Hikam S5
wtfka
Hikam S5
Post by wtfka »
i want to add a new monitor with a hikam s5. It works fine, if i watch the stream with VLC: rtsp://192.168.178.42:554/onvif1
In Zoneminder i just get a blue picture:
Source Type: ffmpeg
Source Path: rtsp://192.168.178.42:554/onvif1
Remote Method: TCP
Options:
Target colorspace: 24 bit
Capture Width (pixels): 1280
Capture Height (pixels): 720
1	zmc_m4		10891	INF	Daheim: 231000 - Capturing at 500.00 fps	zm_monitor.cpp	3125
2018-02-11 12:07:17.868160	zmc_m4		10891	INF	Daheim: 230000 - Capturing at 1000.00 fps	zm_monitor.cpp	3125
2018-02-11 12:07:16.534617	zmc_m4		10891	INF	Daheim: 229000 - Capturing at 1000.00 fps	zm_monitor.cpp	3125
2018-02-11 12:07:15.176436	zmc_m4		10891	INF	Daheim: 228000 - Capturing at 500.00 fps	zm_monitor.cpp	3125
2018-02-11 12:07:13.845669	zmc_m4		10891	INF	Daheim: 227000 - Capturing at 1000.00 fps	zm_monitor.cpp	3125
2018-02-11 12:07:12.457350	zmc_m4		10891	INF	Daheim: 226000 - Capturing at 1000.00 fps	zm_monitor.cpp	3125
2018-02-11 12:07:11.041306	zmc_m4		10891	INF	Daheim: 225000 - Capturing at 500.00 fps	zm_monitor.cpp	3125
2018-02-11 12:07:09.623498	zmc_m4		10891	INF	Daheim: 224000 - Capturing at 1000.00 fps	zm_monitor.cpp	3125
2018-02-11 12:07:08.173433	zmc_m4		10891	INF	Daheim: 223000 - Capturing at 500.00 fps	zm_monitor.cpp	3125
2018-02-11 12:07:06.718020	zmc_m4		10891	INF	Daheim: 222000 - Capturing at 1000.00 fps	zm_monitor.cpp	3125
2018-02-11 12:07:05.284860	zmc_m4		10891	INF	Daheim: 221000 - Capturing at 500.00 fps	zm_monitor.cpp	3125
2018-02-11 12:07:05.101603	zmc_m4		10897	ERR	Unable to open input rtsp://192.168.178.42:554/onvif1 due to: Broken pipe	zm_ffmpeg_camera.cpp	269
2018-02-11 12:07:05.072303	zmc_m4		10897	ERR	Unable to open input rtsp://192.168.178.42:554/onvif1 due to: Connection timed out	zm_ffmpeg_camera.cpp	269
2018-02-11 12:07:05.070157	zmc_m4		10897	ERR	Open video took more than 10 seconds.	zm_ffmpeg_camera.cpp	441
2018-02-11 12:07:03.858954	zmc_m4		10891	INF	Daheim: 220000 - Capturing at 1000.00 fps	zm_monitor.cpp	3125
2018-02-11 12:07:02.526616	zmc_m4		10891	INF	Daheim: 219000 - Capturing at 1000.00 fps	zm_monitor.cpp	3125
2018-02-11 12:07:01.210014	zmc_m4		10891	INF	Daheim: 218000 - Capturing at 500.00 fps	zm_monitor.cpp	3125
2018-02-11 12:06:59.893744	zmc_m4		10891	INF	Daheim: 217000 - Capturing at 1000.00 fps	zm_monitor.cpp	3125
2018-02-11 12:06:58.576557	zmc_m4		10891	INF	Daheim: 216000 - Capturing at 1000.00 fps	zm_monitor.cpp	3125
2018-02-11 12:06:57.247699	zmc_m4		10891	INF	Daheim: 215000 - Capturing at 500.00 fps	zm_monitor.cpp	3125
2018-02-11 12:06:55.921249	zmc_m4		10891	INF	Daheim: 214000 - Capturing at 1000.00 fps	zm_monitor.cpp	3125
2018-02-11 12:06:54.597909	zmc_m4		10891	INF	Daheim: 213000 - Capturing at 1000.00 fps	zm_monitor.cpp	3125
2018-02-11 12:06:53.281255	zmc_m4		10891	INF	Daheim: 212000 - Capturing at 500.00 fps	zm_monitor.cpp	3125
2018-02-11 12:06:51.956537	zmc_m4		10891	INF	Daheim: 211000 - Capturing at 1000.00 fps	zm_monitor.cpp	3125
2018-02-11 12:06:50.624011	zmc_m4		10891	INF	Daheim: 210000 - Capturing at 1000.00 fps	zm_monitor.cpp	3125
2018-02-11 12:06:49.286717	zmc_m4		10891	INF	Daheim: 209000 - Capturing at 500.00 fps	zm_monitor.cpp	3125
2018-02-11 12:06:47.964460	zmc_m4		10891	INF	Daheim: 208000 - Capturing at 1000.00 fps	zm_monitor.cpp	3125
2018-02-11 12:06:46.658198	zmc_m4		10891	INF	Daheim: 207000 - Capturing at 1000.00 fps	zm_monitor.cpp	3125
Any Ideas how to solve this?
Thx :)
flow
Re: Hikam S5
Post by flow »
Hello, i have the same issue.... is there a solution?
on onvif device manager it works
on vls mediaplayer it works
But with zoneminder not... why it works everywhere without config but not with zoneminder?
Log:
Unable to open input rtsp://10.0.1.51:554/onvif1 due to: Invalid data found when processing input
Thanks in Advance!
flow
Re: Hikam S5
Post by flow »
Haha okey guiys i got it working! xD
do not use TCP
HiKam of the first generation:
Source Type: ffmpeg
Source Path: rtsp://10.0.1.54:554/onvif1
Remote Method: UDP
