[SOLVED] Filtering alarm event in Mocord mode
felixita
Post by felixita »
Hy, currently i'm using a my self bash script to check if there are image stored into the disk captured by ZM in Modect. I use this script to send a Telegram msg to my phone if there are. Now, i need to do the same check in Mocord mode but i can't use this script since ZM save image continuously. I need to discriminate Alarm image within all continuously recorded images.
Someone can give me an advice to make this? I thought something like set ZM to naming this alarm image with a prefix, it's possible?
Thanks you all
felixita
Re: Filtering alarm event in Mocord mode
Post by felixita »
No one has an idea?
check out the example script zm-alarm.pl
I think it may be what you need. The script will detect alarms in Mocord mode.
felixita
Post by felixita »
thanks, i'll try.
felixita
Post by felixita »
this script work well in modect mode but Mocord i don't get any output
felixita
Post by felixita »
ok, with some changes I solved.
Thanks rockedge!
