Foscam FI8918w control not working
kfrank
Post by kfrank »
When I click any of the controls for my camera I get the following errors in my logs(and no movement from the camera):
2018-04-04 13:52:46.017830 zmcontrol 24129 ERR Cmd:HTTP::Request=HASH(0x2a85a30) zmcontrol.pl
2018-04-04 13:52:45.917550 zmcontrol 24129 ERR Error REALLY check failed:'500 Can't connect to 172.17.255.235:80' zmcontrol.pl
Any help would be appreciated.
The error appears to be coming from here in the FI8918W.pm control script:
sub sendCmd
        my $self = shift;
        my $cmd = shift;
        my $result = undef;
        printMsg( $cmd, "Tx" );
        # PP Old cameras also support onstep=1 but it is too granular. Instead using moveCon and stop after interval
        # PP - cleaned up URL to take it properly from Control device
        # Control device needs to be of format user=xxx&pwd=yyy
        my $req = HTTP::Request->new( GET=>"http://".$self->{Monitor}->{ControlAddress}."/$cmd"."&".$self->{Monitor}->{ControlDevice});
        print ("Sending $req\n");
        if ( $res->is_success )
                $result = !undef;
        else
                Error( "Error REALLY check failed:'".$res->status_line()."'" );
                Error ("Cmd:".$req);
        return( $result );
However, if I use the string produced by "http://".$self->{Monitor}->{ControlAddress}."/$cmd"."&".$self->{Monitor}->{ControlDevice}" it produces a url that when sent in my browser does move the camera in the proper direction.
Re: Foscam FI8918w control not working
See: https://wiki.zoneminder.com/Foscam_FI8918W
For an older version of Zoneminder but should still work.
kfrank
Post by kfrank »
All my settings are correct as far as "https://wiki.zoneminder.com/Foscam_FI8918W" is concerned.
Camera is on port 80 as well.
Thanks for the suggestion bbunge. Any other ideas? Based on the errors I'm getting?
authentication problem with the hash when sending the movement command url?
kfrank
Post by kfrank »
That is what it looks like rockedge. Just don't know where to fix it :P
Paranoid
Post by Paranoid »
But does it produce a URL that when sent via the command line moves the camera? It might be that you have logged into the camera with the browser so when you send the command that way it authenticates.
Try this on the command line:
wget "http://172.17.255.235:80/decoder_control.cgi?command=2&user=xxx&pwd=yyy"
and see if the camera moves
Paranoid
Post by Paranoid »
Does your password contain any characters such as "&$%*"? If so try changing it to simple password and see if you get the same errors.
