Hello All
I installed Zoneminder 1.30.4
I wanted to know can the Zoneminder login shown during the login section be changed as per my requirements and also if possible can the inside heading mentioning zoneminder be customized
Thanks and regards
Customize the Zoneminder name at login (title) and few other sections
Re: Customize the Zoneminder name at login (title) and few other sections
sure you can. the file to modify is /usr/share/zoneminder/www/skins/classic/views/login.php
for example change line 18
to:
then logout and login and see the small change.
<h1>ZoneMinder <?php echo translate('Login') ?></h1>
<h1>ZoneMinder Customized <?php echo translate('Login') ?></h1>
Thanks it works fine..is there a way to change the text while logging in showing zoneminder and after logging in in the top zoneminder console and edit version hyperlink
