Clone zones to new monitor
Posted: Fri Nov 10, 2017 7:42 pm
I'm new to ZoneMinder, having started with it about a week ago. I'm in the process of setting up my system and have found that I need more sensitive zone settings at night for the one monitor I have so far. To switch settings for day and night, I have cloned the monitor and set up run states appropriately. However, cloning the monitor only clones the configuration, but not the zones.
Is there a way to clone a monitor including the zones? I don't mind copying them manually and then adjusting the sensitivities, but it would be nice if there were an automatic way to do it, especially since I may eventually end up needing to do it for several cameras.
If the info helps any, I am using ZoneMinder 1.30.4 on Slackware. Thanks for any suggestions!
