I have a Dlink Dcs-8200. I can connect to the camera stream via VLC from windows desktop on the lan via the URL:
rtsp://user:password@192.168.5.29:554/play2.sdp
which stream to VLC a H264 video plus MPEG4 audio.
I have configured Zoneminder source as follow:
Source Type: FFMPEG
Source Path: rtsp://user:password@192.168.5.29:554/play2.sdp
Remote Method: TCP
Options: allowed_media_types=video
Target colorspace: 24 bit colour
Capture Width (pixels): 1280
Capture Height (pixels):720
This is my log:
2017-08-23 19:03:57.769095 zmc_m1 22535 INF Salone: 11000 - Capturing at 9.90 fps zm_monitor.cpp 3125
2017-08-23 19:02:16.667796 zmc_m1 22535 INF Salone: 10000 - Capturing at 9.90 fps zm_monitor.cpp 3125
2017-08-23 19:00:35.577563 zmc_m1 22535 INF Salone: 9000 - Capturing at 9.90 fps zm_monitor.cpp 3125
2017-08-23 18:58:54.462841 zmc_m1 22535 INF Salone: 8000 - Capturing at 9.90 fps zm_monitor.cpp 3125
2017-08-23 18:57:13.358259 zmc_m1 22535 INF Salone: 7000 - Capturing at 9.90 fps zm_monitor.cpp 3125
2017-08-23 18:55:32.280566 zmc_m1 22535 INF Salone: 6000 - Capturing at 9.90 fps zm_monitor.cpp 3125
2017-08-23 18:53:51.212883 zmc_m1 22535 INF Salone: 5000 - Capturing at 9.90 fps zm_monitor.cpp 3125
2017-08-23 18:52:10.129484 zmc_m1 22535 INF Salone: 4000 - Capturing at 9.90 fps zm_monitor.cpp 3125
2017-08-23 18:50:29.042931 zmc_m1 22535 INF Salone: 3000 - Capturing at 9.80 fps zm_monitor.cpp 3125
2017-08-23 18:48:47.965653 zmc_m1 22535 INF Salone: 2000 - Capturing at 9.90 fps zm_monitor.cpp 3125
2017-08-23 18:47:06.912345 zmc_m1 22535 INF Salone: 1000 - Capturing at 9.71 fps zm_monitor.cpp 3125
2017-08-23 18:45:33.008122 web_js 22437 ERR getStreamCmdResponse stream error: Socket /var/run/zm/zms-554656s.sock does not exist. This file is created by zms, and since it does not exist, either zms did not run, or zms exited early. Please check your zms logs and ensure that CGI is enabled in apache and check that the PATH_ZMS is set correctly. Make sure that ZM is actually recording. If you are trying to view a live stream and the capture process (zmc) is not running then zms will exit. Please go to http://zoneminder.readthedocs.io/en/lat ... window-etc for more information. - checkStreamForErrors() ?view=watch
I cannot show the video in the zoneminder console. I also have an alternative URL with mjpeg video + mpg4 audio. But it doesn't work.
I tried with ubuntu 16 and ubuntu 14 server but the result is the same.
Any idea? I think that configuring this dlink camera in zoneminder can be usefull for a lot of people.
Carlo
Dlink Dcs-8200 source
Re: Dlink Dcs-8200 source
This is what I found in log:
[rtsp @ 0x85bea9e0] video codec set to: h264
[NULL @ 0x85bee580] RTP Profile IDC: 42 Profile IOP: 0 Level: 1e
[NULL @ 0x85bee580] RTP Packetization Mode: 1
[NULL @ 0x85bee580] Extradata set to 0x85bd5880 (size: 62)!
[rtsp @ 0x85bea9e0] hello state=0
[rtsp @ 0x85bea9e0] All info found
[rtsp @ 0x85bea9e0] Estimating duration from bitrate, this may be inaccurate
[h264 @ 0x85bee580] detected 1 logical cores
[h264 @ 0x85bee580] Frame num gap 10 8
[h264 @ 0x85bee580] no picture
[h264 @ 0x85bee580] Frame num gap 3 1
[h264 @ 0x85bee580] Frame num gap 2 0
[h264 @ 0x85bee580] Frame num gap 9 7
[h264 @ 0x85bee580] Frame num gap 5 3
If I put the camera configured with libvlc in record mode I the see image of the camera but not the streamed video
