Installed the zmeventserver following the instructions on https://github.com/pliablepixels/zmeventserver. All went ok with the installation but I'm unable to start the script. It's loading and then stops and shows:
root@xxxxxxx:~# sudo /usr/bin/zmeventnotification.pl
failed to listen: at /usr/bin/zmeventnotification.pl line 1191.
May 23 17:36:45 xxxxxxx zmeventnotification[5728]: INF [Push enabled via PushProxy]
May 23 17:36:45 xxxxxxx zmeventnotification[5728]: INF [direct APNS disabled]
May 23 17:36:45 xxxxxxx zmeventnotification[5728]: INF [Event Notification daemon v 0.93 starting]
May 23 17:36:45 xxxxxxx zmeventnotification[5728]: INF [Total event client connections: 0]
May 23 17:36:45 xxxxxxx zmeventnotification[5728]: INF [Reloading Monitors...]
May 23 17:36:45 xxxxxxx zmeventnotification[5728]: INF [Loading monitors]
May 23 17:36:45 xxxxxxx zmeventnotification[5728]: INF [Checking https://185.124.74.36:8801 reachability...]
May 23 17:36:46 xxxxxxx zmeventnotification[5728]: INF [PushProxy https://185.124.74.36:8801 is reachable.]
May 23 17:36:46 xxxxxxx zmeventnotification[5728]: INF [About to start listening to socket]
I'm running Ubuntu 16.04 LTS, fresh install with only ZoneMinder and nothing else.
What could be the reason?
Any help would be appreciated.
