Can any one helps me on how to configure a Wanscam JW0011 on Zonemider 1.3...
i have tried everything but still i'm getting a blue display on the monitor.
Wanscam JW0011 set on Zonemider 1.3
Re: Wanscam JW0011 set on Zonemider 1.3
i had checked https://www.ispyconnect.com/man.aspx?n=Wanscam, but still the streaming path seems not to work!if there any addition to be configured!
Can someone helps please!
do you see a time stamp being displayed on the blue screen? this sounds like the camera resolution is set incorrectly. this must match exactly what the camera is outputting or the blue screen will appear. try to open the camera with VLC and check that your port for the camera is correctly set.
Yes the timestamp is displayed on blue screen...okay i will try to open using VLC, the port set is 99 unless as you mentioned the camera output is not matching with configs on zoneminder..Thanks
Thanks rockedge for the help...i connected using VLC and set up the same image resolution and i was able to stream from Zoneminder...
But the image seems to not be stable, the blue image keeps coming at certain moment!
I have a dLink and a HOOTOO camera that when WIFI connected to the network tend to drop out and reconnect occasionally and I get a brief blue screen and in nodect will start recordings which I use a Filter to look for Cause = Signal to remove them. Glad you got it going! Good work. Perhaps a couple of fine tuning tweaks will improve your situation!
