Hello all, first I want to thanks you for all your work, ZM is really a great tool.
I have some issues with a Dahua DVR. I use ffmpeg and RTSP to get the video stream (found on ZM doc : https://wiki.zoneminder.com/Dahua ) but ZM (or maybe ffmpeg) can't correctly decode the image stream.
Source Type - Ffmpeg
Source Path - rtsp://login:password@YOURIPADDRESSHERE:554/cam/realmonitor?channel=0&subtype=1&tcp
Target Colourspace - 32 bit colour
Capture Width (pixels) - 1920
Capture Height (pixels) - 1080
Option - (Any option)
(Hight Definition screenprint, see on attachments for low definition)
I have make some tests with a lot of configs without any result.
If anyone has an idea, it will be wonderful
Sorry for my poor english and have a good day.
Image are not clean in the bottom
- Low Definition ScreenPrint
- 2017-09-20-141133_1440x900_scrot_edit-ConvertImage.png (487.38 KiB) Viewed 1012 times
