When I try to monitor a camera I do not get the camera view.
When I look at the source code of the page that is showing no images I see the following part of code.
</div>
</div>
</div>
<div id="imageFeed">
<img id="liveStream" src="/cgi-bin/nph-zms?mode=jpeg&scale=100&maxfps=30&buffer=1000&monitor=10&auth=b5b559115cae132d12959ee558719fe6&connkey=141909&rand=1508259429" alt="DeurRechts M" width="640" height="480"/> </div>
<div id="monitorStatus">
<div id="enableDisableAlarms"><a id="enableAlarmsLink" href="#" onclick="cmdEnableAlarms(); return( false );" class="hidden">Enable Alarms</a><a id="disableAlarmsLink" href="#" onclick="cmdDisableAlarms(); return( false );"
When I click on the link above in my browser (in 5th line above):
http://192.168.x.x/cgi-bin/nph-zms?mode=jpeg&scale=100&maxfps=30&buffer=1000&monitor=10&auth=b5b559115cae132d12959ee558719fe6&connkey=141909&rand=1508259429
Not Found
The requested URL /cgi-bin/nph-zms was not found on this server.
Apache/2.4.18 (Ubuntu) Server at 192.168.x.xx Port 80.
When I add “zm” behind the IP number like this
http://192.168.x.xx/zm/cgi-bin/nph-zms?mode=jpeg&scale=100&maxfps=30&buffer=1000&monitor=10&auth=b5b559115cae132d12959ee558719fe6&connkey=141909&rand=1508259429
I will get the correct stream.
So probably there is something wrong with my settings so that I miss the ZM folder in the path.
Does anyone know where I can correct this, because I have no idea?
