SOLVED - live works - playback not
Zsolt
Post by Zsolt » Sun Sep 17, 2017 6:59 pm
Since a few days I'm struggling with my setup.
While the live stream is working, the event playback logs the following errors.
I've seen some people having similar issues, tried altering PATH_ZMS, did not help (things got worse).
Running Ubuntu 16.04.3 with apache.
Baylink
Re: live works - playback not
Post by Baylink » Sun Sep 17, 2017 9:15 pm
This is, I think, a bug in the SQL code; I believe there's a thread running on it elsewhere; it has to do with monitor grouping.
Post by bbunge » Sun Sep 17, 2017 9:49 pm
What install instructions did you use? :With MySQL there are config file changes you need to make. Same with Mariadb.
Zsolt
Post by Zsolt » Mon Sep 18, 2017 5:19 am
I've installed using these instructions -> http://zoneminder.readthedocs.io/en/sta ... untu-16-04
Zsolt
Post by Zsolt » Mon Sep 18, 2017 5:29 am
Damn,
somehow my.cnf wasn't saved after I added sql_mode = NO_ENGINE_SUBSTITUTION
Case closed.
