Zoneminder 1.30.4 on Ubuntu Bionic 18.04 Nightly Build
jsylvia007
Re: Zoneminder 1.30.4 on Ubuntu Bionic 18.04 Nightly Build
Post by jsylvia007 » Wed Aug 29, 2018 1:45 am
bbunge wrote:
Wed Aug 29, 2018 1:36 am
Actually there is a package for ZM 1.30.4 on Bionic. See the WIKI. It is for 64 bit OS (AMD64) only as that is what I decided to work on and most folks can run 64 BIT OS. If not stick with Ubuntu 16.04.
I understand there is a package, but a PPA implies updates and changes to include automatic updates via the package managers. Just a .Deb file doesn't have those things.
Post by rockedge » Wed Aug 29, 2018 12:36 pm
bbunge wrote:It is for 64 bit OS (AMD64) only as that is what I decided to work on and most folks can run 64 BIT OS
not me and the entire cast of people using or wanting to use some older machines that kick 32bit ass. Just another developer deciding what is best for me? Sorry I need one that is 32 bit....runs great for me and the most stable and best running zoneminder is the Tahr version running on 32 bit machines....rock solid. I just need the same thing for Bionic....makes sense cause I am not recommending to anyone to trash the perfectly good machine because "every one ...or most people are"....running 64 bit.......
Post by bbunge » Wed Aug 29, 2018 5:23 pm
I'll get to work on an i386 version. Should have it ready within a day.
Post by rockedge » Wed Aug 29, 2018 5:56 pm
Thank you bbunge for the hard work and taking the time to create a version.
Post by bbunge » Wed Aug 29, 2018 7:49 pm
OK Folks, here are links to your i386 package for Bionic:
https://173.163.189.225/zoneminder-1.30 ... c-i386.deb
wget --no-check-certificate https://173.163.189.225/zoneminder-1.30 ... c-i386.deb -P /tmp/
https://drive.google.com/file/d/1cgPOr2 ... sp=sharing
Install procedure is the same for the AMD64 version. Just use the zoneminder-1.30.4-bionic-i386.deb file. I did a quick test with local and IP cameras and checked the API with Zmninja.
jquerius
Post by jquerius » Fri Sep 14, 2018 5:02 pm
Thank you bbunge for creating the i386 version. I unfortunately setup my home server with OpenVPN on Ubuntu 18.04 and didn't want to wipe and start over with 16.04. Installed ZM last night and everything is good to go now. You rock!
Post by bbunge » Fri Nov 15, 2019 11:41 pm
package has been moved. See: viewforum.php?f=36&sid=a2544c7021c60de89925fac4c06201ba
Users browsing this forum: No registered users and 9 guests
