these are notices warning of some variables that have no values defined until after the monitor is created. I set my php.ini usually to this:
error_reporting = E_COMPILE_ERROR|E_RECOVERABLE_ERROR|E_ERROR|E_CORE_ERROR
and comment out the error_reporting line in the index.php, to shut off the warnings and notices but not the really bad stuff.
or sometimes I will change line 21 in the /usr/share/zoneminder/www/index.php to this
error_reporting( E_COMPILE_ERROR|E_RECOVERABLE_ERROR|E_ERROR|E_CORE_ERROR );
or just comment out line in the index.php
This is a hack fix.....there shouldn't be warnings for this but there is for now and some others that I have also run across and this seems to bypass the problem by pushing the error reporting to a higher level. I am running this on Puppy Linux Xenial 32bit 7.5 ...it is built with Ubuntu 16.04 binaries but differs from Ubuntu.
