sudo apt updatate
sudo apt upgrade
Updated the database with
sudo zmupdate.pl
zmNinja is broken.
http://my_server/zm/api/host/getVersion.json
Searching I found a thread so I
sudo apt install php-apcu php-apcu-bc
https://my_server/zm/api/monitors.json and events.json gives me
Fatal error: Uncaught FatalErrorException: [MissingPluginException] Plugin Crud could not be found. #0 /usr/share/php/Cake/Core/App.php(227): CakePlugin::path('Crud') #1 /usr/share/php/Cake/Core/App.php(549): App::path('Lib', 'Crud') #2 [internal function]: App::load('CrudControllerT...') #3 /usr/share/zoneminder/www/api/app/Controller/AppController.php(34): spl_autoload_call('CrudControllerT...') #4 /usr/share/php/Cake/Core/App.php(567): include('/usr/share/zone...') #5 [internal function]: App::load('AppController') #6 [internal function]: spl_autoload_call('AppController') #7 /usr/share/php/Cake/Error/ExceptionRenderer.php(152): class_exists('AppController') #8 /usr/share/php/Cake/Error/ExceptionRenderer.php(92): ExceptionRenderer->_getController(Object(MissingPluginException)) #9 /usr/share/php/Cake/Error/ErrorHandler.php(126): ExceptionRenderer->__construct(Object(MissingPluginException)) #10 [internal function]: ErrorHandler::handleException(Object(MissingPluginException)) #11 {main} in /usr/share/php/Cake/Error/Err in /usr/share/php/Cake/Error/ErrorHandler.php on line 138
CakePHP: the rapid development php framework
Fatal Error
Error: Uncaught FatalErrorException: [MissingPluginException] Plugin Crud could not be found. #0 /usr/share/php/Cake/Core/App.php(227): CakePlugin::path('Crud') #1 /usr/share/php/Cake/Core/App.php(549): App::path('Lib', 'Crud') #2 [internal function]: App::load('CrudControllerT...') #3 /usr/share/zoneminder/www/api/app/Controller/AppController.php(34): spl_autoload_call('CrudControllerT...') #4 /usr/share/php/Cake/Core/App.php(567): include('/usr/share/zone...') #5 [internal function]: App::load('AppController') #6 [internal function]: spl_autoload_call('AppController') #7 /usr/share/php/Cake/Error/ExceptionRenderer.php(152): class_exists('AppController') #8 /usr/share/php/Cake/Error/ExceptionRenderer.php(92): ExceptionRenderer->_getController(Object(MissingPluginException)) #9 /usr/share/php/Cake/Error/ErrorHandler.php(126): ExceptionRenderer->__construct(Object(MissingPluginException)) #10 [internal function]: ErrorHandler::handleException(Object(MissingPluginException)) #11 {main} in /usr/share/php/Cake/Error/Err
File: /usr/share/php/Cake/Error/ErrorHandler.php
Line: 138
Notice: If you want to customize this error message, create app/View/Errors/fatal_error.ctp
CakePHP 2.8.5
Notice (8): Use of undefined constant ZM_DB_USER - assumed 'ZM_DB_USER' [CORE/Cake/Model/ConnectionManager.php, line 69]
Notice (8): Use of undefined constant ZM_DB_PASS - assumed 'ZM_DB_PASS' [CORE/Cake/Model/ConnectionManager.php, line 69]
Notice (8): Use of undefined constant ZM_DB_NAME - assumed 'ZM_DB_NAME' [CORE/Cake/Model/ConnectionManager.php, line 69]
I thought I would check here before I really broke something trying to fix this!
