[problem] Zoneminder several crash
vox
Re: [problem] Zoneminder several crash
Post by vox » Wed Nov 15, 2017 4:26 pm
It does not work on a remotely controlled server. ^^
osk
Post by osk » Wed Nov 15, 2017 6:59 pm
If you're lucky and your local host is Linux, then you should be able to run X11-applications (like software-properties-gtk) over network connection. You just have to start the remote session with ssh -X host instead of ssh host.
You can also add source support manually by editing file /etc/apt/sources.list directly. Unfortunately I have no detailed instructions for this!
vox
Post by vox » Wed Nov 22, 2017 5:35 pm
I haved try with -x option but not working. (their is some line about wayland)
I need command line if anybody can help, this bug is really, really, really blocking. (so painful that I check for alternatives)
montagdude
Post by montagdude » Wed Nov 22, 2017 7:15 pm
See this link for enabling downloading source code with apt:
https://askubuntu.com/questions/496549/ ... urces-list
osk
Post by osk » Fri Nov 24, 2017 9:05 am
Please note that lower case (small letter) option -x disables X11 forwarding. You have to use upper case (capital letter) option -X to enable X11 forwarding! See "man ssh" for more details.
Cheers
osk
vox
Post by vox » Sat Jan 13, 2018 11:02 am
I think i have drop the problem's source:
When the mariadb server (cluster) has a so big load, the database server fail.
I haved optimize the machine and, actually, the "bug" has dissipear.
Thanks for helping :)
Users browsing this forum: No registered users and 15 guests
