Well I've got the dreaded "the service keeps stopping" issue, here goes.
The system is a newly-installed Fedora 27 system with the latest updates and ZM 1.30.4. Camera is a HikVision DS-2CD2012-I. Video is set to 1280x960, variable bitrate, medium quality, 15fps, max bitrate 2048kbps. The source is set up as Mocord, it's ffmpeg, 32bit color, 1280x960, using RTSP over TCP.
It looks like the connection drops, and then ZoneMinder completely poops the bed. You'd think that ZM would be able to handle a glitch here and there and just move on? What's wrong here? What other information do I need to be able to troubleshoot this?
2018-03-21 21:56:05.141437 zmf 23888 INF Got signal 15 (Terminated), exiting zm_signal.cpp 40
2018-03-21 21:56:05.137658 zmc_m3 23886 INF Got signal 15 (Terminated), exiting zm_signal.cpp 40
2018-03-21 21:56:04.379950 zmdc 23857 INF 'zma -m 3' exited normally zmdc.pl
2018-03-21 21:56:04.007068 zmf 23888 WAR Socket closed at remote end zmf.cpp 269
2018-03-21 21:56:03.923310 zmdc 23857 WAR 'zma -m 3' has not stopped at 18/03/21 21:56:03. Sending KILL to pid 15288 zmdc.pl
2018-03-21 21:56:02.733816 zmc_m3 23886 WAR Buffer overrun at index 118, image 46018, slow down capture, speed up analysis or increase ring buffer size zm_monitor.cpp 3094
2018-03-21 21:56:00.996380 zma_m3 15288 INF Laundry: 032 - Closing event 3738, shutting down zm_monitor.cpp 625
2018-03-21 21:56:00.429404 zmc_m3 23886 WAR Buffer overrun at index 114, image 46014, slow down capture, speed up analysis or increase ring buffer size zm_monitor.cpp 3094
2018-03-21 21:55:57.918197 zma_m3 15288 INF Got signal 15 (Terminated), exiting zm_signal.cpp 40
2018-03-21 21:55:57.847443 zmc_m3 23886 INF Laundry: 46000 - Capturing at 15.15 fps zm_monitor.cpp 3125
2018-03-21 21:55:54.697410 zmdc 23857 INF 'zma -m 3' sending stop to pid 15288 at 18/03/21 21:55:54 zmdc.pl
2018-03-21 21:55:52.284930 zmwatch 23911 INF Restarting analysis daemon for Laundry zmwatch.pl
2018-03-21 21:55:50.148640 zmwatch 23911 INF Analysis daemon for Laundry needs restarting, time since last analysis 8 seconds (1521683750-1521683742) zmwatch.pl
2018-03-21 21:55:48.561511 zmc_m3 23886 WAR Buffer overrun at index 109, image 45859, slow down capture, speed up analysis or increase ring buffer size zm_monitor.cpp 3094
2018-03-21 21:55:41.265797 zma_m3 15288 INF Laundry: 026 - Opening new event 3738, section start zm_monitor.cpp 1541
2018-03-21 21:55:40.538030 zmf 23888 INF Frame server socket open, awaiting images zmf.cpp 119
2018-03-21 21:55:40.191830 zma_m3 15288 INF In mode 5/1, warming up zma.cpp 142
2018-03-21 21:55:39.489580 zmdc 15288 INF 'zma -m 3' started at 18/03/21 21:55:39 zmdc.pl
2018-03-21 21:55:39.489420 zmdc 23857 INF 'zma -m 3' starting at 18/03/21 21:55:39, pid = 15288 zmdc.pl
2018-03-21 21:55:37.695280 zmwatch 23911 INF Restarting analysis daemon for Laundry zmwatch.pl
2018-03-21 21:55:35.860320 zmwatch 23911 ERR Error getting last capture time for Laundry zmwatch.pl
2018-03-21 21:55:23.804130 zmdc 23857 INF 'zma -m 3' exited normally zmdc.pl
2018-03-21 21:55:23.803752 zmf 23888 WAR Socket closed at remote end zmf.cpp 269
2018-03-21 21:55:20.385420 zma_m3 15014 INF Laundry: 029 - Closing event 3737, shutting down zm_monitor.cpp 625
ZoneMinder Crashing
Re: ZoneMinder Crashing
you are reaching some kind of memory limit it looks like. Buffer overrun....have you tried running the camera at a lower res to see if the crash persists? What is your /dev/shm look like?
I haven't tried running it at a lower res... I'll give that a shot, although I'd think the machine should be good enough to run at native res. It's only writing about 3MB/sec to the disk (which is well under the capacity) and /dev/shm is sitting around 20%. Still, even with buffer overruns, shouldn't the thing be able to recover itself and not die completely?
Also turn off zmf...
Here are more logs. This time it ran for ~45 minutes before it died. I'm going to try reducing resolution to 640x480 next.
2018-03-22 11:56:56.395568 zmc_m3 31020 INF Got signal 15 (Terminated), exiting zm_signal.cpp 40
2018-03-22 11:56:54.529055 zmc_m3 31020 WAR Last image read from shared memory 1521734214 seconds ago, zma may have gone away zm_monitor.cpp 3100
2018-03-22 11:56:54.528790 zmdc 10843 INF 'zma -m 3' exited normally zmdc.pl
2018-03-22 11:56:52.388166 zmc_m3 31020 WAR Buffer overrun at index 71, image 14771, slow down capture, speed up analysis or increase ring buffer size zm_monitor.cpp 3094
2018-03-22 11:56:52.148690 zmdc 10843 WAR 'zma -m 3' has not stopped at 18/03/22 11:56:52. Sending KILL to pid 6259 zmdc.pl
2018-03-22 11:56:49.657956 zma_m3 6259 INF Laundry: 029 - Closing event 3778, shutting down zm_monitor.cpp 625
2018-03-22 11:56:46.146716 zma_m3 6259 INF Got signal 15 (Terminated), exiting zm_signal.cpp 40
2018-03-22 11:56:43.660760 zmdc 10843 INF 'zma -m 3' sending stop to pid 6259 at 18/03/22 11:56:43 zmdc.pl
2018-03-22 11:56:43.412413 zmc_m3 31020 WAR Buffer overrun at index 61, image 14611, slow down capture, speed up analysis or increase ring buffer size zm_monitor.cpp 3094
2018-03-22 11:56:40.205660 zmwatch 10882 INF Restarting analysis daemon for Laundry zmwatch.pl
2018-03-22 11:56:40.141866 zmc_m3 31020 WAR Buffer overrun at index 37, image 14587, slow down capture, speed up analysis or increase ring buffer size zm_monitor.cpp 3094
2018-03-22 11:56:37.386270 zmwatch 10882 INF Analysis daemon for Laundry needs restarting, time since last analysis 7 seconds (1521734197-1521734190) zmwatch.pl
2018-03-22 11:56:33.566697 zma_m3 6259 INF Laundry: 026 - Opening new event 3778, section start zm_monitor.cpp 1541
2018-03-22 11:56:27.435005 zma_m3 6259 INF In mode 5/1, warming up zma.cpp 142
2018-03-22 11:56:25.431570 zmdc 6259 INF 'zma -m 3' started at 18/03/22 11:56:25 zmdc.pl
2018-03-22 11:56:25.431560 zmdc 10843 INF 'zma -m 3' starting at 18/03/22 11:56:25, pid = 6259 zmdc.pl
2018-03-22 11:56:19.156650 zmwatch 10882 INF Restarting analysis daemon for Laundry zmwatch.pl
2018-03-22 11:56:15.914930 zmwatch 10882 INF Analysis daemon for Laundry needs restarting, time since last analysis 20 seconds (1521734175-1521734155) zmwatch.pl
2018-03-22 11:56:09.674590 zmc_m3 31020 WAR Last image read from shared memory 14 seconds ago, zma may have gone away zm_monitor.cpp 3100
2018-03-22 11:56:07.308823 zmc_m3 31020 WAR Buffer overrun at index 126, image 14076, slow down capture, speed up analysis or increase ring buffer size zm_monitor.cpp 3094
2018-03-22 11:56:05.306090 zmdc 10843 INF 'zma -m 3' crashed, signal 8 zmdc.pl
2018-03-22 11:56:04.205960 zmdc 10843 WAR 'zma -m 3' has not stopped at 18/03/22 11:56:04. Sending KILL to pid 5952 zmdc.pl
2018-03-22 11:56:00.926113 zmc_m3 31020 INF Laundry: 14000 - Capturing at 13.89 fps zm_monitor.cpp 3125
2018-03-22 11:55:59.381600 zma_m3 5952 INF Laundry: 030 - Closing event 3777, shutting down zm_monitor.cpp 625
2018-03-22 11:55:58.198765 zma_m3 5952 INF Got signal 15 (Terminated), exiting zm_signal.cpp 40
2018-03-22 11:55:56.503402 zmc_m3 31020 WAR Buffer overrun at index 121, image 13921, slow down capture, speed up analysis or increase ring buffer size zm_monitor.cpp 3094
2018-03-22 11:55:56.486150 zmdc 10843 INF 'zma -m 3' sending stop to pid 5952 at 18/03/22 11:55:56 zmdc.pl
2018-03-22 11:55:55.072660 zmwatch 10882 INF Restarting analysis daemon for Laundry zmwatch.pl
2018-03-22 11:55:52.384184 zmc_m3 31020 WAR Buffer overrun at index 71, image 13871, slow down capture, speed up analysis or increase ring buffer size zm_monitor.cpp 3094
2018-03-22 11:55:50.877120 zmwatch 10882 INF Analysis daemon for Laundry needs restarting, time since last analysis 6 seconds (1521734150-1521734144) zmwatch.pl
2018-03-22 11:55:45.810940 zma_m3 5952 INF Laundry: 026 - Opening new event 3777, section start zm_monitor.cpp 1541
2018-03-22 11:55:40.918986 zma_m3 5952 INF In mode 5/1, warming up zma.cpp 142
2018-03-22 11:55:40.246400 zmdc 10843 INF 'zma -m 3' starting at 18/03/22 11:55:40, pid = 5952 zmdc.pl
2018-03-22 11:55:40.246400 zmdc 5952 INF 'zma -m 3' started at 18/03/22 11:55:40 zmdc.pl
2018-03-22 11:55:38.768570 zmwatch 10882 INF Restarting analysis daemon for Laundry zmwatch.pl
2018-03-22 11:55:37.962750 zmwatch 10882 INF Analysis daemon for Laundry needs restarting, time since last analysis 28 seconds (1521734137-1521734109) zmwatch.pl
2018-03-22 11:55:36.658747 zmc_m3 31020 INF Successfully reopened stream. zm_ffmpeg_camera.cpp 134
2018-03-22 11:55:34.474607 zmc_m3 31020 ERR Unable to read packet from stream 0: error -541478725 "End of file". zm_ffmpeg_camera.cpp 167
2018-03-22 11:55:33.858185 zmc_m3 31020 INF av_read_frame returned "End of file". Reopening stream. zm_ffmpeg_camera.cpp 163
2018-03-22 11:55:28.640141 zmc_m3 31020 WAR Last image read from shared memory 19 seconds ago, zma may have gone away zm_monitor.cpp 3100
2018-03-22 11:55:25.767313 zmc_m3 31020 WAR Buffer overrun at index 129, image 13479, slow down capture, speed up analysis or increase ring buffer size zm_monitor.cpp 3094
2018-03-22 11:55:19.358870 zmdc 10843 INF 'zma -m 3' crashed, signal 8 zmdc.pl
2018-03-22 11:55:17.965880 zmdc 10843 WAR 'zma -m 3' has not stopped at 18/03/22 11:55:17. Sending KILL to pid 5309 zmdc.pl
2018-03-22 11:55:16.636751 zmc_m3 31020 WAR Buffer overrun at index 129, image 13329, slow down capture, speed up analysis or increase ring buffer size zm_monitor.cpp 3094
2018-03-22 11:55:15.159119 zma_m3 5309 INF Laundry: 042 - Closing event 3776, shutting down zm_monitor.cpp 625
2018-03-22 11:55:13.488299 zmc_m3 31020 WAR Buffer overrun at index 114, image 13314, slow down capture, speed up analysis or increase ring buffer size zm_monitor.cpp 3094
2018-03-22 11:55:11.958562 zma_m3 5309 INF Got signal 15 (Terminated), exiting zm_signal.cpp 40
2018-03-22 11:55:09.082130 zmdc 10843 INF 'zma -m 3' sending stop to pid 5309 at 18/03/22 11:55:09 zmdc.pl
2018-03-22 11:55:08.060184 zmc_m3 31020 WAR Buffer overrun at index 98, image 13298, slow down capture, speed up analysis or increase ring buffer size zm_monitor.cpp 3094
2018-03-22 11:55:05.929530 zmwatch 10882 INF Restarting analysis daemon for Laundry zmwatch.pl
2018-03-22 11:55:03.953680 zmwatch 10882 INF Analysis daemon for Laundry needs restarting, time since last analysis 13 seconds (1521734103-1521734090) zmwatch.pl
2018-03-22 11:54:56.945348 zmc_m3 31020 WAR Buffer overrun at index 81, image 13131, slow down capture, speed up analysis or increase ring buffer size zm_monitor.cpp 3094
2018-03-22 11:54:48.556359 zmc_m3 31020 INF Laundry: 13000 - Capturing at 12.82 fps zm_monitor.cpp 3125
2018-03-22 11:54:46.257869 zmc_m3 31020 WAR Buffer overrun at index 71, image 12971, slow down capture, speed up analysis or increase ring buffer size zm_monitor.cpp 3094
2018-03-22 11:54:40.544225 zmc_m3 31020 WAR Buffer overrun at index 131, image 12881, slow down capture, speed up analysis or increase ring buffer size zm_monitor.cpp 3094
2018-03-22 11:54:40.112882 zmc_m3 31020 WAR Buffer overrun at index 129, image 12879, slow down capture, speed up analysis or increase ring buffer size zm_monitor.cpp 3094
2018-03-22 11:54:30.815130 zmc_m3 31020 WAR Buffer overrun at index 125, image 12725, slow down capture, speed up analysis or increase ring buffer size zm_monitor.cpp 3094
2018-03-22 11:54:27.313141 zmc_m3 31020 WAR Buffer overrun at index 71, image 12671, slow down capture, speed up analysis or increase ring buffer size zm_monitor.cpp 3094
2018-03-22 11:54:25.976300 zmc_m3 31020 WAR Buffer overrun at index 67, image 12667, slow down capture, speed up analysis or increase ring buffer size zm_monitor.cpp 3094
2018-03-22 11:54:18.655463 zma_m3 5309 INF Laundry: 026 - Opening new event 3776, section start zm_monitor.cpp 1541
2018-03-22 11:54:13.991589 zma_m3 5309 INF In mode 5/1, warming up zma.cpp 142
2018-03-22 11:54:11.299770 zmdc 5309 INF 'zma -m 3' started at 18/03/22 11:54:11 zmdc.pl
2018-03-22 11:54:11.298570 zmdc 10843 INF 'zma -m 3' starting at 18/03/22 11:54:11, pid = 5309 zmdc.pl
2018-03-22 11:54:03.937690 zmwatch 10882 INF Restarting analysis daemon for Laundry zmwatch.pl
2018-03-22 11:54:00.174650 zmwatch 10882 INF Analysis daemon for Laundry needs restarting, time since last analysis 26 seconds (1521734040-1521734014) zmwatch.pl
2018-03-22 11:53:57.453872 zmc_m3 31020 WAR Last image read from shared memory 23 seconds ago, zma may have gone away zm_monitor.cpp 3100
2018-03-22 11:53:55.243248 zmc_m3 31020 WAR Buffer overrun at index 56, image 12206, slow down capture, speed up analysis or increase ring buffer size zm_monitor.cpp 3094
2018-03-22 11:53:50.262746 zmc_m3 31020 INF Successfully reopened stream. zm_ffmpeg_camera.cpp 134
2018-03-22 11:53:49.138370 zmdc 10843 INF 'zma -m 3' crashed, signal 8 zmdc.pl
2018-03-22 11:53:48.231456 zmc_m3 31020 ERR Unable to read packet from stream 0: error -541478725 "End of file". zm_ffmpeg_camera.cpp 167
2018-03-22 11:53:46.677380 zmdc 10843 WAR 'zma -m 3' has not stopped at 18/03/22 11:53:46. Sending KILL to pid 4724 zmdc.pl
2018-03-22 11:53:45.106066 zma_m3 4724 INF Laundry: 040 - Closing event 3775, shutting down zm_monitor.cpp 625
2018-03-22 11:53:44.849958 zmc_m3 31020 INF av_read_frame returned "End of file". Reopening stream. zm_ffmpeg_camera.cpp 163
2018-03-22 11:53:40.672306 zma_m3 4724 INF Got signal 15 (Terminated), exiting zm_signal.cpp 40
2018-03-22 11:53:39.733108 zmc_m3 31020 WAR Last image read from shared memory 19 seconds ago, zma may have gone away zm_monitor.cpp 3100
2018-03-22 11:53:38.920410 zmdc 10843 INF 'zma -m 3' sending stop to pid 4724 at 18/03/22 11:53:38 zmdc.pl
2018-03-22 11:53:36.326154 zmc_m3 31020 WAR Buffer overrun at index 51, image 12051, slow down capture, speed up analysis or increase ring buffer size zm_monitor.cpp 3094
2018-03-22 11:53:34.822580 zmwatch 10882 INF Restarting analysis daemon for Laundry zmwatch.pl
2018-03-22 11:53:31.977110 zmwatch 10882 INF Analysis daemon for Laundry needs restarting, time since last analysis 11 seconds (1521734011-1521734000) zmwatch.pl
2018-03-22 11:53:30.569221 zmc_m3 31020 INF Laundry: 12000 - Capturing at 12.05 fps zm_monitor.cpp 3125
2018-03-22 11:53:22.332320 zmc_m3 31020 WAR Buffer overrun at index 41, image 11891, slow down capture, speed up analysis or increase ring buffer size zm_monitor.cpp 3094
2018-03-22 11:53:09.086466 zmc_m3 31020 WAR Buffer overrun at index 137, image 11687, slow down capture, speed up analysis or increase ring buffer size zm_monitor.cpp 3094
2018-03-22 11:53:07.996633 zmc_m3 31020 WAR Buffer overrun at index 123, image 11673, slow down capture, speed up analysis or increase ring buffer size zm_monitor.cpp 3094
2018-03-22 11:53:06.597091 zmc_m3 31020 WAR Buffer overrun at index 105, image 11655, slow down capture, speed up analysis or increase ring buffer size zm_monitor.cpp 3094
2018-03-22 11:52:58.955777 zma_m3 4724 INF Laundry: 026 - Opening new event 3775, section start zm_monitor.cpp 1541
2018-03-22 11:52:52.014312 zma_m3 4724 INF In mode 5/1, warming up zma.cpp 142
2018-03-22 11:52:49.542230 zmdc 4724 INF 'zma -m 3' started at 18/03/22 11:52:49 zmdc.pl
2018-03-22 11:52:49.542220 zmdc 10843 INF 'zma -m 3' starting at 18/03/22 11:52:49, pid = 4724 zmdc.pl
2018-03-22 11:52:46.330660 zmwatch 10882 INF Restarting analysis daemon for Laundry zmwatch.pl
2018-03-22 11:52:45.186580 zmwatch 10882 ERR Error getting last capture time for Laundry zmwatch.pl
2018-03-22 11:52:33.332560 zmdc 10843 INF 'zma -m 3' exited normally zmdc.pl
2018-03-22 11:52:32.549721 zmc_m3 31020 INF Successfully reopened stream. zm_ffmpeg_camera.cpp 134
2018-03-22 11:52:32.312131 zma_m3 4442 INF Got signal 15 (Terminated), exiting zm_signal.cpp 40
2018-03-22 11:52:30.713730 zmdc 10843 INF 'zma -m 3' sending stop to pid 4442 at 18/03/22 11:52:30 zmdc.pl
2018-03-22 11:52:29.793879 zmc_m3 31020 ERR Unable to read packet from stream 0: error -541478725 "End of file". zm_ffmpeg_camera.cpp 167
2018-03-22 11:52:28.785630 zmwatch 10882 INF Restarting analysis daemon for Laundry zmwatch.pl
2018-03-22 11:52:23.118417 zmc_m3 31020 INF av_read_frame returned "End of file". Reopening stream. zm_ffmpeg_camera.cpp 163
2018-03-22 11:52:22.022340 zmwatch 10882 ERR Error getting last capture time for Laundry zmwatch.pl
2018-03-22 11:52:20.754703 zma_m3 4442 WAR Approaching buffer overrun, consider slowing capture, simplifying analysis or increasing ring buffer size zm_monitor.cpp 1324
2018-03-22 11:52:19.396495 zmc_m3 31020 WAR Last image read from shared memory 1521733939 seconds ago, zma may have gone away zm_monitor.cpp 3100
2018-03-22 11:52:12.064204 zma_m3 4442 INF In mode 5/1, warming up zma.cpp 142
2018-03-22 11:52:11.233860 zmc_m3 31020 WAR Buffer overrun at index 102, image 11052, slow down capture, speed up analysis or increase ring buffer size zm_monitor.cpp 3094
2018-03-22 11:52:09.071900 zmdc 4442 INF 'zma -m 3' started at 18/03/22 11:52:09 zmdc.pl
2018-03-22 11:52:09.071900 zmdc 10843 INF 'zma -m 3' starting at 18/03/22 11:52:09, pid = 4442 zmdc.pl
2018-03-22 11:52:07.744152 zmc_m3 31020 INF Laundry: 11000 - Capturing at 11.36 fps zm_monitor.cpp 3125
2018-03-22 11:52:04.859590 zmwatch 10882 INF Restarting analysis daemon for Laundry zmwatch.pl
2018-03-22 11:52:03.355130 zmwatch 10882 INF Analysis daemon for Laundry needs restarting, time since last analysis 22 seconds (1521733923-1521733901) zmwatch.pl
2018-03-22 11:52:02.341480 zmc_m3 31020 WAR Buffer overrun at index 102, image 10902, slow down capture, speed up analysis or increase ring buffer size zm_monitor.cpp 3094
2018-03-22 11:52:00.660625 zmc_m3 31020 INF Successfully reopened stream. zm_ffmpeg_camera.cpp 134
2018-03-22 11:51:58.487268 zmc_m3 31020 ERR Unable to read packet from stream 0: error -541478725 "End of file". zm_ffmpeg_camera.cpp 167
2018-03-22 11:51:57.833107 zmc_m3 31020 INF av_read_frame returned "End of file". Reopening stream. zm_ffmpeg_camera.cpp 163
2018-03-22 11:51:53.352251 zmc_m3 31020 INF Successfully reopened stream. zm_ffmpeg_camera.cpp 134
2018-03-22 11:51:52.199630 zmdc 10843 INF 'zma -m 3' crashed, signal 8 zmdc.pl
2018-03-22 11:51:48.986305 zmc_m3 31020 ERR Unable to read packet from stream 0: error -541478725 "End of file". zm_ffmpeg_camera.cpp 167
2018-03-22 11:51:47.972600 zmdc 10843 WAR 'zma -m 3' has not stopped at 18/03/22 11:51:47. Sending KILL to pid 3282 zmdc.pl
2018-03-22 11:51:45.790101 zma_m3 3282 INF Laundry: 1198 - Closing event 3774, shutting down zm_monitor.cpp 625
2018-03-22 11:51:42.977044 zmc_m3 31020 INF av_read_frame returned "End of file". Reopening stream. zm_ffmpeg_camera.cpp 163
2018-03-22 11:51:41.964477 zma_m3 3282 INF Got signal 15 (Terminated), exiting zm_signal.cpp 40
2018-03-22 11:51:37.888950 zmdc 10843 INF 'zma -m 3' sending stop to pid 3282 at 18/03/22 11:51:37 zmdc.pl
2018-03-22 11:51:37.788190 zmc_m3 31020 WAR Buffer overrun at index 37, image 10687, slow down capture, speed up analysis or increase ring buffer size zm_monitor.cpp 3094
2018-03-22 11:51:28.494040 zmwatch 10882 INF Restarting analysis daemon for Laundry zmwatch.pl
2018-03-22 11:51:25.372528 zmc_m3 31020 WAR Buffer overrun at index 36, image 10686, slow down capture, speed up analysis or increase ring buffer size zm_monitor.cpp 3094
2018-03-22 11:51:21.192980 zmwatch 10882 INF Analysis daemon for Laundry needs restarting, time since last analysis 6 seconds (1521733881-1521733875) zmwatch.pl
2018-03-22 11:50:59.366664 zma_m3 3282 INF Laundry: 1000 - Analysing at 11.24 fps zm_monitor.cpp 1296
2018-03-22 11:50:39.576443 zmc_m3 31020 INF Laundry: 10000 - Capturing at 14.93 fps zm_monitor.cpp 3125
2018-03-22 11:50:26.512007 zmc_m3 31020 WAR Buffer overrun at index 53, image 9803, slow down capture, speed up analysis or increase ring buffer size zm_monitor.cpp 3094
2018-03-22 11:50:03.742020 zma_m3 3282 INF Laundry: 417 - Opening new event 3774, section start zm_monitor.cpp 1541
2018-03-22 11:50:00.048682 zma_m3 3282 INF Laundry: 417 - Closing event 3773, section end zm_monitor.cpp 1521
2018-03-22 11:49:32.943544 zmc_m3 31020 INF Laundry: 9000 - Capturing at 15.15 fps zm_monitor.cpp 3125
2018-03-22 11:49:32.783435 zma_m3 3282 INF Laundry: 026 - Opening new event 3773, section start zm_monitor.cpp 1541
2018-03-22 11:49:30.073677 zma_m3 3282 INF In mode 5/1, warming up zma.cpp 142
2018-03-22 11:49:28.911080 zmdc 3282 INF 'zma -m 3' started at 18/03/22 11:49:28 zmdc.pl
2018-03-22 11:49:28.911080 zmdc 10843 INF 'zma -m 3' starting at 18/03/22 11:49:28, pid = 3282 zmdc.pl
2018-03-22 11:49:27.509120 zmwatch 10882 INF Restarting analysis daemon for Laundry zmwatch.pl
2018-03-22 11:49:26.836430 zmwatch 10882 ERR Error getting last capture time for Laundry zmwatch.pl
2018-03-22 11:49:16.804280 zmdc 10843 INF 'zma -m 3' exited normally zmdc.pl
2018-03-22 11:49:16.720547 zma_m3 3005 INF Laundry: 032 - Closing event 3772, shutting down zm_monitor.cpp 625
2018-03-22 11:49:16.480543 zma_m3 3005 INF Got signal 15 (Terminated), exiting zm_signal.cpp 40
2018-03-22 11:49:15.923800 zmdc 10843 INF 'zma -m 3' sending stop to pid 3005 at 18/03/22 11:49:15 zmdc.pl
2018-03-22 11:49:15.277450 zmwatch 10882 INF Restarting analysis daemon for Laundry zmwatch.pl
2018-03-22 11:49:14.512020 zmwatch 10882 INF Analysis daemon for Laundry needs restarting, time since last analysis 11 seconds (1521733754-1521733743) zmwatch.pl
2018-03-22 11:49:07.140930 zmc_m3 31020 WAR Buffer overrun at index 62, image 8612, slow down capture, speed up analysis or increase ring buffer size zm_monitor.cpp 3094
2018-03-22 11:48:58.561020 zma_m3 3005 INF Laundry: 026 - Opening new event 3772, section start zm_monitor.cpp 1541
2018-03-22 11:48:54.551008 zma_m3 3005 INF In mode 5/1, warming up zma.cpp 142
2018-03-22 11:48:53.319060 zmdc 10843 INF 'zma -m 3' starting at 18/03/22 11:48:53, pid = 3005 zmdc.pl
2018-03-22 11:48:53.319060 zmdc 3005 INF 'zma -m 3' started at 18/03/22 11:48:53 zmdc.pl
2018-03-22 11:48:48.041950 zmwatch 10882 INF Restarting analysis daemon for Laundry zmwatch.pl
2018-03-22 11:48:47.060520 zmwatch 10882 INF Analysis daemon for Laundry needs restarting, time since last analysis 30 seconds (1521733727-1521733697) zmwatch.pl
2018-03-22 11:48:35.048040 zmdc 10843 INF 'zma -m 3' crashed, signal 8 zmdc.pl
2018-03-22 11:48:32.561690 zmdc 10843 WAR 'zma -m 3' has not stopped at 18/03/22 11:48:32. Sending KILL to pid 2694 zmdc.pl
2018-03-22 11:48:30.410110 zma_m3 2694 INF Laundry: 028 - Closing event 3771, shutting down zm_monitor.cpp 625
2018-03-22 11:48:29.471435 zmc_m3 31020 WAR Last image read from shared memory 21 seconds ago, zma may have gone away zm_monitor.cpp 3100
2018-03-22 11:48:28.040671 zmc_m3 31020 WAR Buffer overrun at index 65, image 8015, slow down capture, speed up analysis or increase ring buffer size zm_monitor.cpp 3094
2018-03-22 11:48:26.556612 zma_m3 2694 INF Got signal 15 (Terminated), exiting zm_signal.cpp 40
2018-03-22 11:48:26.238782 zmc_m3 31020 INF Laundry: 8000 - Capturing at 14.93 fps zm_monitor.cpp 3125
2018-03-22 11:48:24.721880 zmdc 10843 INF 'zma -m 3' sending stop to pid 2694 at 18/03/22 11:48:24 zmdc.pl
2018-03-22 11:48:21.727730 zmwatch 10882 INF Restarting analysis daemon for Laundry zmwatch.pl
2018-03-22 11:48:17.900720 zmwatch 10882 INF Analysis daemon for Laundry needs restarting, time since last analysis 9 seconds (1521733697-1521733688) zmwatch.pl
2018-03-22 11:48:17.319970 zmc_m3 31020 WAR Buffer overrun at index 65, image 7865, slow down capture, speed up analysis or increase ring buffer size zm_monitor.cpp 3094
2018-03-22 11:48:11.062649 zma_m3 2694 INF Laundry: 026 - Opening new event 3771, section start zm_monitor.cpp 1541
2018-03-22 11:48:07.947613 zma_m3 2694 INF In mode 5/1, warming up zma.cpp 142
2018-03-22 11:48:07.055890 zmdc 10843 INF 'zma -m 3' starting at 18/03/22 11:48:07, pid = 2694 zmdc.pl
2018-03-22 11:48:07.055890 zmdc 2694 INF 'zma -m 3' started at 18/03/22 11:48:07 zmdc.pl
2018-03-22 11:48:05.238730 zmwatch 10882 INF Restarting analysis daemon for Laundry zmwatch.pl
2018-03-22 11:48:04.059220 zmwatch 10882 ERR Error getting last capture time for Laundry zmwatch.pl
2018-03-22 11:47:52.192370 zmdc 10843 INF 'zma -m 3' exited normally zmdc.pl
2018-03-22 11:47:50.965720 zma_m3 2338 INF Laundry: 032 - Closing event 3770, shutting down zm_monitor.cpp 625
2018-03-22 11:47:49.679498 zma_m3 2338 INF Got signal 15 (Terminated), exiting zm_signal.cpp 40
2018-03-22 11:47:46.324408 zmc_m3 31020 WAR Buffer overrun at index 50, image 7400, slow down capture, speed up analysis or increase ring buffer size zm_monitor.cpp 3094
2018-03-22 11:47:45.922400 zmdc 10843 INF 'zma -m 3' sending stop to pid 2338 at 18/03/22 11:47:45 zmdc.pl
2018-03-22 11:47:44.311760 zmwatch 10882 INF Restarting analysis daemon for Laundry zmwatch.pl
2018-03-22 11:47:43.482130 zmwatch 10882 INF Analysis daemon for Laundry needs restarting, time since last analysis 11 seconds (1521733663-1521733652) zmwatch.pl
2018-03-22 11:47:35.047618 zmc_m3 31020 WAR Buffer overrun at index 31, image 7231, slow down capture, speed up analysis or increase ring buffer size zm_monitor.cpp 3094
2018-03-22 11:47:25.819401 zma_m3 2338 INF Laundry: 026 - Opening new event 3770, section start zm_monitor.cpp 1541
2018-03-22 11:47:23.521853 zma_m3 2338 INF In mode 5/1, warming up zma.cpp 142
2018-03-22 11:47:23.433940 zmdc 10843 INF 'zma -m 3' starting at 18/03/22 11:47:23, pid = 2338 zmdc.pl
2018-03-22 11:47:23.433940 zmdc 2338 INF 'zma -m 3' started at 18/03/22 11:47:23 zmdc.pl
2018-03-22 11:47:23.331690 zmwatch 10882 INF Restarting analysis daemon for Laundry zmwatch.pl
2018-03-22 11:47:23.308780 zmwatch 10882 ERR Error getting last capture time for Laundry zmwatch.pl
2018-03-22 11:47:19.576214 zmc_m3 31020 INF Laundry: 7000 - Capturing at 14.93 fps zm_monitor.cpp 3125
2018-03-22 11:47:13.149470 zmdc 10843 INF 'zma -m 3' exited normally zmdc.pl
2018-03-22 11:47:11.243245 zmc_m3 31020 WAR Buffer overrun at index 95, image 6845, slow down capture, speed up analysis or increase ring buffer size zm_monitor.cpp 3094
2018-03-22 11:47:09.911345 zma_m3 2037 INF Laundry: 037 - Closing event 3769, shutting down zm_monitor.cpp 625
2018-03-22 11:47:08.413091 zmc_m3 31020 WAR Buffer overrun at index 81, image 6831, slow down capture, speed up analysis or increase ring buffer size zm_monitor.cpp 3094
2018-03-22 11:47:07.690530 zma_m3 2037 INF Got signal 15 (Terminated), exiting zm_signal.cpp 40
2018-03-22 11:47:06.524550 zmdc 10843 INF 'zma -m 3' sending stop to pid 2037 at 18/03/22 11:47:06 zmdc.pl
2018-03-22 11:47:06.171880 zmwatch 10882 INF Restarting analysis daemon for Laundry zmwatch.pl
2018-03-22 11:47:04.356450 zmwatch 10882 INF Analysis daemon for Laundry needs restarting, time since last analysis 14 seconds (1521733624-1521733610) zmwatch.pl
2018-03-22 11:46:56.241524 zmc_m3 31020 WAR Buffer overrun at index 49, image 6649, slow down capture, speed up analysis or increase ring buffer size zm_monitor.cpp 3094
2018-03-22 11:46:45.245629 zma_m3 2037 INF Laundry: 026 - Opening new event 3769, section start zm_monitor.cpp 1541
2018-03-22 11:46:44.396640 zma_m3 2037 INF In mode 5/1, warming up zma.cpp 142
2018-03-22 11:46:44.330920 zmdc 2037 INF 'zma -m 3' started at 18/03/22 11:46:44 zmdc.pl
2018-03-22 11:46:44.330910 zmdc 10843 INF 'zma -m 3' starting at 18/03/22 11:46:44, pid = 2037 zmdc.pl
2018-03-22 11:46:40.569260 zmwatch 10882 INF Restarting analysis daemon for Laundry zmwatch.pl
2018-03-22 11:46:39.570550 zmwatch 10882 ERR Error getting last capture time for Laundry zmwatch.pl
2018-03-22 11:46:29.547310 zmdc 10843 INF 'zma -m 3' exited normally zmdc.pl
2018-03-22 11:46:29.242683 zma_m3 31459 INF Laundry: 4289 - Closing event 3768, shutting down zm_monitor.cpp 625
2018-03-22 11:46:29.013351 zma_m3 31459 INF Got signal 15 (Terminated), exiting zm_signal.cpp 40
2018-03-22 11:46:28.424050 zmdc 10843 INF 'zma -m 3' sending stop to pid 31459 at 18/03/22 11:46:28 zmdc.pl
2018-03-22 11:46:27.955130 zmwatch 10882 INF Restarting analysis daemon for Laundry zmwatch.pl
I tried it at 640x480, still crashes:
2018-03-22 15:34:22.966033 zmc_m3 24957 INF Got signal 15 (Terminated), exiting zm_signal.cpp 40
2018-03-22 15:34:22.138030 zmdc 24924 INF 'zma -m 3' exited normally zmdc.pl
2018-03-22 15:34:21.386435 zmc_m3 24957 INF Laundry: 95000 - Capturing at 14.71 fps zm_monitor.cpp 3125
2018-03-22 15:34:20.848270 zmdc 24924 WAR 'zma -m 3' has not stopped at 18/03/22 15:34:20. Sending KILL to pid 8155 zmdc.pl
2018-03-22 15:34:18.245217 zmc_m3 24957 WAR Buffer overrun at index 13, image 94963, slow down capture, speed up analysis or increase ring buffer size zm_monitor.cpp 3094
2018-03-22 15:34:16.223422 zma_m3 8155 INF Laundry: 030 - Closing event 3791, shutting down zm_monitor.cpp 625
2018-03-22 15:34:14.841611 zma_m3 8155 INF Got signal 15 (Terminated), exiting zm_signal.cpp 40
2018-03-22 15:34:14.553170 zmdc 24924 INF 'zma -m 3' sending stop to pid 8155 at 18/03/22 15:34:14 zmdc.pl
2018-03-22 15:34:13.637750 zmwatch 24968 INF Restarting analysis daemon for Laundry zmwatch.pl
2018-03-22 15:34:11.922150 zmwatch 24968 INF Analysis daemon for Laundry needs restarting, time since last analysis 9 seconds (1521747251-1521747242) zmwatch.pl
2018-03-22 15:34:07.926777 zmc_m3 24957 WAR Buffer overrun at index 8, image 94808, slow down capture, speed up analysis or increase ring buffer size zm_monitor.cpp 3094
2018-03-22 15:34:00.270288 zma_m3 8155 INF Laundry: 026 - Opening new event 3791, section start zm_monitor.cpp 1541
2018-03-22 15:33:58.559117 zma_m3 8155 INF In mode 5/1, warming up zma.cpp 142
2018-03-22 15:33:53.979410 zmdc 24924 INF 'zma -m 3' starting at 18/03/22 15:33:53, pid = 8155 zmdc.pl
2018-03-22 15:33:53.979410 zmdc 8155 INF 'zma -m 3' started at 18/03/22 15:33:53 zmdc.pl
2018-03-22 15:33:52.018850 zmdc 24924 INF Starting pending process, zma -m 3 zmdc.pl
2018-03-22 15:33:51.100880 zmdc 24924 INF 'zma -m 3' crashed, signal 8 zmdc.pl
2018-03-22 15:33:49.865845 zmc_m3 24957 WAR Buffer overrun at index 37, image 94537, slow down capture, speed up analysis or increase ring buffer size zm_monitor.cpp 3094
2018-03-22 15:33:47.094130 zmdc 24924 WAR 'zma -m 3' has not stopped at 18/03/22 15:33:47. Sending KILL to pid 25049 zmdc.pl
2018-03-22 15:33:41.089331 zma_m3 25049 INF Got signal 15 (Terminated), exiting zm_signal.cpp 40
2018-03-22 15:33:35.027710 zmdc 24924 INF 'zma -m 3' sending stop to pid 25049 at 18/03/22 15:33:35 zmdc.pl
2018-03-22 15:33:28.893430 zmwatch 24968 INF Restarting analysis daemon for Laundry zmwatch.pl
2018-03-22 15:33:27.465860 zmwatch 24968 INF Analysis daemon for Laundry needs restarting, time since last analysis 7 seconds (1521747207-1521747200) zmwatch.pl
2018-03-22 15:33:13.986916 zmc_m3 24957 INF Laundry: 94000 - Capturing at 15.15 fps zm_monitor.cpp 3125
2018-03-22 15:33:06.837568 zma_m3 25049 INF Laundry: 92000 - Analysing at 13.51 fps zm_monitor.cpp 1296
2018-03-22 15:32:07.304594 zmc_m3 24957 INF Laundry: 93000 - Capturing at 14.93 fps zm_monitor.cpp 3125
2018-03-22 15:31:52.721139 zma_m3 25049 INF Laundry: 91000 - Analysing at 12.50 fps zm_monitor.cpp 1296
2018-03-22 15:31:00.663349 zmc_m3 24957 INF Laundry: 92000 - Capturing at 15.15 fps zm_monitor.cpp 3125
2018-03-22 15:30:32.567921 zma_m3 25049 INF Laundry: 90000 - Analysing at 8.70 fps zm_monitor.cpp 1296
2018-03-22 15:30:23.767633 zmc_m3 24957 WAR Buffer overrun at index 60, image 91410, slow down capture, speed up analysis or increase ring buffer size zm_monitor.cpp 3094
2018-03-22 15:30:19.650451 zmc_m3 24957 WAR Buffer overrun at index 130, image 91330, slow down capture, speed up analysis or increase ring buffer size zm_monitor.cpp 3094
2018-03-22 15:30:15.545308 zmc_m3 24957 WAR Buffer overrun at index 122, image 91322, slow down capture, speed up analysis or increase ring buffer size zm_monitor.cpp 3094
2018-03-22 15:30:10.021303 zmc_m3 24957 WAR Buffer overrun at index 39, image 91239, slow down capture, speed up analysis or increase ring buffer size zm_monitor.cpp 3094
2018-03-22 15:30:07.301082 zma_m3 25049 INF Laundry: 89908 - Opening new event 3790, section start zm_monitor.cpp 1541
2018-03-22 15:30:02.748746 zma_m3 25049 INF Laundry: 89908 - Closing event 3789, section end zm_monitor.cpp 1521
2018-03-22 15:29:54.017300 zmc_m3 24957 INF Laundry: 91000 - Capturing at 14.93 fps zm_monitor.cpp 3125
2018-03-22 15:28:47.331364 zmc_m3 24957 INF Laundry: 90000 - Capturing at 14.93 fps zm_monitor.cpp 3125
2018-03-22 15:28:37.748347 zma_m3 25049 INF Laundry: 89000 - Analysing at 14.71 fps zm_monitor.cpp 1296
2018-03-22 15:27:40.687564 zmc_m3 24957 INF Laundry: 89000 - Capturing at 15.15 fps zm_monitor.cpp 3125
2018-03-22 15:27:29.544605 zma_m3 25049 INF Laundry: 88000 - Analysing at 14.93 fps zm_monitor.cpp 1296
2018-03-22 15:26:34.010525 zmc_m3 24957 INF Laundry: 88000 - Capturing at 14.93 fps zm_monitor.cpp 3125
2018-03-22 15:26:22.885341 zma_m3 25049 INF Laundry: 87000 - Analysing at 15.15 fps zm_monitor.cpp 1296
2018-03-22 15:25:27.333141 zmc_m3 24957 INF Laundry: 87000 - Capturing at 14.93 fps zm_monitor.cpp 3125
2018-03-22 15:25:16.150756 zma_m3 25049 INF Laundry: 86000 - Analysing at 14.93 fps zm_monitor.cpp 1296
2018-03-22 15:24:20.640152 zmc_m3 24957 INF Laundry: 86000 - Capturing at 14.93 fps zm_monitor.cpp 3125
2018-03-22 15:24:09.395999 zma_m3 25049 INF Laundry: 85000 - Analysing at 14.93 fps zm_monitor.cpp 1296
2018-03-22 15:23:13.995066 zmc_m3 24957 INF Laundry: 85000 - Capturing at 15.15 fps zm_monitor.cpp 3125
2018-03-22 15:23:02.749555 zma_m3 25049 INF Laundry: 84000 - Analysing at 15.15 fps zm_monitor.cpp 1296
2018-03-22 15:22:07.344572 zmc_m3 24957 INF Laundry: 84000 - Capturing at 14.93 fps zm_monitor.cpp 3125
2018-03-22 15:21:56.063933 zma_m3 25049 INF Laundry: 83000 - Analysing at 14.71 fps zm_monitor.cpp 1296
2018-03-22 15:21:00.652999 zmc_m3 24957 INF Laundry: 83000 - Capturing at 14.93 fps zm_monitor.cpp 3125
2018-03-22 15:20:48.093194 zma_m3 25049 INF Laundry: 82000 - Analysing at 14.71 fps zm_monitor.cpp 1296
2018-03-22 15:20:00.138610 zma_m3 25049 INF Laundry: 81289 - Opening new event 3789, section start zm_monitor.cpp 1541
2018-03-22 15:20:00.023078 zma_m3 25049 INF Laundry: 81289 - Closing event 3788, section end zm_monitor.cpp 1521
2018-03-22 15:19:53.997999 zmc_m3 24957 INF Laundry: 82000 - Capturing at 15.15 fps zm_monitor.cpp 3125
2018-03-22 15:19:40.747221 zma_m3 25049 INF Laundry: 81000 - Analysing at 15.15 fps zm_monitor.cpp 1296
2018-03-22 15:18:47.354322 zmc_m3 24957 INF Laundry: 81000 - Capturing at 14.93 fps zm_monitor.cpp 3125
2018-03-22 15:18:34.080285 zma_m3 25049 INF Laundry: 80000 - Analysing at 14.93 fps zm_monitor.cpp 1296
2018-03-22 15:17:40.668812 zmc_m3 24957 INF Laundry: 80000 - Capturing at 15.15 fps zm_monitor.cpp 3125
2018-03-22 15:17:27.432791 zma_m3 25049 INF Laundry: 79000 - Analysing at 14.93 fps zm_monitor.cpp 1296
2018-03-22 15:16:34.024176 zmc_m3 24957 INF Laundry: 79000 - Capturing at 14.93 fps zm_monitor.cpp 3125
2018-03-22 15:16:20.726988 zma_m3 25049 INF Laundry: 78000 - Analysing at 15.15 fps zm_monitor.cpp 1296
2018-03-22 15:15:27.341421 zmc_m3 24957 INF Laundry: 78000 - Capturing at 14.93 fps zm_monitor.cpp 3125
2018-03-22 15:15:14.087152 zma_m3 25049 INF Laundry: 77000 - Analysing at 14.93 fps zm_monitor.cpp 1296
2018-03-22 15:14:20.696487 zmc_m3 24957 INF Laundry: 77000 - Capturing at 15.15 fps zm_monitor.cpp 3125
2018-03-22 15:14:07.045821 zma_m3 25049 INF Laundry: 76000 - Analysing at 14.93 fps zm_monitor.cpp 1296
2018-03-22 15:13:14.019014 zmc_m3 24957 INF Laundry: 76000 - Capturing at 14.93 fps zm_monitor.cpp 3125
2018-03-22 15:13:00.054565 zma_m3 25049 INF Laundry: 75000 - Analysing at 14.71 fps zm_monitor.cpp 1296
2018-03-22 15:12:07.340951 zmc_m3 24957 INF Laundry: 75000 - Capturing at 14.93 fps zm_monitor.cpp 3125
2018-03-22 15:11:52.553645 zma_m3 25049 INF Laundry: 74000 - Analysing at 14.93 fps zm_monitor.cpp 1296
2018-03-22 15:11:00.663180 zmc_m3 24957 INF Laundry: 74000 - Capturing at 15.15 fps zm_monitor.cpp 3125
2018-03-22 15:10:45.757317 zma_m3 25049 INF Laundry: 73000 - Analysing at 14.93 fps zm_monitor.cpp 1296
2018-03-22 15:10:00.163113 zma_m3 25049 INF Laundry: 72330 - Opening new event 3788, section start zm_monitor.cpp 1541
2018-03-22 15:10:00.055291 zma_m3 25049 INF Laundry: 72330 - Closing event 3787, section end zm_monitor.cpp 1521
2018-03-22 15:09:54.021552 zmc_m3 24957 INF Laundry: 73000 - Capturing at 14.93 fps zm_monitor.cpp 3125
2018-03-22 15:09:38.035285 zma_m3 25049 INF Laundry: 72000 - Analysing at 14.71 fps zm_monitor.cpp 1296
2018-03-22 15:08:47.339431 zmc_m3 24957 INF Laundry: 72000 - Capturing at 14.93 fps zm_monitor.cpp 3125
2018-03-22 15:08:30.293165 zma_m3 25049 INF Laundry: 71000 - Analysing at 14.93 fps zm_monitor.cpp 1296
2018-03-22 15:07:40.698771 zmc_m3 24957 INF Laundry: 71000 - Capturing at 15.15 fps zm_monitor.cpp 3125
2018-03-22 15:07:23.629806 zma_m3 25049 INF Laundry: 70000 - Analysing at 14.93 fps zm_monitor.cpp 1296
2018-03-22 15:06:34.021506 zmc_m3 24957 INF Laundry: 70000 - Capturing at 14.93 fps zm_monitor.cpp 3125
2018-03-22 15:06:16.053936 zma_m3 25049 INF Laundry: 69000 - Analysing at 14.93 fps zm_monitor.cpp 1296
2018-03-22 15:05:27.333399 zmc_m3 24957 INF Laundry: 69000 - Capturing at 14.93 fps zm_monitor.cpp 3125
2018-03-22 15:05:09.246456 zma_m3 25049 INF Laundry: 68000 - Analysing at 14.71 fps zm_monitor.cpp 1296
2018-03-22 15:04:20.686610 zmc_m3 24957 INF Laundry: 68000 - Capturing at 15.15 fps zm_monitor.cpp 3125
2018-03-22 15:04:01.940168 zma_m3 25049 INF Laundry: 67000 - Analysing at 15.15 fps zm_monitor.cpp 1296
2018-03-22 15:03:14.034358 zmc_m3 24957 INF Laundry: 67000 - Capturing at 14.93 fps zm_monitor.cpp 3125
2018-03-22 15:02:55.193786 zma_m3 25049 INF Laundry: 66000 - Analysing at 14.93 fps zm_monitor.cpp 1296
2018-03-22 15:02:07.345725 zmc_m3 24957 INF Laundry: 66000 - Capturing at 14.93 fps zm_monitor.cpp 3125
2018-03-22 15:01:48.361917 zma_m3 25049 INF Laundry: 65000 - Analysing at 14.29 fps zm_monitor.cpp 1296
2018-03-22 15:01:00.696862 zmc_m3 24957 INF Laundry: 65000 - Capturing at 15.15 fps zm_monitor.cpp 3125
2018-03-22 15:00:38.993274 zma_m3 25049 INF Laundry: 64000 - Analysing at 15.15 fps zm_monitor.cpp 1296
2018-03-22 15:00:00.307519 zma_m3 25049 INF Laundry: 63419 - Opening new event 3787, section start zm_monitor.cpp 1541
2018-03-22 15:00:00.033592 zma_m3 25049 INF Laundry: 63419 - Closing event 3786, section end zm_monitor.cpp 1521
2018-03-22 14:59:54.013137 zmc_m3 24957 INF Laundry: 64000 - Capturing at 14.93 fps zm_monitor.cpp 3125
2018-03-22 14:59:32.107561 zma_m3 25049 INF Laundry: 63000 - Analysing at 14.93 fps zm_monitor.cpp 1296
2018-03-22 14:58:47.367225 zmc_m3 24957 INF Laundry: 63000 - Capturing at 14.93 fps zm_monitor.cpp 3125
2018-03-22 14:58:25.356870 zma_m3 25049 INF Laundry: 62000 - Analysing at 14.93 fps zm_monitor.cpp 1296
2018-03-22 14:57:40.677889 zmc_m3 24957 INF Laundry: 62000 - Capturing at 15.15 fps zm_monitor.cpp 3125
2018-03-22 14:57:18.562573 zma_m3 25049 INF Laundry: 61000 - Analysing at 14.93 fps zm_monitor.cpp 1296
2018-03-22 14:56:34.034044 zmc_m3 24957 INF Laundry: 61000 - Capturing at 14.93 fps zm_monitor.cpp 3125
2018-03-22 14:56:11.807110 zma_m3 25049 INF Laundry: 60000 - Analysing at 14.93 fps zm_monitor.cpp 1296
2018-03-22 14:55:27.344216 zmc_m3 24957 INF Laundry: 60000 - Capturing at 14.93 fps zm_monitor.cpp 3125
2018-03-22 14:55:04.704423 zma_m3 25049 INF Laundry: 59000 - Analysing at 14.93 fps zm_monitor.cpp 1296
2018-03-22 14:54:20.703403 zmc_m3 24957 INF Laundry: 59000 - Capturing at 15.15 fps zm_monitor.cpp 3125
2018-03-22 14:53:57.905073 zma_m3 25049 INF Laundry: 58000 - Analysing at 14.93 fps zm_monitor.cpp 1296
2018-03-22 14:53:14.017761 zmc_m3 24957 INF Laundry: 58000 - Capturing at 14.93 fps zm_monitor.cpp 3125
2018-03-22 14:52:50.773903 zma_m3 25049 INF Laundry: 57000 - Analysing at 15.15 fps zm_monitor.cpp 1296
2018-03-22 14:52:07.366139 zmc_m3 24957 INF Laundry: 57000 - Capturing at 14.93 fps zm_monitor.cpp 3125
2018-03-22 14:51:44.130260 zma_m3 25049 INF Laundry: 56000 - Analysing at 14.93 fps zm_monitor.cpp 1296
2018-03-22 14:51:00.672169 zmc_m3 24957 INF Laundry: 56000 - Capturing at 15.15 fps zm_monitor.cpp 3125
2018-03-22 14:50:37.385462 zma_m3 25049 INF Laundry: 55000 - Analysing at 14.93 fps zm_monitor.cpp 1296
2018-03-22 14:50:00.164608 zma_m3 25049 INF Laundry: 54447 - Opening new event 3786, section start zm_monitor.cpp 1541
2018-03-22 14:50:00.035302 zma_m3 25049 INF Laundry: 54447 - Closing event 3785, section end zm_monitor.cpp 1521
2018-03-22 14:49:54.020848 zmc_m3 24957 INF Laundry: 55000 - Capturing at 14.93 fps zm_monitor.cpp 3125
2018-03-22 14:49:30.232430 zma_m3 25049 INF Laundry: 54000 - Analysing at 14.93 fps zm_monitor.cpp 1296
2018-03-22 14:48:47.368975 zmc_m3 24957 INF Laundry: 54000 - Capturing at 14.93 fps zm_monitor.cpp 3125
2018-03-22 14:48:23.508491 zma_m3 25049 INF Laundry: 53000 - Analysing at 14.93 fps zm_monitor.cpp 1296
2018-03-22 14:47:40.684451 zmc_m3 24957 INF Laundry: 53000 - Capturing at 15.15 fps zm_monitor.cpp 3125
2018-03-22 14:47:16.696949 zma_m3 25049 INF Laundry: 52000 - Analysing at 14.93 fps zm_monitor.cpp 1296
2018-03-22 14:46:34.039496 zmc_m3 24957 INF Laundry: 52000 - Capturing at 14.93 fps zm_monitor.cpp 3125
2018-03-22 14:46:09.918115 zma_m3 25049 INF Laundry: 51000 - Analysing at 14.93 fps zm_monitor.cpp 1296
2018-03-22 14:45:30.005855 zma_m3 25049 INF Laundry: 50401 - Left alarm state (3785) - 4894(38) images zm_monitor.cpp 1711
2018-03-22 14:45:27.964748 zma_m3 25049 INF Laundry: 50371 - Gone into alert state zm_monitor.cpp 1704
2018-03-22 14:45:27.386426 zmc_m3 24957 INF Laundry: 51000 - Capturing at 14.93 fps zm_monitor.cpp 3125
2018-03-22 14:45:27.255618 zma_m3 25049 INF Laundry: 50360 - Gone back into alarm state zm_monitor.cpp 1695
2018-03-22 14:45:26.505771 zma_m3 25049 INF Laundry: 50348 - Gone into alert state zm_monitor.cpp 1704
2018-03-22 14:45:26.302680 zma_m3 25049 INF Laundry: 50345 - Gone into alarm state zm_monitor.cpp 1614
2018-03-22 14:45:20.491204 zma_m3 25049 INF Laundry: 50251 - Left alarm state (3785) - 4744(24) images zm_monitor.cpp 1711
2018-03-22 14:45:17.589695 zma_m3 25049 INF Laundry: 50221 - Gone into alert state zm_monitor.cpp 1704
2018-03-22 14:45:16.711311 zma_m3 25049 INF Laundry: 50208 - Gone into alarm state zm_monitor.cpp 1614
2018-03-22 14:45:02.803447 zma_m3 25049 INF Laundry: 50000 - Analysing at 14.93 fps zm_monitor.cpp 1296
2018-03-22 14:44:20.677885 zmc_m3 24957 INF Laundry: 50000 - Capturing at 15.15 fps zm_monitor.cpp 3125
2018-03-22 14:43:55.306250 zma_m3 25049 INF Laundry: 49000 - Analysing at 14.71 fps zm_monitor.cpp 1296
2018-03-22 14:43:14.888636 zma_m3 25049 INF Laundry: 48401 - Left alarm state (3785) - 2894(11) images zm_monitor.cpp 1711
2018-03-22 14:43:14.026216 zmc_m3 24957 INF Laundry: 49000 - Capturing at 14.93 fps zm_monitor.cpp 3125
2018-03-22 14:43:13.945778 zma_m3 25049 INF Laundry: 48371 - Gone into alert state zm_monitor.cpp 1704
2018-03-22 14:43:11.698772 zma_m3 25049 INF Laundry: 48360 - Gone into alarm state zm_monitor.cpp 1614
2018-03-22 14:42:47.663161 zma_m3 25049 INF Laundry: 48000 - Analysing at 14.93 fps zm_monitor.cpp 1296
2018-03-22 14:42:07.360165 zmc_m3 24957 INF Laundry: 48000 - Capturing at 14.93 fps zm_monitor.cpp 3125
2018-03-22 14:41:40.721006 zma_m3 25049 INF Laundry: 47000 - Analysing at 14.71 fps zm_monitor.cpp 1296
2018-03-22 14:41:00.698053 zmc_m3 24957 INF Laundry: 47000 - Capturing at 15.15 fps zm_monitor.cpp 3125
2018-03-22 14:40:32.938834 zma_m3 25049 INF Laundry: 46000 - Analysing at 15.15 fps zm_monitor.cpp 1296
2018-03-22 14:40:00.126963 zma_m3 25049 INF Laundry: 45507 - Opening new event 3785, section start zm_monitor.cpp 1541
2018-03-22 14:40:00.048367 zma_m3 25049 INF Laundry: 45507 - Closing event 3784, section end zm_monitor.cpp 1521
2018-03-22 14:39:54.022693 zmc_m3 24957 INF Laundry: 46000 - Capturing at 14.93 fps zm_monitor.cpp 3125
2018-03-22 14:39:26.227041 zma_m3 25049 INF Laundry: 45000 - Analysing at 14.71 fps zm_monitor.cpp 1296
2018-03-22 14:38:47.387949 zmc_m3 24957 INF Laundry: 45000 - Capturing at 14.93 fps zm_monitor.cpp 3125
2018-03-22 14:38:18.448155 zma_m3 25049 INF Laundry: 44000 - Analysing at 14.93 fps zm_monitor.cpp 1296
2018-03-22 14:37:40.679113 zmc_m3 24957 INF Laundry: 44000 - Capturing at 15.15 fps zm_monitor.cpp 3125
2018-03-22 14:37:11.708138 zma_m3 25049 INF Laundry: 43000 - Analysing at 14.93 fps zm_monitor.cpp 1296
2018-03-22 14:36:34.057868 zmc_m3 24957 INF Laundry: 43000 - Capturing at 14.93 fps zm_monitor.cpp 3125
2018-03-22 14:36:04.320948 zma_m3 25049 INF Laundry: 42000 - Analysing at 14.71 fps zm_monitor.cpp 1296
2018-03-22 14:35:27.392136 zmc_m3 24957 INF Laundry: 42000 - Capturing at 14.93 fps zm_monitor.cpp 3125
2018-03-22 14:34:56.733824 zma_m3 25049 INF Laundry: 41000 - Analysing at 14.71 fps zm_monitor.cpp 1296
2018-03-22 14:34:20.683659 zmc_m3 24957 INF Laundry: 41000 - Capturing at 15.15 fps zm_monitor.cpp 3125
2018-03-22 14:33:48.901690 zmaudit 24963 INF closing zmaudit.pl
2018-03-22 14:33:48.877230 zmaudit 24963 INF Found open event '3625' zmaudit.pl
2018-03-22 14:33:48.831180 zmaudit 24963 INF closing zmaudit.pl
2018-03-22 14:33:48.812780 zmaudit 24963 INF Found open event '3617' zmaudit.pl
2018-03-22 14:33:48.763710 zmaudit 24963 INF closing zmaudit.pl
2018-03-22 14:33:48.743590 zmaudit 24963 INF Found open event '3615' zmaudit.pl
2018-03-22 14:33:48.700420 zmaudit 24963 INF closing zmaudit.pl
2018-03-22 14:33:48.651360 zmaudit 24963 INF Found open event '3614' zmaudit.pl
2018-03-22 14:33:48.641611 zma_m3 25049 INF Laundry: 40000 - Analysing at 14.93 fps zm_monitor.cpp 1296
2018-03-22 14:33:48.602610 zmaudit 24963 INF closing zmaudit.pl
2018-03-22 14:33:48.582930 zmaudit 24963 INF Found open event '3592' zmaudit.pl
2018-03-22 14:33:48.533960 zmaudit 24963 INF closing zmaudit.pl
2018-03-22 14:33:48.514680 zmaudit 24963 INF Found open event '3591' zmaudit.pl
2018-03-22 14:33:48.450420 zmaudit 24963 INF closing zmaudit.pl
2018-03-22 14:33:48.412510 zmaudit 24963 INF Found open event '3587' zmaudit.pl
2018-03-22 14:33:48.163700 zmaudit 24963 INF closing zmaudit.pl
2018-03-22 14:33:47.742840 zmaudit 24963 INF Found open event '3576' zmaudit.pl
2018-03-22 14:33:14.054725 zmc_m3 24957 INF Laundry: 40000 - Capturing at 14.93 fps zm_monitor.cpp 3125
2018-03-22 14:32:41.793172 zma_m3 25049 INF Laundry: 39000 - Analysing at 14.93 fps zm_monitor.cpp 1296
2018-03-22 14:32:07.383975 zmc_m3 24957 INF Laundry: 39000 - Capturing at 14.93 fps zm_monitor.cpp 3125
2018-03-22 14:31:34.807638 zma_m3 25049 INF Laundry: 38000 - Analysing at 15.15 fps zm_monitor.cpp 1296
2018-03-22 14:31:00.705816 zmc_m3 24957 INF Laundry: 38000 - Capturing at 15.15 fps zm_monitor.cpp 3125
2018-03-22 14:30:28.100197 zma_m3 25049 INF Laundry: 37000 - Analysing at 14.71 fps zm_monitor.cpp 1296
2018-03-22 14:30:00.158700 zma_m3 25049 INF Laundry: 36580 - Opening new event 3784, section start zm_monitor.cpp 1541
2018-03-22 14:30:00.063468 zma_m3 25049 INF Laundry: 36580 - Closing event 3783, section end zm_monitor.cpp 1521
2018-03-22 14:29:54.047810 zmc_m3 24957 INF Laundry: 37000 - Capturing at 14.93 fps zm_monitor.cpp 3125
2018-03-22 14:29:20.595658 zma_m3 25049 INF Laundry: 36000 - Analysing at 14.71 fps zm_monitor.cpp 1296
2018-03-22 14:28:47.370931 zmc_m3 24957 INF Laundry: 36000 - Capturing at 14.93 fps zm_monitor.cpp 3125
2018-03-22 14:28:12.645351 zma_m3 25049 INF Laundry: 35000 - Analysing at 14.93 fps zm_monitor.cpp 1296
2018-03-22 14:27:40.701304 zmc_m3 24957 INF Laundry: 35000 - Capturing at 15.15 fps zm_monitor.cpp 3125
2018-03-22 14:27:05.571235 zma_m3 25049 INF Laundry: 34000 - Analysing at 14.93 fps zm_monitor.cpp 1296
2018-03-22 14:26:34.034094 zmc_m3 24957 INF Laundry: 34000 - Capturing at 14.93 fps zm_monitor.cpp 3125
2018-03-22 14:25:58.320288 zma_m3 25049 INF Laundry: 33000 - Analysing at 14.93 fps zm_monitor.cpp 1296
2018-03-22 14:25:27.372156 zmc_m3 24957 INF Laundry: 33000 - Capturing at 14.93 fps zm_monitor.cpp 3125
2018-03-22 14:24:51.613290 zma_m3 25049 INF Laundry: 32000 - Analysing at 14.93 fps zm_monitor.cpp 1296
2018-03-22 14:24:20.702396 zmc_m3 24957 INF Laundry: 32000 - Capturing at 15.15 fps zm_monitor.cpp 3125
2018-03-22 14:23:44.860739 zma_m3 25049 INF Laundry: 31000 - Analysing at 14.93 fps zm_monitor.cpp 1296
2018-03-22 14:23:14.031614 zmc_m3 24957 INF Laundry: 31000 - Capturing at 14.93 fps zm_monitor.cpp 3125
2018-03-22 14:22:37.689927 zma_m3 25049 INF Laundry: 30000 - Analysing at 14.93 fps zm_monitor.cpp 1296
2018-03-22 14:22:07.402911 zmc_m3 24957 INF Laundry: 30000 - Capturing at 14.93 fps zm_monitor.cpp 3125
2018-03-22 14:21:30.734313 zma_m3 25049 INF Laundry: 29000 - Analysing at 14.93 fps zm_monitor.cpp 1296
2018-03-22 14:21:00.691632 zmc_m3 24957 INF Laundry: 29000 - Capturing at 15.15 fps zm_monitor.cpp 3125
2018-03-22 14:20:23.696270 zma_m3 25049 INF Laundry: 28000 - Analysing at 14.93 fps zm_monitor.cpp 1296
2018-03-22 14:20:00.206702 zma_m3 25049 INF Laundry: 27646 - Opening new event 3783, section start zm_monitor.cpp 1541
I'm really starting to think that either I'm not understanding something or that this is a bug. Is there any other information I can provide that will be helpful for troubleshooting?
Here's my journalctl -xe output:
It seems like the thing causing the whole thing to crash is:
Mar 27 13:58:39 zoneminder.pp.int.jewski.co zmdc[4939]: WAR ['zma -m 1' has not stopped at 18/03/27 13:58:39. Sending KILL to pid 2630]
Since it exits almost immediately after that.
Mar 27 13:58:32 zoneminder.pp.int.jewski.co zmwatch[5114]: INF [Restarting analysis daemon for Laundry]
Mar 27 13:58:32 zoneminder.pp.int.jewski.co zmdc[4939]: INF ['zma -m 1' sending stop to pid 2630 at 18/03/27 13:58:32]
Mar 27 13:58:34 zoneminder.pp.int.jewski.co zma_m1[2630]: INF [Got signal 15 (Terminated), exiting]
Mar 27 13:58:37 zoneminder.pp.int.jewski.co zma_m1[2630]: INF [Laundry: 4226 - Closing event 390, shutting down]
Mar 27 13:58:43 zoneminder.pp.int.jewski.co zmdc[4939]: INF ['zma -m 1' exited normally]
Mar 27 13:58:43 zoneminder.pp.int.jewski.co systemd[1]: zoneminder.service: main process exited, code=exited, status=255/n/a
Mar 27 13:58:43 zoneminder.pp.int.jewski.co zmpkg[6966]: INF [Sanity checking States table...]
Mar 27 13:58:45 zoneminder.pp.int.jewski.co zmpkg[6966]: INF [Command: stop]
Mar 27 13:58:47 zoneminder.pp.int.jewski.co systemd[1]: zoneminder.service: control process exited, code=exited status=1
Mar 27 13:58:50 zoneminder.pp.int.jewski.co zma_m2[3660]: INF [Got signal 15 (Terminated), exiting]
Mar 27 13:58:50 zoneminder.pp.int.jewski.co zmc_m2[5286]: INF [Got signal 15 (Terminated), exiting]
Mar 27 13:58:50 zoneminder.pp.int.jewski.co zmc_m1[5289]: INF [Got signal 15 (Terminated), exiting]
Mar 27 13:58:52 zoneminder.pp.int.jewski.co zma_m2[3660]: INF [Laundry 2: 3302 - Closing event 391, shutting down]
Mar 27 13:58:54 zoneminder.pp.int.jewski.co systemd[1]: Unit zoneminder.service entered failed state.
Mar 27 13:58:54 zoneminder.pp.int.jewski.co systemd[1]: zoneminder.service failed.
