Off Off
opcache.inherited_hack On On
opcache.interned_strings_buffer 4 4
opcache.lockfile_path /tmp /tmp
opcache.log_verbosity_level 1 1
opcache.max_accelerated_files 2000 2000
opcache.max_file_size 0 0
opcache.max_wasted_percentage 5 5
opcache.memory_consumption 64 64
opcache.optimization_level 0x7FFFBFFF 0x7FFFBFFF
opcache.preferred_memory_model no value no value
opcache.protect_memory 0 0
opcache.restrict_api no value no value
opcache.revalidate_freq 2 2
opcache.revalidate_path Off Off
opcache.save_comments 1 1
opcache.use_cwd On On
opcache.validate_permission Off Off
opcache.validate_root Off Off
opcache.validate_timestamps On On
zlib
ZLib Support enabled
Stream Wrapper compress.zlib://
Stream Filter zlib.inflate, zlib.deflate
Compiled Version 1.2.8
Linked Version 1.2.8
zlib.output_compression Off Off
zlib.output_compression_level -1 -1
zlib.output_handler no value no value
Additional Modules
Module Name
Environment
Variable Value
APACHE_RUN_DIR /var/run/apache2
APACHE_PID_FILE /var/run/apache2/apache2.pid
JOURNAL_STREAM 8:4693701
INVOCATION_ID 3083c76c88da44678c9ce9dee59971b0
APACHE_LOCK_DIR /var/lock/apache2
LANG C
APACHE_RUN_USER www-data
APACHE_RUN_GROUP www-data
APACHE_LOG_DIR /var/log/apache2
PWD /
PHP Variables
Variable Value
$_COOKIE['X-OPENMEDIAVAULT-LOGIN-$2y$10$hjcL0Kwq0WgseEq2XRmdeueJiU/M_OM88oV7Il84LJcY7N5l7hSey'] The beginning of knowledge is the discovery of something we do not understand.
$_COOKIE['replayMode'] single
$_COOKIE['X-OPENMEDIAVAULT-LOGIN-$2y$10$9xvvK_s4TgJS5h6EWU12EO00xfisSrSeWPsfGM9LdXJtTIUq3ubze'] Fear is the mind-killer.
$_COOKIE['X-OPENMEDIAVAULT-LOGIN-$2y$10$sSOT5r47a80BVFL/wRNXt_XfDseilM24uLlH9gy_g27P0LRbBPPVa'] He who controls the spice controls the universe.
$_COOKIE['zmMontageLayout'] montage_freeform.css
$_COOKIE['zmMontageScale'] 33
$_COOKIE['X-OPENMEDIAVAULT-LOGIN-$2y$10$QE96ds/i1uAAo9orZhMFT_yZLmqPuvX9NI4tr4KgWdhRT81wMwNN2'] Without change something sleeps inside us, and seldom awakens. The sleeper must awaken.
$_COOKIE['X-OPENMEDIAVAULT-LOGIN-$2y$10$JD1nqzzkR12AihFAwzl/q_WHMkKIkGcogCwIXsKvCVHTZ8m8uEdze'] A large populace held in check by a small but powerful force is quite a common situation in our universe. And we know the major conditions wherein this large populace may turn upon its keepers: When they find a leader. This is the most volatile threat to the powerful; they must retain control of leaders. When the populace recognizes its chains. Keep the populace blind and unquestioning. When the populace perceives a hope of escape from bondage. They must never even believe that escape is possible!
$_COOKIE['X-OPENMEDIAVAULT-LOGIN-$2y$10$O8DjusksBRDxWDQUfXBaKegLqmUSJyZYoEZsgyXpUcGSBbBoOhgWK'] Fear is the mind-killer.
$_COOKIE['X-OPENMEDIAVAULT-SESSIONID'] 18gm9clur1cks0le6078k4sql2
$_COOKIE['ZMSESSID'] k0vghbj1sbauugsrksp5u28a84
$_SERVER['HTTP_HOST'] t2
$_SERVER['HTTP_CONNECTION'] keep-alive
$_SERVER['HTTP_UPGRADE_INSECURE_REQUESTS'] 1
$_SERVER['HTTP_USER_AGENT'] Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/65.0.3325.181 Safari/537.36
$_SERVER['HTTP_ACCEPT'] text/html,application/xhtml+xml,application/xml;q=0.9,image/webp,image/apng,*/*;q=0.8
$_SERVER['HTTP_ACCEPT_ENCODING'] gzip, deflate
$_SERVER['HTTP_ACCEPT_LANGUAGE'] de-DE,de;q=0.9,en-US;q=0.8,en;q=0.7
$_SERVER['HTTP_COOKIE'] X-OPENMEDIAVAULT-LOGIN-%242y%2410%24hjcL0Kwq0WgseEq2XRmdeueJiU%2FM.OM88oV7Il84LJcY7N5l7hSey=The+beginning+of+knowledge+is+the+discovery+of+something+we+do+not+understand.; replayMode=single; X-OPENMEDIAVAULT-LOGIN-%242y%2410%249xvvK.s4TgJS5h6EWU12EO00xfisSrSeWPsfGM9LdXJtTIUq3ubze=Fear+is+the+mind-killer.; X-OPENMEDIAVAULT-LOGIN-%242y%2410%24sSOT5r47a80BVFL%2FwRNXt.XfDseilM24uLlH9gy.g27P0LRbBPPVa=He+who+controls+the+spice+controls+the+universe.; zmMontageLayout=montage_freeform.css; zmMontageScale=33; X-OPENMEDIAVAULT-LOGIN-%242y%2410%24QE96ds%2Fi1uAAo9orZhMFT.yZLmqPuvX9NI4tr4KgWdhRT81wMwNN2=Without+change+something+sleeps+inside+us%2C+and+seldom+awakens.+The+sleeper+must+awaken.; X-OPENMEDIAVAULT-LOGIN-%242y%2410%24JD1nqzzkR12AihFAwzl%2Fq.WHMkKIkGcogCwIXsKvCVHTZ8m8uEdze=A+large+populace+held+in+check+by+a+small+but+powerful+force+is+quite+a+common+situation+in+our+universe.+And+we+know+the+major+conditions+wherein+this+large+populace+may+turn+upon+its+keepers%3A+When+they+find+a+leader.+This+is+the+most+volatile+threat+to+the+powerful%3B+they+must+retain+control+of+leaders.+When+the+populace+recognizes+its+chains.+Keep+the+populace+blind+and+unquestioning.+When+the+populace+perceives+a+hope+of+escape+from+bondage.+They+must+never+even+believe+that+escape+is+possible%21; X-OPENMEDIAVAULT-LOGIN-%242y%2410%24O8DjusksBRDxWDQUfXBaKegLqmUSJyZYoEZsgyXpUcGSBbBoOhgWK=Fear+is+the+mind-killer.; X-OPENMEDIAVAULT-SESSIONID=18gm9clur1cks0le6078k4sql2; ZMSESSID=k0vghbj1sbauugsrksp5u28a84
$_SERVER['PATH'] /usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin
$_SERVER['SERVER_SIGNATURE'] <address>Apache/2.4.25 (Debian) Server at t2 Port 80</address>
$_SERVER['SERVER_SOFTWARE'] Apache/2.4.25 (Debian)
$_SERVER['SERVER_NAME'] t2
$_SERVER['SERVER_ADDR'] 192.168.0.5
$_SERVER['SERVER_PORT'] 80
$_SERVER['REMOTE_ADDR'] 192.168.0.109
$_SERVER['DOCUMENT_ROOT'] /var/www/html
$_SERVER['REQUEST_SCHEME'] http
$_SERVER['CONTEXT_PREFIX'] no value
$_SERVER['CONTEXT_DOCUMENT_ROOT'] /var/www/html
$_SERVER['SERVER_ADMIN'] webmaster@localhost
$_SERVER['SCRIPT_FILENAME'] /var/www/html/test.php
$_SERVER['REMOTE_PORT'] 60261
$_SERVER['GATEWAY_INTERFACE'] CGI/1.1
$_SERVER['SERVER_PROTOCOL'] HTTP/1.1
$_SERVER['REQUEST_METHOD'] GET
$_SERVER['QUERY_STRING'] no value
$_SERVER['REQUEST_URI'] /test.php
$_SERVER['SCRIPT_NAME'] /test.php
$_SERVER['PHP_SELF'] /test.php
$_SERVER['REQUEST_TIME_FLOAT'] 1523521729.471
$_SERVER['REQUEST_TIME'] 1523521729
