Hi All,
I am trying to get my Netcat Cameras (Yucheng C01H4P2) to work. I have v1.30.4 Zoneminder installed on Ubuntu Server 16.04. All three of these cameras display full 1920x 1080 HD resolution when I access them via web brower with the camera’s dynamic IP. I have iSpy setup on a windows laptop temporarily and it works however the image quality is poor. Also, when I hit “Add New Monitor” and make all my settings, click save, and get an error message, the “Add New Monitor” window disappears and i have to start all over again. Has anyone else experienced this and if so is there a fix? Any help woul dbe great. I tried to provided as much detail as possible.
Ubuntu Server 16.04 w/no GUI
Running on a dedicated computer
AMD 4 Core CPU
4G RAM
1TB HDD
All hardware details listed below
Latest ZM Version v1.30.4
Camera Model: Yucheng C01H4P2
Resolution: 1920x1080
This is the URL I am using to access the stream:
http://admin:admin@192.168.0.100/tmpfs/auto.jpg
I got it from iSpy as it auto-generated it for me somehow and does work in iSpy.
Here are my ZM settings:
See ZM-PIC1-General
See ZM-PIC2-Source
Timestamp, Buffers, and Misc are all untouched and here is what I get when I hit “Save”
See ZM-PIC3-Error
Here are more details:
BIOS Information
Vendor: American Megatrends Inc.
Version: 1201
Release Date: 08/20/2012
Address: 0xF0000
Runtime Size: 64 kB
ROM Size: 2048 kB
Characteristics:
ISA is supported
PCI is supported
PNP is supported
APM is supported
BIOS is upgradeable
BIOS shadowing is allowed
ESCD support is available
Boot from CD is supported
Selectable boot is supported
BIOS ROM is socketed
EDD is supported
5.25"/1.2 MB floppy services are supported (int 13h)
3.5"/720 kB floppy services are supported (int 13h)
3.5"/2.88 MB floppy services are supported (int 13h)
Print screen service is supported (int 5h)
8042 keyboard services are supported (int 9h)
Serial services are supported (int 14h)
Printer services are supported (int 17h)
CGA/mono video services are supported (int 10h)
ACPI is supported
USB legacy is supported
LS-120 boot is supported
ATAPI Zip drive boot is supported
BIOS boot specification is supported
Targeted content distribution is supported
BIOS Revision: 8.15
System Information
Manufacturer: System manufacturer
Product Name: System Product Name
Version: System Version
Serial Number: System Serial Number
UUID: A0672D55-90FE-D511-984F-50465D696A51
Wake-up Type: Power Switch
SKU Number: To Be Filled By O.E.M.
Family: To Be Filled By O.E.M.
Base Board Information
Manufacturer: ASUSTeK Computer INC.
Product Name: M5A78L-M LX PLUS
Version: Rev X.0x
Serial Number: 121002904701475
Asset Tag: To Be Filled By O.E.M.
Features:
Board is a hosting board
Board is replaceable
Location In Chassis: To Be Filled By O.E.M.
Type: Motherboard
Chassis Information
Manufacturer: Chassis Manufacture
Type: Desktop
Lock: Not Present
Version: Chassis Version
Serial Number: Chassis Serial Number
Asset Tag: Asset-1234567890
Boot-up State: Safe
Power Supply State: Safe
Thermal State: Safe
Security Status: None
OEM Information: 0x00000001
Height: Unspecified
Number Of Power Cords: 1
Contained Elements: 0
Processor Information
Socket Designation: AM3R2
Type: Central Processor
Family: FX
Manufacturer: AMD
ID: 12 0F 60 00 FF FB 8B 17
Signature: Family 21, Model 1, Stepping 2
Flags:
FPU (Floating-point unit on-chip)
VME (Virtual mode extension)
DE (Debugging extension)
PSE (Page size extension)
TSC (Time stamp counter)
MSR (Model specific registers)
PAE (Physical address extension)
MCE (Machine check exception)
CX8 (CMPXCHG8 instruction supported)
APIC (On-chip APIC hardware supported)
SEP (Fast system call)
MTRR (Memory type range registers)
PGE (Page global enable)
MCA (Machine check architecture)
CMOV (Conditional move instruction supported)
PAT (Page attribute table)
PSE-36 (36-bit page size extension)
CLFSH (CLFLUSH instruction supported)
MMX (MMX technology supported)
FXSR (FXSAVE and FXSTOR instructions supported)
SSE (Streaming SIMD extensions)
SSE2 (Streaming SIMD extensions 2)
HTT (Multi-threading)
Version: AMD FX(tm)-8120 Eight-Core Processor
Voltage: 1.3 V
External Clock: 200 MHz
Max Speed: 3100 MHz
Current Speed: 3100 MHz
Status: Populated, Enabled
Upgrade: Socket AM3
Serial Number: To Be Filled By O.E.M.
Part Number: To Be Filled By O.E.M.
Core Count: 8
Core Enabled: 8
Thread Count: 8
Characteristics:
64-bit capable
Cache Information
Socket Designation: L1-Cache
Configuration: Enabled, Not Socketed, Level 1
Operational Mode: Write Back
Installed Size: 384 kB
Maximum Size: 384 kB
Supported SRAM Types:
Pipeline Burst
Installed SRAM Type: Pipeline Burst
Speed: 1 ns
Error Correction Type: Multi-bit ECC
System Type: Unified
Associativity: 2-way Set-associative
Cache Information
Socket Designation: L2-Cache
Configuration: Enabled, Not Socketed, Level 2
Installed Size: 8192 kB
Maximum Size: 8192 kB
Pipeline Burst
Speed: 1 ns
Associativity: 16-way Set-associative
Cache Information
Socket Designation: L3-Cache
Configuration: Enabled, Not Socketed, Level 3
Pipeline Burst
Speed: 1 ns
Associativity: 64-way Set-associative
Port Connector Information
Internal Reference Designator: PS/2 KeyBoard
Internal Connector Type: None
External Reference Designator: Keyboard
External Connector Type: PS/2
Port Type: Keyboard Port
Internal Reference Designator: PS/2 Mouse
External Reference Designator: PS2Mouse
Port Type: Mouse Port
Internal Reference Designator: USB12
External Reference Designator: USB12
External Connector Type: Access Bus (USB)
Port Type: USB
Internal Reference Designator: USB34
External Reference Designator: USB34
Port Type: USB
Internal Reference Designator: LAN
External Reference Designator: LAN
External Connector Type: RJ-45
Port Type: Network Port
Internal Reference Designator: Audio_Line_In
External Reference Designator: Audio_Line_In
External Connector Type: Mini Jack (headphones)
Port Type: Audio Port
Internal Reference Designator: Audio_Line_Out
External Reference Designator: Audio_Line_Out
Internal Reference Designator: Audio_Mic_In
External Reference Designator: Audio_Mic_In
Internal Reference Designator: VGA
External Reference Designator: D_SUB
External Connector Type: DB-15 female
Port Type: Video Port
Internal Reference Designator: COM1
External Reference Designator: COM1
External Connector Type: 9 Pin Dual Inline (pin 10 cut)
Port Type: Other
Internal Reference Designator: LPT
External Reference Designator: LPT
External Connector Type: 25 Pin Dual Inline (pin 26 cut)
Port Type: Other
Internal Reference Designator: SATA3G_1
Internal Connector Type: Other
External Reference Designator: Not Specified
External Connector Type: None
Port Type: Other
Internal Reference Designator: SATA3G_2
Port Type: Other
Internal Reference Designator: SATA3G_3
Port Type: Other
Internal Reference Designator: SATA3G_4
Port Type: Other
Internal Reference Designator: SATA3G_5
Port Type: Other
Internal Reference Designator: SATA3G_6
Port Type: Other
Internal Reference Designator: CPU FAN
Port Type: Other
Internal Reference Designator: CHA FAN
Port Type: Other
Internal Reference Designator: USB56
Internal Connector Type: Access Bus (USB)
Port Type: USB
Internal Reference Designator: USB78
Port Type: USB
Internal Reference Designator: USB910
Port Type: USB
Internal Reference Designator: PANEL
Port Type: Other
Internal Reference Designator: SPDIF OUT
Port Type: Other
Internal Reference Designator: AAFP
Port Type: Other
System Slot Information
Designation: PCIEX1_1
Type: 32-bit PCI Express
Current Usage: Available
Length: Short
Characteristics:
3.3 V is provided
Opening is shared
PME signal is supported
Designation: PCIE16X
Length: Short
Characteristics:
3.3 V is provided
Opening is shared
Designation: PCIEX1_2
Length: Short
Characteristics:
3.3 V is provided
Opening is shared
Designation: PCI1
Type: 32-bit PCI
Length: Short
Characteristics:
3.3 V is provided
Opening is shared
On Board Device Information
Type: Video
Status: Enabled
Description: ATI
Type: Ethernet
Status: Enabled
Description: To Be Filled By O.E.M.
Type: Sound
Status: Enabled
Type: Other
Status: Enabled
OEM Strings
String 1: 50465D696A51
String 2: To Be Filled By O.E.M.
String 3: To Be Filled By O.E.M.
String 4: To Be Filled By O.E.M.
BIOS Language Information
Language Description Format: Abbreviated
Installable Languages: 1
en|US|iso8859-1
Currently Installed Language: en|US|iso8859-1
System Event Log
Area Length: 4 bytes
Header Start Offset: 0x0000
Header Length: 2 bytes
Data Start Offset: 0x0002
Access Method: Indexed I/O, one 16-bit index port, one 8-bit data port
Access Address: Index 0x046A, Data 0x046C
Status: Invalid, Not Full
Change Token: 0x00000000
Header Format: No Header
Supported Log Type Descriptors: 6
Descriptor 1: End of log
Data Format 1: OEM-specific
Descriptor 2: End of log
Data Format 2: OEM-specific
Descriptor 3: End of log
Data Format 3: OEM-specific
Descriptor 4: End of log
Data Format 4: OEM-specific
Descriptor 5: End of log
Data Format 5: OEM-specific
Descriptor 6: End of log
Data Format 6: OEM-specific
Physical Memory Array
Use: System Memory
Error Correction Type: None
Maximum Capacity: 8 GB
Number Of Devices: 2
Memory Array Mapped Address
Starting Address: 0x00000000000
Ending Address: 0x0022EFFFFFF
Range Size: 8944 MB
Partition Width: 1
Memory Device
Total Width: 64 bits
Data Width: 64 bits
Form Factor: DIMM
Set: None
Locator: DIMM0
Bank Locator: BANK0
Type: Other
Type Detail: Synchronous
Speed: 1600 MHz
Manufacturer: Manufacturer0
Serial Number: SerNum0
Asset Tag: AssetTagNum0
Part Number: PartNum0
Memory Device Mapped Address
Ending Address: 0x000FFFFFFFF
Range Size: 4 GB
Partition Row Position: 1
Memory Device
Data Width: 64 bits
Form Factor: DIMM
Set: None
Locator: DIMM1
Bank Locator: BANK1
Type: Other
Speed: 1600 MHz
Manufacturer: Manufacturer1
Serial Number: SerNum1
Asset Tag: AssetTagNum1
Part Number: PartNum1
Starting Address: 0x00100000000
Ending Address: 0x001FFFFFFFF
Range Size: 4 GB
System Boot Information
Status: No errors detected
ZM with YUCHENG C01H4P2 Stream ERROR
- ZM-PIC3-Error
- Selection_004.png (63.79 KiB) Viewed 1231 times
- ZM-PIC2-Source
- Selection_003.png (37.33 KiB) Viewed 1231 times
- ZM-PIC1-General
- Selection_002.png (40.9 KiB) Viewed 1231 times
