My major issue is that there will be times the system just becomes unusable and a reboot is needed to recover. I am using two ReoLink C2 cameras (right now only using one). The log will show something like:
2017-11-13 10:28:02.466986 web_php[1712].ERR-/usr/share/zoneminder/www/includes/functions.php/2033 [Timed out waiting for msg /var/lib/zoneminder/sock/zms-177743s.sock]
2017-11-13 10:28:02.378241 web_php[1566].ERR-/usr/share/zoneminder/www/includes/functions.php/2033 [Socket /var/lib/zoneminder/sock/zms-177743s.sock does not exist. This file is created by zms, and since it does not exist, either zms did not run, or zms exited early. Please check your zms logs and ensure that CGI is enabled in apache and check that the PATH_ZMS is set correctly. Make sure that ZM is actually recording. If you are trying to view a live stream and the capture process (zmc) is not running then zms will exit. Please go to http://zoneminder.readthedocs.io/en/latest/faq.html#why-can-t-i-see-streamed-images-when-i-can-see-stills-in-the-zone-window-etc for more information.]
2017-11-13 10:27:59.916397 zms[23723].ERR-zm_monitor.cpp/4213 [Terminating, last frame sent time 1510586879.416237 secs more than maximum of 10.000000]
2017-11-13 10:27:59.367590 web_js[1566].ERR-?view=watch [getStreamCmdResponse stream error: socket_bind( /var/lib/zoneminder/sock/zms-177743w.sock ) failed: Address already in use - checkStreamForErrors()]
2017-11-13 10:27:59.286243 web_php[1566].ERR-/usr/share/zoneminder/www/includes/functions.php/2033 [socket_bind( /var/lib/zoneminder/sock/zms-177743w.sock ) failed: Address already in use]
2017-11-13 10:27:57.004406 zms[23715].ERR-zm_monitor.cpp/4213 [Terminating, last frame sent time 1510586876.504189 secs more than maximum of 10.000000]
If I reboot the zoneminder VM it works on a new reboot.
I had just restarted everything and after only a 10 minutes it stopped working. I believe this is the log prior to it stopping working. Not sure if that TDP parse failure corresponds with the exact moment it stops working or not...I am trying to correlate that.
2017-11-13 10:46:01.146615 zmc_m1[3058].ERR-zm_rtsp.cpp/88 [16: b7 7a d8 f2 da e4 f9 9d be 91 02 7a 8c 1e e3 8a]
2017-11-13 10:46:01.118868 zmc_m1[3058].ERR-zm_rtsp.cpp/86 [Response parse failure, 826 bytes follow]
2017-11-13 10:45:50.951479 web_js[1857].ERR-?view=watch [getStreamCmdResponse stream error: socket_bind( /var/lib/zoneminder/sock/zms-626033w.sock ) failed: Address already in use - checkStreamForErrors()]
2017-11-13 10:45:50.858050 web_php[1857].ERR-/usr/share/zoneminder/www/includes/functions.php/2033 [socket_bind( /var/lib/zoneminder/sock/zms-626033w.sock ) failed: Address already in use]
2017-11-13 10:45:50.829368 web_php[1497].ERR-/usr/share/zoneminder/www/includes/functions.php/2033 [Socket /var/lib/zoneminder/sock/zms-626033s.sock does not exist. This file is created by zms, and since it does not exist, either zms did not run, or zms exited early. Please check your zms logs and ensure that CGI is enabled in apache and check that the PATH_ZMS is set correctly. Make sure that ZM is actually recording. If you are trying to view a live stream and the capture process (zmc) is not running then zms will exit. Please go to http://zoneminder.readthedocs.io/en/latest/faq.html#why-can-t-i-see-streamed-images-when-i-can-see-stills-in-the-zone-window-etc for more information.]
2017-11-13 10:45:48.113437 zms[1898].ERR-zm_monitor.cpp/4213 [Terminating, last frame sent time 10.019719 secs more than maximum of 10.000000]
2017-11-13 10:45:42.568836 zmc_m1[1776].ERR-zm_rtsp.cpp/770 [Unexpected channel selector 192 in RTSP interleaved data]
